Home » Eclipse Projects » BIRT » Modify querytext of dataset called by inner table with data from outer table
Modify querytext of dataset called by inner table with data from outer table [message #742422] Thu, 20 October 2011 13:27 Go to next message
John Weber is currently offline John WeberFriend
I have a report with an outer table calling upon a dataset of filter data. I am grouping by filter name, and each filter may have several lines returning table, column, and values to match. I am using a concatenation aggregation to generate a sql fragment for a where clause like:
AND AE_P_PHS_E.CRAFT_CODE IN ('B-SIGNS')  AND AE_P_PHS_E.SHOP IN ('B-PAINT SHOP')  AND AE_P_PHS_E.STATUS_CODE IN ('20-W.F.M.')  AND AE_P_PRO_E.CATEGORY IN ('B-INS','B-AR','B-SR','B-PM')  AND AE_P_PRO_E.ORDER_TYPE IN ('B')
I am then calling an inner table to which I want to apply the filter. I have stored in a global variable the base SQL, which ends in WHERE 1=1. I have a script on the Dataset for the inner table on beforeOpen:
this.queryText  = reportContext.getPersistentGlobalVariable('baseSQL') + row._outer["Concatenation"];
This fails, presumably, because row._outer works from the child table, but not from the dataset called by the child table.
Any thoughts on how to accomplish this?
Re: Modify querytext of dataset called by inner table with data from outer table [message #742573 is a reply to message #742422] Thu, 20 October 2011 16:05 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Instead of using row._outer can create a dataset parameter for the inner
dataset and use the binding tab on the inner table to set the parameter
to the row._outer value. Then in the beforeOpen script you can
reference the dataset parameter like:
inputParams["mynewdatasetparameter"].value
Jason
> like:
Re: Modify querytext of dataset called by inner table with data from outer table [message #742694 is a reply to message #742573] Thu, 20 October 2011 18:33 Go to previous messageGo to next message
I have added the parameter, param_1, and in the binding tab for the inner table, added the binding to the concatenation. In beforeOpen on the query, I have:
this.queryText  = reportContext.getPersistentGlobalVariable('baseSQL') + inputParams["param_1"].value;
I get the following error:
Table (id = 9847):
- An exception occurred during processing. Please see the following message for details:
Cannot set the string value ( AND AE_P_PHS_E.CRAFT_CODE IN ('B-SIGNS')  AND AE_P_PHS_E.SHOP IN ('B-PAINT SHOP')  AND AE_P_PHS_E.STATUS_CODE IN ('20-W.F.M.')  AND AE_P_PRO_E.CATEGORY IN ('B-INS','B-AR','B-SR','B-PM')  AND AE_P_PRO_E.ORDER_TYPE IN ('B')) to parameter 1.
Cannot set preparedStatement parameter string value.
SQL error #1: Invalid column index
Re: Modify querytext of dataset called by inner table with data from outer table [message #743854 is a reply to message #742694] Fri, 21 October 2011 19:37 Go to previous message
I got this working. Two notes:
I needed to add a '?' in a dummy expression in the where clause in my baseSQL, or it would error out on having a parameter, but not a matching '?' in the SQL.
Also, it would error out when using inputParams["param_1"].value. I had to use inputParams["param_1"]
Thanks for the help!
Previous Topic:fonts in birt generated pdf reports.
Next Topic:Run/view reports/dashboards on tomcat staging server.
Current Time: Sun Jun 24 18:41:36 GMT 2018
Powered by FUDForum. Page generated in 0.02173 seconds
