Home » Eclipse Projects » EclipseLink » command line tool for generating JPA Entities?
command line tool for generating JPA Entities? [message #742548] Thu, 20 October 2011 15:38 Go to next message
Jerome is currently offline JeromeFriend
Is there a Command-Line tool for generating Entities from Tables?
Re: command line tool for generating JPA Entities? [message #742569 is a reply to message #742548] Thu, 20 October 2011 16:04 Go to previous messageGo to next message
Jerome  is currently offline Jerome Friend
I did some research and found that other JPA providers have such tools. Is there no such command-line tool for EclipseLink? I want something I can call from ant.
Here are some tools that generate JPA entity classes from tables:
1) Avaje
2) Hibernate Tools
3) OpenJPA Reverse Mapping Tool
Sorry I can't post the URLs to these yet (because of forum policy).
Jerome
Re: command line tool for generating JPA Entities? [message #748480 is a reply to message #742569] Mon, 24 October 2011 18:12 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
Eclipse and other IDE's provide this functionality, not sure if from the command line however. You may wish to check the Eclipse Dali forum.
Since JPA is standard, any tool should work with any JPA provider at runtime, as long as it support JPA.
James : Wiki : Book : Blog : Twitter
Re: command line tool for generating JPA Entities? [message #748486 is a reply to message #742569] Mon, 24 October 2011 18:12 Go to previous message
James is currently offline JamesFriend
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Previous Topic:@OneToMany SortedSet
Next Topic:SEQUENCE table / row lock issue
Current Time: Fri Apr 27 00:44:19 GMT 2018
Powered by FUDForum. Page generated in 0.01452 seconds
