Home » Eclipse Projects » BIRT » Trying to create a report variable that returns yesterday's date in yyyy-MM-dd format
Trying to create a report variable that returns yesterday's date in yyyy-MM-dd format [message #756986] Tue, 15 November 2011 20:35 Go to next message
Todd  is currently offline Todd Friend
I am new to this and I am trying to create a variable on a report that will return yesterday's date formatted yyyy-MM-dd and have had no luck. Any help would be appreciated. I have tried
BirtDateTime.year(BirtDateTime.now()) + "-" + BirtDateTime.month((BirtDateTime.now()) + "-" BirtDateTime.day(BirtDateTime.now())
and it will return today's date in the required format, but I can't get it to pull yesterday (and it doesn't seem like the correct way to get this to work).
The reason I am looking for a variable is so that I can use it in a number of filters for the report that all require yesterdays date in that format.
thanks
Re: Trying to create a report variable that returns yesterday's date in yyyy-MM-dd format [message #756989 is a reply to message #756986] Tue, 15 November 2011 21:18 Go to previous message
I found a solution
Formatter.format(BirtDateTime.addDay(BirtDateTime.today(),-1), "YYYY-MM-dd")
Previous Topic:Encoding a report design in another xml?
Next Topic:birt chart accessibility options
Current Time: Fri Jan 19 21:08:48 GMT 2018
Powered by FUDForum. Page generated in 0.02016 seconds
