Home » Eclipse Projects » Riena » to change language after starting an application
to change language after starting an application [message #743712] Fri, 21 October 2011 17:29 Go to next message
atao Missing name is currently offline atao Missing nameFriend
Is there any way with Riena to change the language used when a standalone application is already running?
The use case is:
- each user can state its favorite language (it's stored with its other personal data)
- the application starts with the OS language on the station
- when a user is authenticated, then the application switches to the favorite user's language
- option: the user can change its favorite language at any time.
[Updated on: Fri, 21 October 2011 17:31]
Report message to a moderator
Re: to change language after starting an application [message #745096 is a reply to message #743712] Sat, 22 October 2011 15:31 Go to previous messageGo to next message
Christian Campo is currently offline Christian CampoFriend
Am 21.10.11 19:29, schrieb atao:
> The use case is: - each user can state its favorite language (it's stored with its other personal data)
> - when a user is authenticated, then the application switches to the favorite user's language - option: the user can
I would probably say that you can do that like with any RCP application. Since Riena has RCP inside, there is no
difference. However I admit that I dont know the details how to do that in RCP. :-)
If that doesnt help let me know and I digg a little deeper.....
christian
Re: to change language after starting an application [message #745465 is a reply to message #745096] Sat, 22 October 2011 21:07 Go to previous message
[quote ]
difference. However I admit that I dont know the details how to do that in RCP. Smile
[/quote]
Thank you for your answer.
The only way to do it with RCP is to restart the workbench.
See:
- http://www.toedter.com/blog/?p=19
- http://stackoverflow.com/questions/1431949
- https://bugs.eclipse.org/bugs/show_bug.cgi?id=222023
Previous Topic:submodule and foreach
Next Topic:uiFilters extension
Current Time: Mon Apr 23 00:20:53 GMT 2018
Powered by FUDForum. Page generated in 0.01864 seconds
