Home » Archived » M2M (model-to-model transformation) » [ATL] inter-model reference
[ATL] inter-model reference [message #743656] Fri, 21 October 2011 12:38 Go to next message
giovi  is currently offline giovi
Member
hi,
i'm trying to do a trasformation with atl. I take two models of the same Metamodel type and one model of another metamodel type in output. I've checked "allow inter-model references" but i don't understand a particular behaviour of ATL.
When i try to do this:
module mngr2ctxmngr;
create OUT : CtxManager from IN1 : Manager, IN2 : Manager;
helper def : counter : Integer = 0;
rule test{
	from
		i : Manager!ManagerState in IN1
	to
		o_1: CtxManager!CtxState(
			name <- i.name,
			managerStates <- Manager!ManagerState.allInstancesFrom('IN2')->asSequence()->first()
a receive this model as output:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:contextmanager="http://www.kermeta.org/contextmanager">
  <contextmanager:CtxState name="1A">
    <managerStates href="source/manager2.mngr#//@ownedState.0"/>
  </contextmanager:CtxState>
  <contextmanager:CtxState name="1B">
</xmi:XMI>
That's exactly what i wont but when i try to do fo example this:
rule test{
	from
	to
			name <- i.name,
			managerStates <- i
i receive this model as output:
  <contextmanager:CtxState name="1A" managerStates="/0"/>
  <contextmanager:CtxState name="1B" managerStates="/1"/>
</xmi:XMI>
Why there is not a reference href in this way? it seems that it's happens when i try to do a reference with the source pattern element.... how do i get even here a reference as in the first example?
Re: [ATL] inter-model reference [message #749851 is a reply to message #743656] Tue, 25 October 2011 09:32 Go to previous messageGo to next message
Member
In the last case ATL maybe applies a binding between source model element and target model element generated from this source model element and retrieve a ref of this generated element in the target model? If it's correct there is a method to retrive a ref od source model element?
Thanks and sorry for my poor english
Re: [ATL] inter-model reference [message #786733 is a reply to message #749851] Mon, 30 January 2012 14:12 Go to previous messageGo to next message
José Miguel P. is currently offline José Miguel P.
Member
I've been reading your post, and I'm having the same case.
Have you been any problem with the second type of inter-model-references in previous transformations? Do you know how I can force the first type of references?
Thanks you very much and sorry for my English.
Re: [ATL] inter-model reference [message #792908 is a reply to message #743656] Tue, 07 February 2012 09:57 Go to previous messageGo to next message
Dennis Wagelaar is currently offline Dennis Wagelaar
On 21/10/11 18:38, giovi wrote:
> *snip*
> rule test{
> from
> to
> name <- i.name,
> managerStates <- i
> </xmi:XMI>
Well, you're transforming 'i' into 'o_1', so when you assign 'i' to
'managerStates', ATL's implicit tracing mechanism will replace it by 'o_1'.
Hence, it becomes a self-reference. To avoid this, use the '<:=' assignment
operator instead of '<-', which should bypass implicit tracing.
Dennis
Re: [ATL] inter-model reference [message #793839 is a reply to message #792908] Wed, 08 February 2012 11:35 Go to previous message
Member
Thanks you very much Dennis.
It seems to work fine.
I have not found this kind of assignment at the literature, so I din't know thing about it's existence.
Thanks you!
Previous Topic:What is the best way to merge two metamodels?
Next Topic:[QVTrelational] How to use Keys to preserve graph structure
Current Time: Wed May 22 00:40:47 EDT 2013
Powered by FUDForum. Page generated in 0.01599 seconds
