Home » Archived » Maven Integration (M2E) » Classpath entry org.maven.ide.eclipse.MAVEN2_CLASSPATH_CONTAINER will not be exported or published.
Classpath entry org.maven.ide.eclipse.MAVEN2_CLASSPATH_CONTAINER will not be exported or published. [message #756752] Mon, 14 November 2011 22:40
Mahmoud Saleh is currently offline Mahmoud SalehFriend
hi
sometimes when importing a maven project in eclipse, i get the following error:
Classpath entry org.maven.ide.eclipse.MAVEN2_CLASSPATH_CONTAINER will not be exported or published. Runtime ClassNotFoundExceptions may result
although the classpath file on the svn repo contains the maven dependencies entry:
<classpathentry kind="con" path="org.maven.ide.eclipse.MAVEN2_CLASSPATH_CONTAINER">
    		<attributes>
    			<attribute name="org.eclipse.jst.component.dependency" value="/WEB-INF/lib"/>
    		</attributes>
    	</classpathentry>
i know the workaround to solve the issue by going to project deployment assembly and adding maven dependencies manually (which will add the entry above again !), but i am curious to know, why such error is generated, although classpath contains the dependencies entry ?
please advise, thanks.
Previous Topic:Maven WTP Project not respecting [provided] scope
Next Topic:Adding Maven commands
Current Time: Thu Apr 26 12:04:43 GMT 2018
Powered by FUDForum. Page generated in 0.01797 seconds
