Home » Eclipse Projects » BIRT » DB2 connections
DB2 connections [message #742553] Thu, 20 October 2011 15:45 Go to next message
marc.marshall is currently offline marc.marshallFriend
Member
I have a Birt project that I load my DataSource with a JNDI connection. Birt opens and closes my DB2 connection. When I stress test this report I have found that the DB2 connections are left open and my server locks up when too many of them are opened at once (40). Is there a way to manually force close my DB2 connection after my information is fetched from DB2? Thanks in advance for any advice that you may offer me.
Marc
Re: DB2 connections [message #742582 is a reply to message #742553] Thu, 20 October 2011 16:13 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Marc,
It should be doing this by default, but you could try adding the
following to the beforeOpen script of the datasource:
reportContext.getAppContext().put("OdaJDBCDriverPassInConnectionCloseAfterUse",
true);
Jason
On 10/20/2011 11:45 AM, marc.marshall wrote:
> Marc
Re: DB2 connections [message #742601 is a reply to message #742582] Thu, 20 October 2011 16:37 Go to previous messageGo to next message
Member
Jason,
Does Birt close it logically or close it physically? What I mean logically is returning the connection to the pool. At what point Does Birt close the DB2 connection? Thank in advance for your advise.
Marc
Re: DB2 connections [message #742609 is a reply to message #742601] Thu, 20 October 2011 16:48 Go to previous messageGo to next message
Here is the code for the close:
public void close( ) throws OdaException
logger.logp( java.util.logging.Level.FINEST,
Connection.class.getName( ),
"close", //$NON-NLS-1$
"Connection closed." ); //$NON-NLS-1$
if ( jdbcConn == null )
return;
try
if ( this.appContext != null && jdbcConn != null )
Object option = this.appContext.get(
IConnectionFactory.CLOSE_PASS_IN_CONNECTION );
boolean closePassInConnection = ( option instanceof Boolean )
? ( (Boolean) option ).booleanValue( ) : true;
if ( !closePassInConnection )
return;
if ( jdbcConn.isClosed( ) == false )
jdbcConn.close( );
logger.log(Level.FINER, "JDBC connection: " + jdbcConn + " is closed");
else
already closed outside of JDBC ODA driver");
catch ( SQLException e )
try
if (DBConfig.getInstance().qualifyPolicy(
jdbcConn.getMetaData().getDriverName(),
DBConfig.IGNORE_UNIMPORTANT_EXCEPTION))
return;
catch (SQLException e1) {
throw new JDBCException( ResourceConstants.CONN_CANNOT_CLOSE, e );
jdbcConn = null;
Set the log level to FINEST and verify the connection is getting closed.
Jason
On 10/20/2011 12:37 PM, marc.marshall wrote:
> Jason,
> Marc
Re: DB2 connections [message #753315 is a reply to message #742609] Wed, 26 October 2011 18:15 Go to previous message
Member
Jason,
Thanks for your suggestions. I set viewer log level to finest in my web.xml in my Birt Viewer 2.6.2. I looked in the ReportEngine logs in my Birt Viewer and did not find any open or close logs. Am I using and looking at the correct logs?
Marc
Previous Topic:Paginate on Y-Series Group?
Next Topic:BIRT Report Engine Installation Problem
Current Time: Mon Jun 18 15:54:12 GMT 2018
Powered by FUDForum. Page generated in 0.02248 seconds
