Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Accessing Properties of Custom Dialog(I've to access the properties of a custom dialog i created)
icon5.gif  Accessing Properties of Custom Dialog [message #754033] Mon, 31 October 2011 14:51 Go to next message
Arul  is currently offline Arul Friend
I'm learning SWT and i have created a custom dialog by extending the Dialog class.
KeyDialog:
public class KeyDialog extends Dialog
	Object result;
	String str;
	public KeyDialog(Shell parent,int style)
		super(parent,style);
	public KeyDialog(Shell parent)
		this(parent,0);
	public Object open ()
	      //My code goes here
		return result;
I have opened this dialog from another class as :
Object res;
kd1=new KeyDialog(shell);
res=kd1.open();
How can i access the String str in KeyDialog class ?
Any suggestions are welcome......
Re: Accessing Properties of Custom Dialog [message #754040 is a reply to message #754033] Mon, 31 October 2011 15:00 Go to previous messageGo to next message
Daniel Krügler is currently offline Daniel KrüglerFriend
> Dialog class.
> KeyDialog:
> Object res;
> res=kd1.open();
This form of getting the return type of open looks suspicious. What does
it help that you query the int value as an Object?
There is no much magic behind that, just do it as you would do it in
other classes: Provide a getter for it.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Accessing Properties of Custom Dialog [message #754049 is a reply to message #754040] Mon, 31 October 2011 15:21 Go to previous message
Thank you Daniel...
I didn't think about that. Worked superb....
Previous Topic:Problem with ScrolledPageBook, SashFom and TableViewer combined
Next Topic:Tooltip on Text
Current Time: Thu May 24 21:45:40 GMT 2018
Powered by FUDForum. Page generated in 0.02363 seconds
