Home » Eclipse Projects » BIRT » BIRT engine deployment
BIRT engine deployment [message #83794] Tue, 25 October 2005 13:50 Go to next message
VS is currently offline VSFriend
Hi all,
I'm interested in deploying BIRT engine into our web app without using
viewer example servlet. What's not so clear to me (after reading birt's
doc) is how this can be done. Can I just put some birt jars files together
with the dependencies (and some other resources - js) in my app's
WEB-INF/lib? Or is using the viewer servlet better alternative? What are
pros and cons?
Thanx,
V.
Re: BIRT engine deployment [message #83883 is a reply to message #83794] Tue, 25 October 2005 14:55 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Vladimir,
The viewer servlet handles parameters and displaying the html output. You
can write your own. We have an example of that in the examples section,
under integration the dynamic parameters. With future releases of BIRT the
viewer servlet will become more complex, ie handling cascading and dynamic
parameters, so using the existing one may offer more benefits in the long
run. To use the current one, download the standalone engine and deploy the
birt.war file.
Jason Weathersby
BIRT PMC
"Vladimir" <vladimir.simjanoski@gmail.com> wrote in message
news:412dbc5ed09115fa5195ca2d627a8fb2$1@www.eclipse.org...
> Hi all,
> pros and cons?
> Thanx,
> V.
Previous Topic:After report how to show rendered HTML/PDF file?
Next Topic:where is the birt example used in application
Current Time: Sat Apr 21 00:13:15 GMT 2018
Powered by FUDForum. Page generated in 0.01872 seconds
