Home » Eclipse Projects » BIRT » PDF/A-1a and PDF/A-1b?
PDF/A-1a and PDF/A-1b? [message #751608] Wed, 26 October 2011 01:28 Go to next message
Missing name Missing name is currently offline Missing name Missing name
Member
Does BIRT (2.6.1) produce PDF files, which conform the PDF/A-1a and PDF/A-1b standards? Simply these standards are for the digital preservation of the documents. For example the fonts should be embedded in the PDF etc. I checked my code and I have not used PDFRenderOption.setEmbededFont(true). What default value BIRT uses with the font embedding?
See the http://en.wikipedia.org/wiki/PDF/A for more information.
Is there any specific BIRT API commands I have to use to conform above standards?
BR,
Mika
[Updated on: Wed, 26 October 2011 02:04]
Report message to a moderator
Re: PDF/A-1a and PDF/A-1b? [message #752810 is a reply to message #751608] Wed, 26 October 2011 10:25 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
BIRT uses iText to generate PDF and iText has a setPDFXConformance
method, but currently BIRT does not make this call in the PDF emitter.
PdfWriter writer = PdfWriter.getInstance(document,
new FileOutputStream(filename));
writer.setPdfVersion(PdfWriter.PDF_VERSION_1_4);
writer.setPDFXConformance(PdfWriter.PDFA1B)
I am not certain whether this means that the the files BIRT produces are
not compliant. You could always change the source and add the call.
Jason
On 10/26/2011 1:28 AM, mika.tapanainen wrote:
> Hello,
> PDF/A-1b standards?
> standards?
> BR,
> Mika
Jason Weathersby
BIRT Exchange
Re: PDF/A-1a and PDF/A-1b? [message #753403 is a reply to message #752810] Thu, 27 October 2011 01:56 Go to previous messageGo to next message
Member
Is it really so that I have to change the source code? Is it possible that in the future releases of the BIRT API there would be a possibility to set above conformance (PdfWriter.PDFA1B, PdfWriter.PDF_VERSION_1_4 etc.) directly?
BR,
Mika
[Updated on: Thu, 27 October 2011 01:56]
Re: PDF/A-1a and PDF/A-1b? [message #753527 is a reply to message #753403] Thu, 27 October 2011 11:08 Go to previous messageGo to next message
Open a bugzilla entry to see if we can get an option put in the pdf
emitter for this.
Jason
> etc.) directly?
Jason Weathersby
BIRT Exchange
Re: PDF/A-1a and PDF/A-1b? [message #753661 is a reply to message #753527] Fri, 28 October 2011 05:00 Go to previous messageGo to next message
Member
I posted this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=362282
Re: PDF/A-1a and PDF/A-1b? [message #753771 is a reply to message #753661] Fri, 28 October 2011 12:50 Go to previous messageGo to next message
Thanks for posting the number.
On 10/28/2011 5:00 AM, mika.tapanainen wrote:
> I posted this:
Jason Weathersby
BIRT Exchange
Re: PDF/A-1a and PDF/A-1b? [message #766183 is a reply to message #753771] Thu, 15 December 2011 05:32 Go to previous messageGo to next message
NJ Missing name is currently offline NJ Missing name
Is there any news on this topic? i.e. Is it planned to implement this feature in the near future? We also have a need to archive data that is exported using BIRT. The format has to be PDF/A-1b
Thanks in advance for your help.
Re: PDF/A-1a and PDF/A-1b? [message #766347 is a reply to message #766183] Thu, 15 December 2011 10:31 Go to previous messageGo to next message
It is not in the development plan yet. Hopefully we will have an update
shortly.
Jason
Jason Weathersby
BIRT Exchange
Re: PDF/A-1a and PDF/A-1b? [message #766745 is a reply to message #766347] Fri, 16 December 2011 05:49 Go to previous messageGo to next message
Great, thanks, I look forward to an update in the near future. It would be great if this can be completed in Q1 2012.
[Updated on: Fri, 16 December 2011 05:51]
Re: PDF/A-1a and PDF/A-1b? [message #783245 is a reply to message #766745] Wed, 25 January 2012 05:52 Go to previous messageGo to next message
Any news / updates yet?
N.
Re: PDF/A-1a and PDF/A-1b? [message #783861 is a reply to message #783245] Thu, 26 January 2012 10:49 Go to previous messageGo to next message
I am pretty certain this is planned for the next major version of BIRT
(June), 3.6.2 will be out in a couple of weeks, and it may make it in
that version but I doubt it.
Jason
> Thanks
> N.
Jason Weathersby
BIRT Exchange
Re: PDF/A-1a and PDF/A-1b? [message #784243 is a reply to message #783861] Fri, 27 January 2012 03:40 Go to previous messageGo to next message
Ok, thanks will check back here in a couple of weeks then.
Re: PDF/A-1a and PDF/A-1b? [message #893754 is a reply to message #751608] Thu, 05 July 2012 09:04 Go to previous messageGo to next message
m.kassens is currently offline m.kassens
Something new in Birt 4.2 for PDF/A-1a or PDF/A-1b?
Re: PDF/A-1a and PDF/A-1b? [message #893808 is a reply to message #893754] Thu, 05 July 2012 10:28 Go to previous messageGo to next message
I do not believe that bugzilla entry was implemented in 4.2.
Jason
Jason Weathersby
BIRT Exchange
Re: PDF/A-1a and PDF/A-1b? [message #1020504 is a reply to message #893808] Mon, 18 March 2013 06:22 Go to previous messageGo to next message
Adrian Andras is currently offline Adrian Andras
Any news for PDF/A-1a or PDF/A-1b in upcomming release of BIRT 4.3?
Adrian
Re: PDF/A-1a and PDF/A-1b? [message #1021178 is a reply to message #1020504] Tue, 19 March 2013 12:03 Go to previous messageGo to next message
Adrian
We are publishing the 4.3 plan this week, but this bug is not in the list. Is patching the PDF an emitter an option?
Jason Weathersby
BIRT Exchange
Re: PDF/A-1a and PDF/A-1b? [message #1021235 is a reply to message #1021178] Tue, 19 March 2013 13:54 Go to previous messageGo to next message
Jason Weathersby wrote on Tue, 19 March 2013 12:03
Adrian
Jason, thanks for your reply. How would that work with patching the PDF by an emmiter?
Just to explain what I need to achieve more in detail. PDF files I am currently creating are generated on server from an external system that uses a birt-runtime with standard report design files created in BIRT 2.5.2 (upgrading to the latest version of BIRT is not a problem if needed). Report design file exports the xml data source to pdf format. The whole process is managed with a script written in bash. If there's any tool that would be able to convert the standard PDF file generated with BIRT to the PDF/A format, that would be the sufficient solution for my needs.
Thanks for your answer. I appreciate it.
Adrian
Re: PDF/A-1a and PDF/A-1b? [message #1022368 is a reply to message #1021235] Thu, 21 March 2013 15:03 Go to previous messageGo to next message
Adrian
There a couple of ways I can think to do this. First modify the source for the existing BIRT PDF emitter to put code in to add:
You would then export the new emitter plugin and replace your current one with the one you modified. Another option may be to write a program that uses iText to open the PDF documents and add the above code. I have not tried either approach, so I am not 100% that this will work though.
Jason Weathersby
BIRT Exchange
Re: PDF/A-1a and PDF/A-1b? [message #1023964 is a reply to message #1022368] Mon, 25 March 2013 10:59 Go to previous message
Thanks for your advice, Jason. Just for my info, are you considering to include this feature (generating reports in PDF/A format) as a standard function of BIRT in any of upcomming releases?
Adrian
[Updated on: Mon, 25 March 2013 11:00]
Previous Topic:Toggle between chart and table
Next Topic:Format Number problem
Current Time: Fri May 24 11:19:51 EDT 2013
Powered by FUDForum. Page generated in 0.08821 seconds
