Home » Eclipse Projects » Rich Client Platform (RCP) » cannot add view via Extension wizard
cannot add view via Extension wizard [message #753892] Sun, 30 October 2011 10:32 Go to next message
senhatsu is currently offline senhatsuFriend
In my plugin project I can add the org.eclipse.ui.views extension.
But unfortunately the next step - adding an actual view - is not possible.
The only option the wizard gives is to add a generic element.
How is it possible to add a view to the org.eclipse.ui.views extension via the new wizard?
P.S.
My environment is Eclipse Indigo Java EE IDE for Web Developers and Java SE 1.6 (JDK).
[Updated on: Sun, 30 October 2011 14:13]
Report message to a moderator
Re: cannot add view via Extension wizard [message #753905 is a reply to message #753892] Sun, 30 October 2011 14:16 Go to previous messageGo to next message
The schema files where missing.
Apparently this is a known issue.
Search for "Eclipse plugin editor extension tab show "Generic" in "New" submenu".
[Updated on: Sun, 30 October 2011 14:18]
Re: cannot add view via Extension wizard [message #753928 is a reply to message #753905] Sun, 30 October 2011 17:22 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
What Eclipse version did you download? You need to source-bundles from
the platform because they are not packaged into the binary-bundles.
Tom
Am 30.10.11 15:16, schrieb senhatsu:
> Apparently there the schema files where missing.
Re: cannot add view via Extension wizard [message #753930 is a reply to message #753928] Sun, 30 October 2011 17:46 Go to previous message
Dear Tom,
thanks for the reply.
Before posting the problem I had already set up a custom Target Platform containing the Eclipse RCP SDK.
But I didn't use it.
After I changed the preferences to use the custom Target Platform, it did work.
Best wishes,
Thomas
Previous Topic:enabledWhen + menus without commands
Next Topic:Web Start Xerces Issue
Current Time: Sat Feb 24 21:58:40 GMT 2018
Powered by FUDForum. Page generated in 0.01967 seconds
