Home » Newcomers » Newcomers » How to add PHP development to Eclipse already setup for Java & Androkd?(Can I use Eclipse for PHP development as well as Java and Android development?)
How to add PHP development to Eclipse already setup for Java & Androkd? [message #755889] Thu, 10 November 2011 02:51 Go to next message
MyEmailList is currently offline MyEmailListFriend
I have setup Eclipse on a XP Pro PC to do Android & Java Development.
On another XP Pro PC I setup Eclipse (months ago) to do PHP development... but got side tracked and it just set there.
Now I would like to be able to work on only one machine (XP Pro PC) with Eclipse to do PHP development sometimes and at other times to be able to do Android/Java development.
I think I need to download the PHP stuff to the Android/Java Eclipse installation but am not sure exactly where to click or how to do it.
I already have Apache and MySQL running on the PC and have done some PHP dev with Notepad... but would really like to be able to switch Eclipse back and forth between PHP dev and Android/Java dev.
Where do I click and what do I do to add the PHP development capibility to Eclipse?
Thanks for any help.
Re: How to add PHP development to Eclipse already setup for Java & Androkd? [message #756810 is a reply to message #755889] Tue, 15 November 2011 08:52 Go to previous message
Christian Pontesegger is currently offline Christian PonteseggerFriend
In your Eclipse installation select menu Help -> Install New Software...
Select the Indigo update site. Afterwards enable Programming languages -> PHP Development Tools and whatever you might need else.
Previous Topic:Installing m2e and wtp on eclipse helios 3.6
Next Topic:Strange SelectionService behaviour
Current Time: Sat Feb 24 02:59:15 GMT 2018
Powered by FUDForum. Page generated in 0.03285 seconds
