Home » Newcomers » Newcomers » Java Error: Could not find or load main class <classname>(Java Error)
Java Error: Could not find or load main class <classname> [message #754954] Sat, 05 November 2011 16:14 Go to next message
sheffy89 is currently offline sheffy89
I'm new to Java and just downloaded the Eclipse Indigo IDE. I used a very basic "hello world" code copied directly from the Eclipse tutorial prompt. Every time I try to compile (I think it's called "run" in eclipse) I get this message:
"Could not find or load main class test"
(if test is the name of my class)
Any suggestions?
Re: Java Error: Could not find or load main class &lt;classname&gt; [message #754959 is a reply to message #754954] Sat, 05 November 2011 17:01 Go to previous message
Russell Bateman is currently offline Russell Bateman
On 2011.11.05 14:14, sheffy89 wrote:
> Any suggestions?
> Thanks
If your project compiles cleanly and if you've got a properly defined
main defined in the class and if you right-click the .java file and
choose Run As..., this should work.
I suggest following http://www.vogella.de/articles/Eclipse/article.html
to get oriented in using Eclipse.
Previous Topic:How to start plugin development
Next Topic:UnsupportedOperationException
Current Time: Fri May 24 03:35:49 EDT 2013
Powered by FUDForum. Page generated in 0.01601 seconds
