Mac OS X 64bit Eclipse (3.6.2) "Cannot load 32-bit SWT libraries on 64-bit JVM" [message #743478] |
Fri, 21 October 2011 14:16 |
John Evans Messages: 2 Registered: October 2011 Location: Atlanta, GA |
Junior Member |
Having been developing a set of plugins for several years on Windows XP, I wanted to move to a mac and develop for that platform also. It has been working ok for a couple months with one nagging problem. Researching I discovered a patch for the SWT problem which required me to set up EGit and get the SWT code. Following the instructions (eclipse.org/swt/git.php), I attempted to test the setup by running one of the tests which failed. Error message:
when it runs the code test:
static final boolean IS_64 = longConst() == (int /*long*/)longConst();
which returns false because it casts to -1.
The commiter of the patch suggested I was running a 32bit version of Eclipse that was trying to run in 64-bit mode. so I should use the VM argument -d32 to force the VM into 32-bit mode. Confident that I'd downloaded the 64-bit version of Eclipse, but I downloaded it again (internal IBM source), but got the same error. I downloaded it from eclipse.org and got the same error.
Distinguishing files suggest that I do have 64-bit:
org.eclipse.equinox.launcher.cocoa.macosx.x86_64_1.1.2.R36x_v20101019_1345.jar
org.eclipse.swt.cocoa.macosx.x86_64_3.6.2.v3659b.jar
So I tried his suggestion of adding the VM argument -d32, but doing that I get this error:
java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
/Users/JohnEvans/git/eclipse.platform.swt.binaries/bundles/org.eclipse.swt.cocoa.macosx.x86_64/libswt-cocoa-3807.jnilib: no suitable image found. Did find: /Users/JohnEvans/git/eclipse.platform.swt.binaries/bundles/org.eclipse.swt.cocoa.macosx.x86_64/libswt-cocoa-3807.jnilib: mach-o, but wrong architecture
no swt-cocoa in java.library.path
Can't load library: /Users/JohnEvans/.swt/lib/macosx/x86/libswt-cocoa-3807.jnilib
Can't load library: /Users/JohnEvans/.swt/lib/macosx/x86/libswt-cocoa.jnilib
/Users/JohnEvans/.swt/lib/macosx/x86/libswt-cocoa-3807.jnilib: no suitable image found. Did find: /Users/JohnEvans/.swt/lib/macosx/x86/libswt-cocoa-3807.jnilib: mach-o, but wrong architecture
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:285)
This error suggests that it is 64-bit eclipse.
My conclusion is that I've really downloaded Eclipse 64-bit, but it won't run this test with the VM in either 32-bit or 64-bit mode because it always cast 0x1FFFFFFFFL as an int to -1.
Any ideas what is happening that causes the test to fail?
Re: Mac OS X 64bit Eclipse (3.6.2) "Cannot load 32-bit SWT libraries on 64-bit JVM&quo [message #748179 is a reply to message #743478] |
Mon, 24 October 2011 14:38 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Hi John,
SWT's source is stored in git in 32-bit form. This can be seen in the
cast of the 64-bit test: (int /*long*/). If the source was in 64-bit
form then it would look like (long /*int*/). This is why the IS_64 test
is evaluating to false even though you are running with 64-bit eclipse.
So you have two choices:
1. Run 32-bit swt. To do this:
- add the -d32 vm argument
- ensure that in your .classpath file that
CLASSPATH_ATTR_LIBRARY_PATH_ENTRY is pointing at
org.eclipse.swt.cocoa.macosx.x86, NOT at org.eclipse.swt.cocoa.macosx.x86_64
2. Run 64-bit swt. To do this:
- convert swt's source to 64-bit form by running the replace.32.to.64
ant target in file org.eclipse.swt/tasks/build.xml, and when it's done
be sure to Refresh (F5) your org.eclipse.swt project
- you probably do not need to add vm argument -d64, but it can't hurt
HTH,
Grant
> of the tests which failed. Error message: Cannot load 32-bit SWT
> when it runs the code test: static final boolean IS_64 = longConst() ==
> (int /*long*/)longConst(); which returns false because it casts to -1.
> eclipse.org and got the same error. Distinguishing files suggest that I
> do have 64-bit:
> I get this error:
> Can't load library:
> Can't load library:
FUDForum. Page generated in 0.01792 seconds
