| persisting EObjects on the web server (custom resourceSet or jpa/jdo annotations or something else?) [message #754112] |
Mon, 31 October 2011 16:11  |
Tom H Messages: 136 Registered: July 2009 |
I have been using the ecore tools for generating my java objects, and I have been using a ResourceSet to persist my objects for development, however for live persistence I have not yet moved from the old school DAO pattern, where there is a DAO object which is a layer to a quite hard coded set of SQL statements.
I have been asked to migrate some projects to the Google App Engine platform, that have their models stored as ecore.
I have a fairly clear field to choose from here, but I am quite confused as to what I should be considering as an option.
It looks possible to generate JPA/JDO annotations for each of modelled classes and not use any of the Factory/Package/Resourceset functionality of EMF.
It seems that following that route though loses all the cool generated editor code, because none of them will be able to persist to the google datastore directly, or at least will require a data layer to do so.
Any suggestions on how to proceed would be appreciated
Thanks.
| Re: persisting EObjects on the web server (custom resourceSet or jpa/jdo annotations or something el [message #754115 is a reply to message #754112] |
Mon, 31 October 2011 17:01   |
Martin Taal Messages: 5054 Registered: July 2009 |
Hi Tom,
There are several options:
- Texo: http://wiki.eclipse.org/Texo which generates pojo's with jpa annotations/orm from ecore/xsd models, the
generated code are real pojos and can be persisted in a standard jpa way, it also provides emf back/from pojo
conversion, so great for webserver environments but it won't work with generated EMF editors (although rcp data binding
should work fine with Texo pojos also)
- Teneo: http://wiki.eclipse.org/Teneo/Hibernate which persists native EMF generated code using Hibernate, it can be
used within webserver environments as well as in the rcp (generated emf editors).
- CDO: http://wiki.eclipse.org/CDO: use cdo for the RCP's (emf generated editors) and just treat the web server google
app engine as another cdo client. CDO also has a hibernate store (http://wiki.eclipse.org/CDO_Hibernate_Store)
gr. Martin
> Thanks.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.01509 seconds
