Home » Modeling » BPEL Designer » question of possibility
question of possibility [message #746248] Sun, 23 October 2011 09:43 Go to next message
Mircea Cadariu is currently offline Mircea CadariuFriend
Hi all,
I have a standalone application that does the search (via some tags) and retrieval of WSDL docs from specified locations on the web.
My question is whether it's possible to integrate this functionality in the BPEL Designer (maybe mingle with the implementation of the Partner Link type - the wsdl doc could be obtained through the app's functionality somehow).
I want to find out if this is possible or not, before committing to this project. If it's doable, I'll use it as my diploma thesis and contribute my work to the BPEL Designer project.
[Updated on: Sun, 23 October 2011 18:13]
Report message to a moderator
Re: question of possibility [message #753786 is a reply to message #746248] Fri, 28 October 2011 17:56 Go to previous message
I've found a place where I can insert the functionality using the plug-in spy.
My next question is how can I see whether the modification is working or not? What is the correspondent of "run application" for plug-in development?
Thanks.
Previous Topic:Listener for tabs
Next Topic:How to get the P2 repository for the BPEL Designer?
Current Time: Sun Feb 18 01:01:35 GMT 2018
Powered by FUDForum. Page generated in 0.01769 seconds
