Home » Archived » M2M (model-to-model transformation) » [ATL] metamodel element uml::Class not found
[ATL] metamodel element uml::Class not found [message #81262] Thu, 15 May 2008 12:35 Go to next message
Deepak is currently offline DeepakFriend
Member
--------------090207000809050908050706
I am ATL newbie and interested in profile transformation.
So I am playing with the ATL example "UML Class Diagram to UML Profile".
The transformation works fine when I set the metamodels path to
"uri:http://www.eclipse.org/uml2/2.1.0/UML".
However, setting the path of the UML metamodel to the local directory
(see the zip file containing no.jpg), the ATL compiler gives the
following error message.
The metamodel element uml::Class exists in the file uml21.uml (in
attachment available).
No matter which handler I choose (EMF or UML), the error message still
occurs.
INFO: /ProfileGen/Transformations/UMLCD2UMLProfile.atl
SCHWERWIEGEND: ****** BEGIN Stack Trace
SCHWERWIEGEND: message: cannot find metamodel element uml::Class in
model UML
SCHWERWIEGEND: A.main() : ??#22 null
SCHWERWIEGEND: local variables = {self=UMLCD2UMLProfile : ASMModule}
SCHWERWIEGEND: local stack = []
SCHWERWIEGEND: A.__matcher__() : ??#1 null
SCHWERWIEGEND: A.__matchClass() : ??#2 null
SCHWERWIEGEND: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to
allow continuation after errors).
SCHWERWIEGEND: cannot find metamodel element uml::Class in model UML
java.lang.RuntimeException: cannot find metamodel element uml::Class in
model UML
Thanks in advance for any help !
Deepak
Content-Type: application/octet-stream;
name="att.zip"
Content-Disposition: attachment;
filename="att.zip"
UEsDBBQAAgAIAMydmjhXqCDz78kAAIsMDwAJAAAAdW1sMjEudW1s7F1bU+u6 kn6fqvkPFPM2
VSwgi+uuveYUhgCBhASF+0vKSZTY4PgiO+Dw68e5QRIsWbZailnh5ZxT6xDb 6q+71er+uvXv
f8KetfaKiW869p/17V9b62vYbjlt0+7+Wb+9Od04WP/P//33f/3b71n/VJw2 ttbCnvnPxw8K
v7bXo3+xbP+f6N//rBtB4P6zuem3DNzTfzm97i+HdDd9F7c2HyqlzZk/jx74 8edvb2+/cMsy
XR+P/j76/wrDv/21tXlbKa+PXmm2/6w3/LO2UzGqO8V2AZdrb+jgolC5eltf s/Ue/rMe/Ww9
+ta1tX9dvfWid3G7aOEetoPRA4KBO/6bf2rE7JmB+Ypvon9afHpIe3rJDnAX k/VN0VdcabRX
aI5jYd0GeAWivaIekAhagDdQUbi1reHPcPtKD/pEt/jedWzpvr/4DioWx05v +Iwx2tGzu9jG
0avMdz2I1HL+KdUYcU/+fvIXta9r2Zw+2XmzcfsoiKTW7Ad44clUKTed9mB9 7dX0zaZpmcHg
z7rbb1pma31tvGIaSJO3Ru+1nDdM7nSrjxcEVY5EG336VBsXvoixks35pXAt kAqAbttOoAcf
aM4tLEaeaxG6TsscwTP6K9vssZbfd13m8r8o2fyH12Iwfx0+7c/6/35IJLOU ayidlP/dXND9
rAZRoxrdBwymf9T0A6K3gj/rAeljLhOphQwoJj+M/zyD4M6fddxyCP4V/fP/ NPySfnnCks/8
d/Bo4TXVX45+xauBpo+w3q7a1mAimehfTjCJ3Ft7+g9fldQy5CnpNZKppNew ruA6ZIFAliD9
bGJBGqhYEGLq5nSfmnP7MZLUu12Cu5Olt5ye6/jRImJFEspTSGTIVEgUppa8 jf3oY0euxuyY
mKSIT+pUp1Gs6G6jeKG/6tXmM24Fs/97RpYB7rlWtMNppj0Mhheezti7ot/6 ZtceSnhRPgi3
cce09aaFbyaPr0//dOpLXT0wevowKo5C30a5pKEjVCrWN4tDHzu3Yv+XZTaJ TgYjzztc1kZj
JMevz96c/TpXJ5EgIqTq/WirMIP+1w2hbrDWFz2j45Be/J4wAmr6BbXpq2Su bvLvH++KzjCb
818b7Yb9L1+7oD2C3zejQ3PC3oyVdlo4wu8Mx/b3gePfzQWz/3BQi65obnOo Rm43Jqy6ofqg
KHgeSqnhY6sTe074/KJ5YS68AMVttFXSxuRzW22bJBLDaAchOALInnNVQwCk IjF/phXaQW7o
Ic3HHvIhKU4JUsOatql3bSdSkZb/VahKJXjy8SXHhm6CSPJWA5fkLTUSajnR N4TzQVDc9swS
csZlZlCYyT9/mDSPod9StcjQ/cYkQM5s5XfaSln5HQLXzTtjJa38LgSX5L2W Pyu/R2qs/J6u
RVFwQJyBgI3fx3iQrya9KfD1DxrDR13iwZtD2gILeIhx/7OHXi3N+pLeRQXi ZboOdppVSI5U
X9/FwUSOvoAgHzW2IBGPIGeNSjAp8MiXpcpsvY+K9uhHei673RbX/ydNnf4/ oSXq/xPV+Aju
Oa8YQJShOlHq2hJFqSOGK7nCOom2ldq4SCAgTt1girNgpHUo2excD9XYeVNj CHVUwRaQZZO1
y9lmC6mRZVORz2xSfabp16NHY2f4wUeuG0lwmNQUkGxLof9sUe3O/1jUHK4n IajdtwwesSLs
9aMVinjSlkJP2taWK9Q24tZVIZm2DYUyDZcrU0zFVI/kOKjPfERmeeLUPjPm KE6vRp/ZD/D5
BGwsGReqXvRtOGQ62vdDprNk194xGNHH50b5iY/IUbETMqORk1DxUbGryT0q dhUlerppQRTA
sAuNYTbRGvAFAYNqil5ft4ZFtEiNeljmActgAfklgB3+XsQcjXCZ/lLcfE3J 5msqMl8zNeoC
oJvLBj0bFs/w9v685K33mQX79DAFs/E+52zjfZFsuS+KLPclHYQCCL7kY9u1 4M3QWv62ayXG
T1CGaOXMEHuSDbGnyBB7qRAUALCXDzu04e3QXr4d2jwoDmlwEKZo58wUHcmm 6MAnL5wlp5Wc
MKW+CKiLq+XC8F14FF1AFJNeFS7dx3gsWskIDgEl8RSSSjx1sHlU2FziRGIO BrJRI6wiqShq
BCKjr4YOns1pEHgeMgmVaZ+vLVv7fHqmQFz7fAPQKfjqYAlAYUl6GRUBG7+N EVi+fQKeZwKq
c28RrAe4eDTuZxbLBQZyc4H6hQ0frfTpZXunT1pS/UAfMdM91jgjb5iuyLmk z6zXe1ea4nNJ
P5R7LnnV1KQIXlWA95oz8F4lg/cGn4d4o+KEx65GoDZhK9K1N2ZFZ+SnTkaw 4zaU5r0xqVNe
2VCseaHkdEaoKLMYqocyzBmUA8lQDuCjhIHx/Z3IgJXdutFJ9J/Qmveu5Uvz 3iX3crwr4iW/
q4dyK2dQbkmGcgs+x7EVfn8nsk1nxFpWdWYckYiubbPTnjXVurZtyNW1bUWt IQUqeL2+H2h4
hJ8AbgXIdHXsAsEmiRWoG/q04YhnblghTBit51YZFSrWk38nDe1z37M+GSU8 2TvWso0D/G0w
Z0HdzOcK215cuS95KJYRM8EKbALU71DmBKgd2NlbO4iRMe2Y1jzDbyZJG0cS 55/AZUqcwLUj
dQLXTggq/116xnrsQyqYdOfT4zG0wxSSf5E4jG9X6jC+XdhhfLthguTjhiLG ecw0wpeo9ntS
x3XuIVDh7xn02slwRtRHx25Cky3P/EOJI1L3pLr6fVhXv49YMjftriqhZ5SG oXL04X4oc/Th
gfZ3jz48QD+jD3M0+vDA+Bl9+A1HHx7Qcz2T/EhjfLRuOKThRh5ZD0RIH4er NSLtED7Df7ia
I9IO4UekbaQakRa3WcOPSNtQVN3bSODZjDJsk3xUZmPfYNXzwttnSFZogz7C FY6N1WCMrphO
80/KJIrwcBo8qBXtfm/yawHsGswuAaOL4LBzj0CwyyBQ9whxCHTBN2YVqXtk MEUahpAiDZcl
Uk3jEOnQ+ZGO3hIRp8Yc8dTyIDVUM5YmTsZkp9pM9lSkHuIeq5vp5B4nJYPn jGIAK81jgzkn
pzb9guyS/N6jBdwTuZQX9wQ8IHZPjCUq1EnSgB9xlSpq31ulinIJEG4RnADh FsMlqtSpltzc
N9EqgeDcPWVun3GLkspdcE/lchfcUzXcBfeMCZ9lwSF4ljMEzyQjeKYIwXN+ AxRA7xwavWxC
PYf3nudLb3Z1S0ogLOUDwhI8hCVYCBPedkFFKxJWn/hYYk7FvUBsf137QlER 8dkXzBxALOFF
qs++kNsn416qoXu6lywUazEso8wIXkIjmFGw4Plwt6wtMeotKwOwnA8Ay/AA VqAATHoPWqK/
rjBmco+mxpfHlSgBDamEsunBCWukXzw+WpOFK7jXxERkI7piUqBjKWhSN6Ir yYeHK0WHhyqd
uq6/YP9ujJ8AcFV1o1bcKr2bzJpTl27K+UZQ9HiXfvH5MD713VGJIctV224t kdjOWjSDI+fW
2FcRj207SbxZ7mlue015PEW3JpMS7dZAKdFuwlXlqD+/WbbiCgfclNxWTaLY pV5O7sJeTu5e
J7GNSpEUSTAXp9yIUNENXaLokUw2tItA2dAuMhKo6DGi10W03uhoEkUvkxTt 1kFJ0W6d6vB7
0nx9JH6Jml+X6uvrsL6efruzOVL52C33HQwGee0Y7o1U33+jkgzv3sgkw7u3 fzcZ3r39IcPn
iAzv3v6Q4b8hGd6lXw8+3qj9RtscdTH1Td8Qu0fPXa3Lwl34y8Ld1bws3IW/ LNxNdVl47E4N
zoR3FV0W7t4nTZycP5hmtvd7NqH6BjJvR79CHPO1G/O+BzHz1CMxzU1S0GFr AQ8J2NXmT7aZ
sXtgY6cDTrJ1H5Oa9RtJvbO8L1oyeI+sAXOlyclMfEiP+xjmq9LxJJli+6TI cT7x4DexQBH8
Em4ZLygesuTqkvHTFeGn8+AnXmjUc2Z+TcnwNRXB12TBNyp+VTvTvFZm8JoJ lXDVdKWWZPBa
8KeUlpEmFuuCXhTjtpIOtEcEn4AdadvaknkTjKvFR/5M3JuxLxVX783akvl7 GHzOtYtZIPlJ
4gSUHZZMOcGKKCcd+mkvbFn9Nj52LCtSeDHmaidnhKGOZPQ68GmWrpYTze9K bsnqQo0XBuMJ
dZk8oc8pbJmoQkYSVShuEiwXVYh+NXfLMqMPPsEuttvYbs2d1N24weVfyUBP EgvEhtQCsQFb
IDYT5g/E+MyEKFh0gSYs94N+0fZsqoe9zLj0j/AyYXF81ji7VtIDylH7FxXG Myzmz8yRBRNm
5IzPqCrhGGYUDayevDDtvRi6BPv+/CzaaFlCXKi6AS6UF6SSnkG/8RuCnvES /t30DEv7oWfk
iJ5hoR96xjekZ9Cvqzd0v2E7jY9tvkEN3PhOala4UuSMHnyWp4dWkpzRg+/F 7oVpyBlx+zQ8
OUPRLS6ujVgWD2butrFS5m7Dp7YcbSXN3YGvFzlG/szdUZTJdrXkPEXDxrjt j2IiMrwrTMDs
XbRSZu/C701uuJJm78HHSx7Kn9l7am4JdL2QTeObzXJnNnbCLE7Hpswzc/gI FUy/Pxo+RGQW
/QmLGVLWm8Pe7exihGaEZFNNX1EA6iOJsvSNfMgSPhwMqBu55bSGVTSpI0KC hKnOt/7oBprM
uAXsy86fIOnAQbhMV9JnzVG7Tiyq8C2xjwDMQGiV9KnAlvUxR0KEPNFnkyCr 4ukmwXrtq2Ri
3asiVuQrYzrQAtHtlDg9AUhfQ3VzWN7oBSte6096A/3eLj9JVUVM742Kl4+H qeXAEaGvvoVL
9ixhwi3EnxeiiXiXEOWLIR9KpmaFYd7oRQMqzjNnFx4q0QBJuk7XHRhJ1+mW M5KUBsIhSgyL
4FHi2IR3ns0uC7HgPYGulUEOMkla70ZWOYAZznuYcL31cKcWY+dtCQ3yYj45 0Vi3aCYFJsAt
xv3gEw8IIMJQFsFxmzWHK9odYyrtMyYUd0X4VxN6gOfebMNytbapIAYQ64cn ZG1nJGRRwqQC
nRjtHzs9N/pJpMP3ZmAIREkFhYMTC/RhW3MAbhmg0XSBcVlQjCVlFuVv6Y0+ YP7xN3VL/ioQ
Hlf425DlCn/Tw6hPTtuM7hwYPMavZRxSucNoQ5/IK/7y8i0jo0/i+yz27Mxa hm/j5HBK2Ud2
YMcr7tDLcbij961MSIXgq96FHa+3y9aJE96lcyvCI/yGuqt01tqu1Flre3/5 rLW9n1lreSLz
7v3MWvuOZN49emt63w8aTdxofUT+AqHq/mqNWduHJ6Ttr+aYtX34qvhBqjFr u0rGrB2gvOXS
D4ykE9vn1s1zYjuQlrw6TD4jJaZrvviimCOcxBTwIZKUCj80+A5qGQTEHadr EmsIh1IHkG/A
npA2UFJ+cY7AcszVPv7A+EaBs8mG1EbDjb+80bDx02iYp7NJ46fR8DueTRqs zauBxWdSNlaq
v9A7AufLe0cr2V/oHRnwkkzVX7ihovPA07RlnkqOPmOdxe+K0brxJL2iTT8V rI1/S81TjeGJ
nrDwMvasOc76D4JkIDAkE3JIxoiVTFzlazPj6TE2dp0/PQrTIbxjJOlE6R0n EgEm29tcvH6K
RKoZ9/JOSd6xzFOSdwJ6SvJO2HWkmMA/yRr5S4vgs5W8EwOSouGdhIm5jhnD EoiNvCK7UWtL
MZvVK8odlucV1XTZeUUOcogAbKffhhMS6y/n94ipl+XZDU5lEWu9UymMkKx7 01lytnP2aDa3
Q11rQjuUIW+HOpN5hZp3Bsrv8M6oCtF0+nYc5YUzl3cfysjleeeaxFyed47+ 6lyed2785PLy
k8vzzsOfXN73y+V5peRtq+HPfEZjDKNAJFRaqbEiXgk+JVVaybEi3gV8mvQi zViR2P0aPrl3
oejAc0HVIsfGjXjrFzD7y5ViGnmX4Ewj73IlmUbeJTjTyCtr+TP7ct6YRnHn 8mnX7shMcRth
a/Te8aCxTMnichL9yGNNP2GdBitUkH2nT+bHe8dlpLON965KPIxXJLGRvAo9 r66TLg7kiKqm
SRRVuOze3Ti9nQgVwGyupNVYrqi6QIafHds5BGg+EnXiSq1O0IuBMYtcLAbG wDAuk1ZRyjJp
ldnXGaulXLBIKZPGeM8vkqlQCsjVMK1kmONPYrc/Ln8vRTI1Dp2pUHSmllZn aghAMjVFOlPj
0JmvpYKJZNLqTI2tM6dIqMQAtvdca9xtvXNFCZ6t51ra1nNN3XqmSafUzf13 GYPHa+rheJwY
zNApeicxMkSSRrZ4iF30P+IUBn8tS+L+j2ReuuUh0Et4vLoGRnXhKRhClLPq SGY5q2783eWs
evhTzspROetG+ylnfcNy1g1S0Tbr3azUjRjeDXwK9nYlb8TwbuHLArdpbsSI 3aThk9m3YT4J
6nccp+hryin6Lu0p+o59ir7WhA4w0JLhOEVfU07Rd2lP0XchhGQUZV7uOXTm 6zFpLJn7tDpz
D6Ez94p05p5DZ84o2bq6lq2pgfE1yS0WMQ0EazTmoODXPHBozUm81sT1I4t+ DUdjzjal/WQH
HKmHZL2JmWS2RpuIKfo1HK05OxTP96iltO9HNnufc2JlqMa+Hzm0Zpfi+R7T tnM9GgCSeVTU
zvXIoTMDis48pdWZp/RX83ANjJYimScOnTEotv2O4BrdnqhR8fh6E55M91MS NyFO9gJSLdr9
3iT4XViNTj0t3X0cYS+j4/O8Jk1C9IVHUU/IkxPwJscz6PNbifk6bJTheQi9 ZYo4wYhfwvOY
JoPAOhK2HD1vcuh5jaLnzwacnjepUNQDYtrdmevaeVS+mUjHMbVM08C9VtKc 8bheDK5aTYtx
nVhTznX18kYOeS2pVYoWbJWinTCfPI3000k52/LbSOEcUa8tc1aP1/67Z/V4 +GdWT54KIvhn
Vs93LIhg+qye4Q/stkgvOl6tOT0d+AaUzmrO6enAN0V10szpid2a4csgXTXX sHpdVgSMP2Iw
EVPvrlbFswtf8TRWs+JpwFc8DSN/pm7k7dK9uIP69PSRLidgJhE+vedst6h4 Jv16y0Gv6cR3
GSdcUSl6RDRhT8jPWkL8NaerzyHghF/bQBJnVz1LnQzynHIyCJjVPFPDiNEa 6i5uRbF3a5IS
zNS786JJusTSe0m0VDuJmk2JMF4M9hVk/UAXY1S9hLLnIyWs0KJfsjbW0BH+ Aiu02BesxXWs
Aa+QimFzHDgJr3DZGPboLZ+jZLjoAntLvord61Eh7E+9tfAaE0A0ZK/RZtx2 eNW3REaP2Ojb
DGGz6dc8RL9ri03otEORO19Z4Y5Db1sYnU9mYh2HqwiA4CM8By0ptnCYmGbE 0glFogkWlm5i
ZTXpGvXEht8IX/jRni4CHe3p0k+bBOsBnqsRZ3ZNLpsS2Tfgrl/1PCqw2G5v l/wr/dXsjuM5
tnfkfR9ive/o8zgz8z67U0CZ32ew3ncV/a+kbZv3RSHrReWh9ibFeJxvIkzI bodHuaRtmvdN
TLBuOLw474tYKBXgtZCwwCrAa6HPgqwAqIU+C7ECpBb6TMhSaWGWyNCnItjF wYwbFslzBxqA
HwYcrxxIHq8cKJo2FrDKM8PSsX/jCMDW15TdXu716T3RgTFvASz3KPf80Kea 6my8whNg9hMp
YfsZ01WvmqzZT6/stvXiXNrVfrINyLRr57fEtOurVHrYK2zy+426BX5QJTPg 8EXeuxInK7xJ
TXO/0dEsiEmeMc1+ciZLLq5kNL6QFfjwBJBfMc8wS8o2riXOkghljWILqX7b nsbDVV4XFiMS
iZYSSr3MZKCpZG4OpI6yGPzloywGP6Ms8sTcfP8ZZfEdmZvvdFLXsAg9jKlx uxFtqQ27Pwym
BE5P76tF7nqHJ3dtrSa5awue3LWVitw1UDLOYitUkyTZ1nhNfvjhImmu7dW6 hGEbnm+8vZqX
MBTgOfAFlD+LLyhKixboV1ZFkT4ZNHSYtPbv1bp94Tf8vvR7NW9f+A0fK+1o +bP3HaTG3neo
WjRj6MMdXsTYd1arLWsXfkvaXc22rF34MGk3zJ+x7ylqy9pD9CS8NtreBYx8 z1gy2XaPVY0v
jjP9Il5sn12Jd8RzFoIJ733Jpfl9I28tRftUyD9TWxlpjAeJTRHVjFXmg4Sm CPsJo4xPTrza
mFX+Zz45lDUs5ZAafHXw4pXJtn6tgdzrYutIYuHpUGqJ9hD2juJDRmF2ajbS KrMbGt1lzyrj
HANuT+Byart7JpELsSEV+A1Y4Dfo466Gnzf8qGIYzF+sZHcaPGXd7pnEeUQN TaaQGwhUyA16
m5ptRD4qWmUFj4slMxP0uiGMl+ueS2QcNGSW18mRBokDOaJGvmRcxJ4ths2F dXEhRoyg5W0n
5MiQKmhQhhXRkjx6onA51LokT62JJtOHE82AlXbImLMxc0nupwPvlkQGzXUv JUr+WKZjJ8eg
jp0c0/Nm0x9wMAkzuPRLJBEBqS79BNalnzBc+nCcRBS5fIkdu5dc3nwbvMeP nMAa/gkji2VZ
etMZn7ZvfZy8fG7j35YXOpOiVOMvwhp/0WCyuSOpH+sLko+rKfLPzahJDC+K Uo3+FNboT6lG
3+cV+lfhSvSop1Jjt9NQIQeVnGkSOaiEdWT8Czio5Mz44aDmh4NKzsIfDur3 46CSc6oPsp1G
a9CysN8w7cZi9jBrzYecrxQtjZyD11vJ+UrS0kgJnANASmloabG7NXjlmpTU 0NJIKeQrFDSM
yJHopBX9l0Cpl1ysFDuNXICz08jFSrLTyAU4O41cavkz+0s17DRyaSTzz0fU cwFbv1wpchop
w29M5ZUkp5EyfLBUDvNn6xU15DRSod+UrLt+I3AWovqGjwMBs6+sUouZ/QQe j0aPXEWzj5Zt
wEsyd2ZvP10oMfvoPYg1Q8myPjKY2eP56CUsbmp8cU4iUzP6nlAmU9N+ulQE 3iULvI/fiCB3
yUSuWVaN3KVk5MqKkCsnmB0IeOWcgVeWDF5FEXgVLrMTAK4CDVxGeYbgW+0V PYHMMQBRfElX
CH5J9MtPpz8YDnf00yxO0NCuJBtaFT6araJEKU4aSNg9H4BSrBqSpRiqcVc1 TbK7qqFcuKsa
/MmgFi7XXV3DG9o1yp27upZsaNfw+xjScueuEJIrRQRvXoje/NK1HbLIKGI3 umTwjHWWZ7z1
cXsoCdLRW0Kn3zrTPbY8pDgMr0s2t7qife1GY5+hwAC8yRmAN5IBvFEE4C0L wLNxtlkEt1vm
9S6x3Q9ScbuVjNutItzuWLiV5hurRPC7Y+IX26YlFb87yfjdKcLvnoqfblmn 47ZfEdzumf4y
tolYKm73knG7V4TbAyvoxHYggtlDznzl/7N3XVvN80r7VvYNsD5KaGv9Jzj0 juiceMktMiR2
igMOV/87hbyEWMXWSDEoJ9/eJ2+wRjOjKc8886T4zp403dmzxZlAHUKn5V3l c8Vc5bPi63uG
T+le6EAfninI5CAv1Hyc4N7DVB+uAgnteCG6tmFkf4teMuGppIwYsaVwn0j2 80ifBDER3ycC
rIw45XgrCRE6VrVclKO4XuLA10sc1vX0eOIElJ1rqZWdi/S8zi6hg54Gt1OM 450MxDH7K6k+
5+Et5hXzECOluJaOTj1SrejUU9xg861qUX3lcmJNLvjbCKDMFtrsTxA1W2iz X2aQLJ37OFBE
sBS9BBaX92Qqs2+AKB/BsBW8tJQNLmdnU8jUkf065MB+9nMp5yLCodTqORSU 20BkQC+Rpe4u
GpbKu2ggfXPO2V8j6uacs19P//Kcc/RCrOWcc2XmnLPrQMs5518355xdGxF5 LuwJPNzOXG3o
SYS3JDVqGCKER7WEZg5DhPA1hrDAMET+Yw0/DPGqCdj7ikTNvhf2xtycpW3+ 1awBqFf4gv2b
ZaTNv8FDmN9I9Wz+TVODrklv0PXqU0N/DBMiYexNje2DJi928X1esUGmEthk 1FrQfK79IBk6
tSx9km3xWWylJFuqWPd9ffuPz81RhOmebWqB6n/jf0tNk//va2P6jz+WMkf8 fBEquLwv/k+F
ZHJKMfOSSfMlE6GCkokQgGQiC1IyeQXeiOo2rrtxpqbJQKiIG3E2FUS43N6G 6CW2eL/cKvvL
vI0QeI2U/GWiZm9D9st0Xiec4GR2q3oUtC0BLQs+LGDi1eilbYHWcdt0Eqax Tk/PnN6/Ci2r
mJcCk2e1pBRgq9ltxhs7qUMra2l0LO7fvo9o80QgH0BP9f0A95sC6zIQn/Zc 9sY7sDfeod74
NxZbzsGjYB2VE3mXGSNPiXOLX/ic2MU+hx+HTd8sHs/AvPlvIHV9mi5R2afp pqA617MYNMth
1JiJr751zPpiYob3sj0Ee37CcTSjD5w5+qsMwXdQg39+e7AqkdBVov11Li7r Pq9TGtQIuBwS
WNVICGvxg58kUh5oU2GnOElVeqA+bLTXRwLbUUv4nk14BevDvvd96nvf6We5 xo81OTRL+1FN
FvdEm6k6DXxXilV4hzX0d5H9vFnKX8bK4R/A91QnUOPDUgnU+EB/G6jxsSSk rxJQ42NJSP8b
gRop1Qe1sgA9bGc5aJaO2nFgu8w8VawBkCKjerYpPLogTY3s2Q7gES8DVKRn +6GFtHJA9PRs
Bykn/crcyhSc9TX/JWH3n5ZRdv8JjzD4JEba/Sc86mXVqp7dr2oa11rlQhs8 uz2pu9jTDb8S
hr9qFjBzDf6ZWjMTmLkGHzqtpdUz/HVNwMx1JPDgd/tNKdqSdbMQmevwb9OG mYjMDfh4aYNU
z9g3NCEyawyO4PewMSzt2V0fe3HUHEiYe82sZL4G/yLVzEzmN+GjpM0KJvOb mpL5TboWjRvF
dn+IJ7LDnu0xsE1igt4yK5Pfgn+ZtszM5Lfgo6XtCmby25oy+W0ibPTDp96W fOu3zcrjd+Bf
qB0z8/gd+Khpp4J5/K6mPH4XcXFT/wp40ZiGvrTR75qVz+/Cv1ArZubzK/BR 00oF8/kVTfm8
Tdciv92MB8MBJTvB3YYvM09tm5XO2/APk21kOo/3wIMlvFe9dB7v6Unn8R5V i5wx3me4ShZ/
wRDLGzy2jErlsQX+KGHLyFQeW+CBEq5XL5XHdT2pPK4TxjaIfcZInqBoOeSp SMtyMbyvJ0PC
+4g+ancLIc99SC7wUiekg7cgzncAyPiAD6i3Efkf029lq6OMrA4IQ1YnnNlL wSOmgPI6tBjy
mvleZUu98CFiyOyqLS2wQwIpsJQhsCvBmToZaR1Rb6wfgdjjEVLtUI7YRnL5 1TSWOQSkkRwz
pqm/faw6Czlm7i8e7hgYTTSVltYx9Lr3ck/2sZ76Bj6xGPo3yQD2ZyaGS0v2 BAHq4QnVbt5/
DjZDa+AJKwaY3CaQyE4h44FTJC6yC1CGfXzK8nK3WTodNaAkBunszqwCSgYb PJ2xAoGfQ6pA
sjuDDA7O0gKygw0Lzlk+7bLfhJLXufLo4JzQX9s9gDLUub7lHviCvgBOZYx4 wYwX5CPqC4h4
QeqAaVl+G7EDXloLzrkvBfDT0+UH5Y/J3tISE71bWvCl2i0t+EpTTegKCSUM pe/tSnlJCIql
MI88cCKKLATquyMtmGwwLbeFBl9zaQZvrFJkgPga8cgAI1Lylwnvm1G5zTn4 msnmOmbSK8/0
BqYWN9SHUU4ZbnjMkEyOV5ZgbxhhyW2SfYqrikAP31DvNBgJa/gWTIfwlezC wUjdXiKMVPLL
YFSQXwaWuTZPcD+Ya73Obj6nb969/1fW4BBVhy6+8S5I7QPDtxxP7MXXpJwF 3DIe1EkbTpn1
3TIM/z4KO31f3Z+mXtrI5Ph/lyjnzcR3oAxi+I5606PP4x75ItVwZAJ7ZPYt A5MW4iY4jRW+
h9WBe7YOQAukheAFQjTyeuH7VCGvF36w/jSvF35AS16v6vB64Qey5PX6fbxe +IH9iNmNxF6V
qHg8moUdfITHDj6aiR18hMcOPhXBDuY+zvDYwSdN2MEnwgzN7IYvZeZPRo39 4Wd4JPuzkWN/
+JnASzKtnpm/aGpgvCDOa+7b9HRcTLwvRg374Rf4dwgbOeyHMXxshEn1TB1r AsM5bLyP3Wv7
bpYFuKN/akex3Qs93/aDIDNMiWFf7Bg1/ocd+AfKMXP8z4UPmlxUPft3NY3/ uWkR+x9uUk6w
zB5l7JmVynvwz5VnZirvwYdQfgVTeV9TKu+z8MnnktG9DwlJDlhDSpMvVYfj DpioZGofVvBo
kPDjgDWbNPlSdQjkhsUAncrqU4O9j/siVQ3IbLCGZmW1oMGBJCvH0xLGhNMI HzKKBWRGjAha
MKKW0GEckdvse36vjrteGOHh4WQOqhFeHlKvra7SI4aIJ8rvmCIJWYZEoyzp AKmZIADByvLV
YhbUrbgvNdn3umi/+UqYlUTp8y3ac74xIshWFj2HTtN/DBMiccY3pM8K3qjX FQ/HTFVawhsD
uSwhvaalT3pNNnDJGSu7mGPm/Sm2XRX6U3ATAHQcbA7q7AcONg8IN8bBtqgI pLGIsl+Y/WMt
1p3nY2GFcHL/qZBMDvxsTjLziLiJZEhRyRAAybSQ6vGAFtUX1OMoyoxzCCuT AytHlqrhjog3
NtJeLQmDjqhG789uNMVtkeq6AO5/Td1mYxyp3GyM45KYVMrrFLNGKjMzk3mi YrZRtpHmMbxY
8RheG6qLDeZv2ojjb+IRw4aI9beVjXa1Gbz7QRiFUUNkr3Gp8Z9P8P3buAOL Ge9Qb7CNu8kw
Ar+Ou0nxrc941YI/Ouz8QIeqF914hpcm/13NOTLj+yRg6l2V66dx92+vn8bd 5frpKsHUu8v1
078Rpt4TWj8tEcv1zIK19OBhLT0zYS0JPKwlKQRr6WohuU00wVqSlBUP2h9Z QGi3s4jQzpyL
lMH3zYKz9OHhLH0z4Sx9eDjLu1U9g3/XBGd5J6wsyMaRZ89avoTNv5s1pvIB /zR9mDmm8gEf
Ln2k1bP5VNOYSsqAZjUDOHtPzZpVSeFfpoGZsyoD+GhpQKpn7wNNsyqfFntz xb8ieGlT/0Sq
qS2B28efhN8+blMa659pwfbxZ1q4UyXUTFDSWM+p3M9JpkNprK+igpJZRQCS WbU0SUZAZzoU
nVktqjOrEDqzqkln1gR0Zt4HjCWzVlRn1tg6I9asWVPO1bhGfXH2p+sA7ybb AEtBMdZSHmCi
UbJlui6wyXBG5jUiwSQVqERLrCOVaIl12JbkesqW+1T9vkPU2p9AbJXBGlJ3 DxtK2So3EChq
ZYO96mvmKmQQLBtMGG7uxSpFsNQstQiWGqoagqUm4KSFnHGN64wHJdksNy2e U9jrJmGQvR0z
LnlL6BncVmjym0pd7yas691k1YOCsNHvTuKebyLeluFPDFZTdaLfUupttxCo 6LcY5EjuvNTX
RPBHgfr4bitlu47vdlkqvtu2Ssd3wOH9tgDWepPCxrxdFGu9zYZ11khJvwZ8 /dsp/+W4/U4C
IHTnOzxWfqdekoh9B/Fj+vOpvfEYkuG5X3dg/fkO9Xr81HdHWJlFnnYXFsa5 iyAStmJPVMmD
a6X43VVK8bvyxyl+V5YUv1XCTq4sKX5/I3ZyhVvUsX35UoJtFp7Khu8Q2mbi qWzwrrWzVwhP
tauDHsjZ04OncvYIPxKzk0nZv6y1O3tGIakcCxxJ5VhGIqkci8BLMq2etder NiqZl7ZPpDSt
EgnUB5w64Y1fb6elxq+desobwNwq10109qnPQRA2/cvs/y0gA3f2QYuYzj7V 749jxrwafa5S
iBeQU3XL5Zx9lUPmzgFo9cM5oNpWC0dhkMl/rooc5CHrxEX/qa5t4hwQpaJP QUV/SLXtWWc6
o/bnIrjQApehrpHiHKrsYTmHBPYyUuZlfNsCzh12L30Zqwot40hlV8s5AsUQ OEd0wGnXx4l/
9cM+SucCR0ygWK6xlWVqco7plKKjZ1zwyS59R8fgab9zTBgTb+N/MAxRekUO J6nnx2qJRJwT
+HTqBHGlOEpweIvSAaV4QhRLEb5wcko1r7GZjrNKcQmWO9ipplLJqYiH/PZo lfaQpykgOJ3z
t84W7CHP4D3kGfWeEi36eAZvaOds+lAYskHnnL0OSIpVGqwwcU693X/BiUj9 4JxXP3Aa5Yjh
nAtLhhiO+cs8yrlOvRxoz7lg0CZnehJgdyYKdzsicH53A74McgGbD17SS/9j 3ZueOb3P4/Cd
Tygi+DNfwpZ+Lhmbzm/6fnegatG5c5kq2e8+hxUX+pgrS8XC95LfUv116M4V bPJ/Vf2l9841
bN3vmp50ZNFbHHnhz9KTWxfCPUUKK6vXSst717Du/IZq0+24l8iIOFY38+Pc KC3a3cDa7Q2d
hnCMEytSRc2Rs0JVRkrrcQj2lUb0xjxO8I9MJgraQsHJB3xwgmAt+JZqwU7s DeoSFvwBTm7q
3MJe+a1U4ioyMZda8DJINQJknTuV5KLO3d8mF3XuluSiFQLIOndLctFfCJB1 7qk+CCd2K4sz
7Tjy7UkZtnwV+N4oilHnHh7pdW8kxajzAN8ueyhCMZr7SMNj5h70UIw6D3SU QtQc2MOw1M4c
td2hls7EZPxoFCLeeYRv/DwaiYh3HuH7TU9W9ez9SVOb94moW3DqPKWLXdTn PFvqFpw6z2ix
a/qcZ9ay4xNmj0HwhIALj50X1sLjb18r2HkpIa8XxJQXow0ieEJIqMJLyhTX 18eqkxa21K3S
djACFBUmC1yl7eCUIafxK1paTA7gIkfHQQwxiYCXZKTkEHULxx0H0k+51gIX jjsuayUbGh0E
+b1+U2Y+zWVyeDitwqvZyoU4rh6CVcezyvXhxYTpLXgHuOORUp19wdOlCz6d r3SVtOMveJW0
4ytdJe34C14l7QSsCFzydQyYl5fbNQI+HGEjgqU9dZACe2rJnnJDLQWh06ga BWEeLHJyxZZP
8HsYZ2c59CfNrzJEYk6Dy014VXJolPDoqvBNSWgbQcxZpm8tGo62lp9lcu8U YieIUhgQgQUR
hIz45ksflYEcQ/p0p5+QeGZ1q3svBNtoKgQfhUovNoS92FdWXdLtd7t+5PLg q5k4y1HSOa/U
m+3isJf50NT12z/QKfmP7vwVtxTOIb4qveJX2Ct+s8Qc6a0/W4TekppNbymc yX1TCu97I6Bj
oG8pe8gJKOHO8WjFwzjB8kUTLXbEqQnf2W6mix1xalWOr6RFveR/oZdIhNji 7nVvlYw9W6mi
jfFOZHGHWYW85VxAWVf4KEVKvWIEC3qO6BiAAowRP1cczAv8Bh6fGcPOMMQM HqqJf+bFXy4L
kc782wyusgDTHiSOfwcfGolh46G2xTn06ANnXP6rDM+7i8BJdJ02LE66zajv fovBFeV3bcYQ
222SBUktZX+6Q9UFPwh8bk4bubfw+P8O0on/7hCV+O9O+rfx311rif+uEP67 i5b471+I/+6y
VnNG2bfFXduX6lF1zaJL7cEDlntm0qX24EsNvSJ0qbnvMzwUNNGzeNpJ6PC4 UaA3WjfvMyNO
MSEnRm2edhJ4xHLfyM3TTh8eRd8n1TP4viZg1Dsd6RYnIJb+btZU1zv8g/Ru 5lTXB3yQ9IGq
Z+kfmqa6Phg0Fn6UdHGU2M4EzyKx58RJzZrqSuHfo9TMqa4UPkYaWNWz94Gm qa4Bg+BuFMbH
fZl+9sCsjP0T/jH6NDNj/4QPkD4rmLGvasrYV1nDIvuMLqGYaFcJGzyuaU5k VVM6tMbAUd5C
yHNt0aMia6whLIDzQY5hrbPGsKbfylZHGVmt0+mBIxBprSsfT1hnTSZO3sf9 mbZ66cNsQA4q
blBF//6z+w899LrBHKkeuycokUFaS80SFxnw/GuNNVV9m3TDqAEksRrkfHUt LaBksK5lkzVZ
/RNIBiS7TUiM6SYpIDvY+dhNlk+77Deh5LUl/xiDoT23+GjPIeJRBJa5xdtQ 126UhGVupVxY
Jhf0rBeTuS0yzFYGsbXNqjSKMnoKI9iuFc5BbSudpdjWSqa5o5RMc+ePk2nu LMk0qwSm2lmS
af5GMNUuPfLL/mtPPyX8HO6dj7KvkeHY2zWr+7oLX1zcNbP7ugJf8F4p1H3d 0cKxt6Kp+7pC
x9BHbalGjG1Wv9WG77faZvZbbfB+q7tnVc7C3T09/VZ3j77L4CP+96zbPT+R gFe4e0b1XV0L
/BlyLSP7rq5F4CWZVs/c6wsd1N77V5r5+V05WtfyW47fPYjo9bP/0cad/ytZ SMwtNI3vrB5H
Q6KYMBIqI7p1LmfRZ7kyorvPekXGnzg98Uyd+VpoU/pc9exKXYHR3Vc59O3u gw59u/v0wnrb
d7MM1/05+C07entVUkUOCgQaueRZeUVU8FFR90DnqKh7oHJU1D3426Oi7uFy VLRC1U33cDkq
+gurm+4hYc2T4Ha7ObCTOEuCmoFEEnRoVhJ0BJ8EHZmZBB3BJ0FHRZKg3Dca Pgk61gM+dY/Z
KC17Jmy0nYlFlLf7Y6OmRt1j+ArdiZFTo+4JgpckqZ7dn+iBSbunjJ21I+23 3+WwV+6pUX1L
9xT+XTo1sm/pnsHHSmeoepZ+pqdv6Z7RVxBlUXzo+faYiEumpXFuVAfTPYd/ i86N7GC65/Dx
0YVVPVu/0NTBvODm7qHvAWTvF2Zl75fwL9Klmdn7JXyUdFnB7P2qoi3MK34L M6d397/xv6Vi
h8fXk/3Cjz/GXFCWj5cX6ez9p0QyqYBk8pu77rVVUDLXFoRkUj2SuebqjNe+ oejMQcm2N+Nr
CL8JPz+5MbmntOg9sRc3iRGSXxM995TDwz0nmYiiwTeooGRuUOFdCELM4RKS OYj6rSmv+ezH
Eu7k1f5XrHIWRt7s2SeO/sdPMsCgP/rfuf8e0afUoyGrh8hP0Lc3Cf4AZ++Z GjVFfEebwx8+
VtPboo721gJQU5TqUdNb/oDgwShTF9TRW8JeiyKiI7cMyinsifzCHVXT+21P 8Cvu6MGy3/Sn
vwGsqXcCTw2hPDV3RZ+aO/ZT0xAKCe5An5o87Nm9xVukV25/nnuP2Fi09P61 HAG9e89g3kdf
vGmq6O/de4YBjWA1vvdPcoWXrIXqlqy5D5ZK3NsD6HoF94EsfJVhEBKFl5Gq vIxH0H0r7mOh
anuIRPbO/Nx4kiP/V/BFNO4jLDrzkT5dn4Wf4lPl80dXqHpPSv3AE6wfeKL6 gcxuExkRvyl0
tU9KrfsZ1rqf0SKWHb4p1PBnolT8oLuV3BerKMJbMHpkb2wtd/YXrejpF6Xo 6Zc/jp7GS/R0
ldDTeIme/o3oaUy4BEo9u4UTl0i0X7FZ7VcHvv3qmNl+deDbr06h9uuLlvar qwk87VK1KPBH
ftGOA3siBtud+hEJy3fNgk+78PAgz0z4tAcPWfNI9Szf0wSf9qla1Or3Ervr D8vcMuhp3yz0
tA//MPlmoqcD+GApQNUz9EATejqgalEruzc7jvyvlTt9mXe9YRaAugH/GjXM BFA34CMkYlXP
3IkmADUhjF0c9a/jlzZzwuzy57bCFOzicMOFwlPzcAUh4uEKvhdiSmIMQh5t dme7JJlJmDJ7
IuIdfuF+yHWqrh/yqrTj9wrb8XulZyFTfZFAWNzAU8q8wjaE3hhQwuwrApzl Ev7UIr6LILiR
Yf4JiELSpTelpEtvsG39N7b133XDRmMWeuI/EinJK2yGNpUaf1NrQ7CptCHY /OMNwdayIVil
hmBr2RD8jQ3BFjs+mS7slcgqWma1AyP4CldkZjswgq+6RoXagU0txYNYUzsw Zi3yPMlcyigb
9r2Tr7hchnIhZk9XdgqXEiTjxlgMw1j6EtuaLrHNusS9ZhP6HtsVu8e24nvs VK721KHe+PSC
hcpLHWXlpQ47wZz+q++a8xIRyOkGd11hwamrNOfswhacuuxRk6mSziBwz2Ev Y0Nh6aWrFIze
gwWj96i2+zNWn6G83k5hr0NhPaanFJzeg61FJhZ32u2fT+U9c/NyrimcwUiU VhwT2Ipjwn4Q
kO/67bk5l5pMzdHbU6jjfaX+vw/r//t0hG83TmI3bn6XumfJtXng2w99nfs6 3XeV+zrd97+9
r9N9X+7rrFIJ9n25r/M3lmA/qD7oX9YukcF/mAXV/IAvGn6YCdVM4QvZaSGo 5ruWfV6pJqhm
mrL5bq5+pOelDX7AZhXKy/Xnzf8/wb9FT3Cz/85SlLCDoXKXN4C39kHKHZG7 zP6nV+RwkgnI
p6W26PkJj3f95A8ajrzYTN0jJkqlqLh0vArvL1cRmwNt/HSIS7DkwTR5yFUR D/mtmlzaQ64x
PWRuabq0h1xbsIdcg/eQa9R7SrTo4zq8oa1Tb2n0iTPXdMHEtDP/CtUpjlzb rDJwS3JKqXjX
BQhnOxS6zo2iPIgbVuEmo1AHSAnv3oYASfF8E2a8Z/WCQBPObvBZAHO6EJN7 KsoCuJEC3NOG
JsLZGp9wNqchMJZMrSjhbA0BSKZmqeZHrFEd0L+avEgvucZZzZvL6SPUS96k 8wcNK0czxWt3
R0Ss3h48cdCmVpzwplKc8OYfxwlvLXHCVSpSby1xwr+xSL3FXN3S6ftdmRr1 llkQ4W34BGbb
TIjwNnx2u10IIrypBSK8UzlU4g5V327HcZpIGLmjDJK4UwFIoq0QkrKrFJKy WxKSQnk7domm
ut5uqq+ut2Ittq63Al+zXyGLreutwJNF2JaOup6Nfk1dzxaoF+1Q6np20XqR za4XCaXveV+s
ol6UVyaYk8xmfr3I2ytYL8r7B1wspEhhQ41kBHQmSSmSSYtKBqDGmPfFsJW0 XNzkZBvOBGZ5
m2RP2wV2SRgJDWh4FmfHSOSdoVLRkGexqPBG+XY0C3gOLqUIAK7VAaE9SyX+ 36tbGgt7Xh0p
LOx5dfKnC3tePV0W9qpT2PP2rWVh7/cV9rx9xJsXsIcrqHqjxSQSk6TevlHc wN4+eDLjHRjJ
DewdIHhJFuEGzn2mwWt83oEebmDvkKpFw2VzA9tPw8T2YglLPzQKce4dgteg vUMjEefeEXhf
xDtC1bP0Iz14Su+IrkW+37bjrt0juJmdwSZhL4llOnjesVEMwd4x/Jt0bCRD sHcMHyedWNWz
+RM9DMHeCWPDYDfpDdd9RJkN+p6ErZ8Y1a33TuFfpVMju/X/z951NDeOM+2/ svXdXeMcDt/B
dJhxUDBkOeiiokQQoAIpkZJM6de/CvaMZRMgQDZg2tBld2urTJGNp9Hp6W7n Gt5Tuo6Lp+s3
RavWJyWO36r1slnqm5SafeLkYqEs9Q1nFzX5MC0CX+ZJUOO6umlBzq1IaT7D ZAfnlnmI0bjV
Xx3h8jjXIP8sUjDBoUqBqBwR49yCjohxSjzfwV9ZtGrg+Wv3Cp7lmqJxpW5c klNSOTfGKVFY
4TNvgPlFjn0HO2vX1XuY34jA3C0rLEyVVVJynLJOxrlTVsk4d8o/m3HuVDaM 8yIVpiobxvl3
LExVBDZnNNt5d944FbOC2Sp8MFs1M5itwgezValgtqyDeu7c6Rls7NylJepB NtQ6d2ZVoe/g
s6vIzCo0gs/4I1o8dUeaqtA1gTi7OVgE2nk4JzWzKtE1eJNUM7MSfQ/vJt2j 4mn7vaZK9D17
TS0e0SBPMapuVuG5Dm+G6mYWnuvwrtGDVTwVf9BUeH5gouj27DSHfj/w+kGc QVL4nrWnz3lk
Dx/ZSSuqiP4Eu4izK/oTWY7nkXk8i96PBfsnxxk9cs8oSMqMZz6jJ/Vn9PRF Z/TEPCMvek1+
L1nYr4ue51eBl8dyPmk8tef0zQtp5ZxfWirlz/xKuVCJ/DmtrT3p1vol9OS0 uUsNjLI9uWGl
NZ+NMjafNZC+sr7C8l5DaRW7AVvFttlLl6OzfxJMuDrSboDFTWQ7Fb83ffOt vegch3Ov7c1l
EQKFjdgvWAnnIQEJlsO+vvANOZdxzVtsWfvSt4s5b/eRDfJ1r9my0ikr8mV8 PlslmwK2QLew
OC2ant5au/iiXAySa4X0nZbShts26MItp42+gL6jbs6L01ZqddqwVsdJd/Iy 8tPcG/AZjo4D
q/EOU+OjxTdf+RM79Ox14LXPcrXZ31B4ocAiAvN7zdZkUc+lhLfwAMGwAMGU TW7zRpCigIcF
hoWFyy4hBqfzO3qy3HgDJpASPDZcWGy47BQsdnEYLjlvoUfI2jAhHz/muj9K Cg2Xq9RrIFrH
dBClYzrIDx/TQTZjOorEhqSbMR3fkQ1JBZo/mktPMw9fgprFjqLwJUDPTHaU B1+W9qTYUURL
Z5+niR3VYaNofnfMrf5yGM+ygz8Yh208/08XaExPxyzKVAeeMtUxkzLVhadM dVHxroCuJspU
NxYw+PMLYFVEy6PxPbMYVD14U9Uzk0HVg3ef+lbxNL6viUHV5zg8r1mc/B5+ 36x2Jx/eKPlm
tjv58I6SHxdP2QNN7U4B4k/hm1v2VVkgs6YHZsXyAbwxGpgZyw/gHaRBAWP5 gaZYfmhlIhKJ
CXaIADmcmb6OZmWaCX5g/MUfGFqZmWpiXxh+9RGGNB+XTPAzv/ogozR2yntu dY4PjbjnmbTR
CvpD9dLII4008pEkjfz5q2jkI6Z794DDudQXBu20FY1Cuz1at2hclvYolVlO si1Mc0ZcX3zu
WXxgHlyKbKjB9/BUlDEsYXDMJiL787Db88kaoKaJrsk6MzZBDkOF/MyxUorg GJb5M2EqcDAe
kQBI3KHCgWoTpQPVJhRy854zSdPqucDXR6plNgMvFm9vUyKxG9bsvTA1meDR 1asy50mdvVDu
F06FvvB93JITiS9iFKvMWIw1pUJi3sFVXq+FPAcXF+zgYsUHNy3c/Nkp84jv /xathRygqbLW
ummu1jqezZsxbV7X852U9hwfX9CMP4uUeHQZ/csZTfXc30EhTT0/v9cDPMd3 Buv6bDNhQMZ2
6KT3BXz+ZnjvehuW17zN5ry77oJQB0byxo/wANiGBcAOEwAjaGo3Hij0gHeU esA7sCOFd5ge
8MgO5/7F2lUzErpqBhmvwF12M+SSxJXhVYYcdc1BeN9VSnjf/eGE990N4b1I hPe9DeH9OxLe
95h30Py8us0Ik0Xs0Vz6TnmCwz2zyuR78GXyfTPL5PvwZfJ9qTL5rpYy+b6m MvkBE0WdwPPh
9P3ALH77ATxt68BMfvshPJXwEBVP3w818dsPYyH7HuWkHRyZRW4/gjdKR2aS 24/gHaVjq3jq
fqyJ3H5Mhcx7XnU/NovefgJvk07MpLefwPtJJ3Hx1H1LU013C6XxPJqDCI+d IHdDy5ZZ8fsW
vFlqmhm/N+FdpWYB4/emnvgdn7J50gu6qd1715+eXd3xqVHhOz4FN0v41Mjw HVvgrhK2ihe+
Y0tP+I4tdnv6Wy1jsWy+P4eA18rT4oLPjIrg8Rm4WcJnRkbw+AzcVcLnxYvg 8bmeCB6fUy39
M/g8/tr+GXxh6SJN4wukmjSdicJ54Y/7rw/5ALYLmk7kvFmwGtcE/YrfD49i jzCfQyhcNNX9
Sn/KJfOwekFb8BGIt3X83YtA0WETqZarX0SrlQgChFV8GSuiwuLfliIqLP7N m2I3ee2MSmNB
CZPg7tXNN8W/VXbd4N+gzEP8h8M8FOfcistdXbcT/qOSfIj/UFi5x9yZ4PJz 0PkbTrJ98xVo
Qx2+4t6mvoMdJLj25fPHI/iPhz3wK/6BlzJvvKiDb7zA1zpnKONrlZRSfP2z KaX4ekMpLRCl
FN9sKKXfkFKKb1BaivrNBc0c0N0YVY3CN/Apllsjq1H4Fj7tdytTjUo00PDJ qltN1agSZ4Ay
HjSpt9h4Os2v7yWzylEl+HJUycxyVBm+HFVGxdP3sqZyVJkdeFG7N393OJWv mFWPqsAbpoqZ
9agKvLNUtYqn8lVN9agqE0XLv8qh4VWjSKT4Dt4U3RlJIsV38O7RXVw8DUd6 SKQYIT0VZ0S/
uOKMYp0TG3HN0jaxEdeQ1MTGpEpAHsnWqLZafi3+2gFo+J7pDLRwL/BJdB9U a6UcX3ivfFJt
pgr76b9qyYeLKqEA/F8f91s4vPDZJen/WAMxf+V8mzj9bT5Xav9jDXPK+TZJ 03Y+vI3TSJZN
Ul0z79ugdNlcMd6mziz+rNA8f8KHH+POg8tejPylAsP1dNQ4n9Ow/7HKkTnP 6UEANZ9Hfa3e
5gFJntMDkp7bJzQYTMk5PaTfNQkjwF4lE8tKJoaQDNUjmUcBzGwzMPMoi5lH CMw8gmImiQH2
yOHRrWaBiRC1HmNF46DxE3tx+wSvL7HHz5aITJ9pxjdhOpCDIFx/kYbQiwQK 2UlPSllhT5Ks
MDC0PjPRcLFCQ5Zh5jiJ8bSOXuYERuAb6lnAT3xi3N3Psnf3M/fuTp77J65N YGfeYJ55daF3
IgfcQGk8Uj/jpdDgrDiwMLUnXhCmDFZNjFfEfpwTrddwOPHaWNlv25wFCMPx PNhanyM6TMwH
IWw7Fb83fUtlCkxU7yu8NG2llE4bluFnx6n5jGo2u+SrG9mJW5ZKEbdAh8bi FlO5B2Ew8RxV
GPcVYrwVqzyANiyFt404BzAK2kFvzae2xNwuePJum+pksLZjlQxWx/rZDFYH bRisBWKwOnTD
YP2GDFYnTnP/msvmOddu5xmqgrFZHBcMz3HBZnJcMDzHxZXiuLRjHRVwVxPH xaW85FfzXUte
DmV3zaK7EHi6CzGT7kLg6S4kLp6yU010F8rNdDedub8QBtNczDZqVnsKhbdG npntKR68h+TR
4qm6p6k9pcNpT3HtcW/UXCaHcmh6x6zGlA68KeqY2ZjShXePuqh4mt7V1JjS jTnLLauv+ew8
oXqPu3c1MTuucrkl7iGlyy1xT9PB9XgHh16zLXkOrl+wg+srPrg+/cqtpOzi f1+Almkziv++
JVn897mHLlgp7GuiRfgCpEybQT30ZUmZPgWQjK+JlOkLYKbFoLQFspgJIDDj a8JMIICZNoPI
G8hiJoDATKAJM4EAZp4YkhnIYmZgAZCMAk2YGaRjJmF56qtkZDEzoAAE0YEm zAwEyN87jBt4
KIuZoQUhGU2YGQpgZpeBmaEsZoYQmBlqwsxQADNjxj0TymIm5GNGcIutJsyE ApiZMDATymIm
pACSCTVhJhTAzC2jUaplZWsySSKdRsy82Fng+6vYpxp4/jwAc3GI/bYY0zhK I6ImHYcQHzNi
Lzj3R+F0zejORNwR90ohCy1SykIbwbLQRpxBkt4og2SvFRIsR0qJ/yPYcbBj C3gsqXsNP55y
jHSS+8ZUJblvHP9sct/E2pD7CkTum6ANue8bkvsmfF8CaGEanphF93mBr2e9 mEn3eYGvsb5I
0X3GVEdlMNZE94m5/i2UtsdmMX5ieMbP1EzGzxSe8TOlxdP2afyVVcmkHMiM 3Xj770oQSnvM
lKU9ZsyT7C6W//C7X333MmPb70zRegX3Cr45bRs2G7KNoGP2Kwr/zVob8raV NuTt/PCGvJ1N
Q16RYvadTUPed4zZd2LlKyV2zerF24X3O3fN7MXbhY+F9qR68ba1MHn3NPXi 7TFR9H60vJev
8XbPrOTcPnxybt/M5Nw+fHJuPy6esh9oSs4dMFHUCTw/v1E/MCstdwBvig7N TMsdwrtHh7R4
en6oqRHvSGAzbtT0/HbQn4cKORT+yKx+vCN4c3RkZj/eMbyLdIyKp/DHmtq6 jpkocoOwm9+w
n5gVrZ/Am6MTM6P1E3gXaauA0fqWpmh9i4oY9mA8IkE+w75lVsTehDdHTTMj 9ia8i9QsXsTu
nuqJ2N1TdsQ+9pe6l9u4u6dGRe3uKbhJci0jo3bXQvCSLF7U7lp6onb3jO3Y 0MBr4/yafmZU
uO6egdsi98zIcN09B/eP3PPihevuuZ5w3T1noujNdW+6YdBvvlbbc2j8hVGB u3sBb5EujAzc
3Qt4L+myeIG7e4m+kih74Y/7rw/5+F5UgC57s2Clrt03r9/64VlpbJ4PNNXE h/zmzPbDgz8r
roDQg1DKTnuZZ1FePVPoCdzEqcgT/lhpEZrQUxDf9xN6Br/TatlhLvScmNfC IfyYK3YRCod9
z1/we1W0/SfRnj+1/ZcYAxFm0LslkwjJn96GNTpoG4G/jcC4nih5xJN7LTlG I+kP3t/wUdbJ
AUpQcy0w4mmEGJKhspKhAJK5RpokIzBGgzUWbGxBI/hGYO+mk6zd7o3k3s2k P5BvSbjRs6vV
vRG4aRyGbt/EspKJISSjZ1ereyuAGczAzK0sZm4hMHOrCTO3ApjBDMzcymLm FgIzt5owUxLA
jMvATEkWMyUIzJQ0YaYkgBmXgZmSLGZKEJgpacJMWQAzpeTBdm5ZFjNlPmbE WgTLqndCu2V2
JPu6du8s8JdtQIJzr9xy2n7o4W22Tky3wgxZXp+f1IsptCjQrWR9JXa4PMBt z/Xa2d+pqunC
qKRfGAmiX6lFRfbCqHAvjEQ4SpwWsGSqAheGxbhKK+DBYTU9BGqPGW9TlQ2B qlR6UHgCgjWF
QNX0EKjtMS72O9mw+Y4/Qt0Tk4ymsPlOADMdBmbuZDFzRwEkc4dUm7w7ZgLt 6m2NIcJ/jZuQ
zUNWytADF8XZDAzi1uFCuz3KoJck68uwN6D3Byv5ez7518ya4fip8uNHzOOX PfVa6qnXlH9N
jYmP01a0xIfw19AUv20wzbY/3q0xJd63B4MlE/KdC3CfhJN/OwcXwO8Pgsgb 4URogw/VcO8l
h2qAne0982wrA3s4xhfxIMRzVRM84Pu0Ax52Mt4L98wDbgXONGUyixOURXgv XlT3vflH////
uXYvwmBTVN26yjX1bh10Tb1bZ97APdsn4zm+QKQNJ1yVw3/dB9BxN+4DU9/m ajburVnaVj9R
jHMT4lT83vQfas9x6E3+wfjzjeXC31gPFFYubPXG1J54wbqhrwtFty749F73 0dI4Cch9RAon
AbmP9EdPAnIf480koOJMAnKfrM0koO83Cch9QmnuQHPhgTUjb5Zjr6f7ZFYL whM8ue7ZzBaE
Z3jC57NMC0KikYanKT5rakFoMFEUzH3O5krtmitntfn3HsoxGshtmNWS0IBv SWiY2ZJgw7ck
2Kh4mm9rakmw2S0JPmYpfg69b5nVmNCCt1MtMxsTWvC+U9sqnt639UwUcNuU uxB6lZXKrOVt
bjE+McXF1/lswnQ0dWs7TAOyTEnmEKTDq3w6QRJL6rMgf+X5NHYTSbQUepir Tw1b3O9LIlbB
fh9G7O+rLopB8wsuz/fRr/4+zvmVA7+8LH7l+kRX+RECUxfcdOpCQsZ+RV1w ZakLLpe6kFyT
FMnkKyF1uLGAZBh0FyJLdyEWhGQ00V2IAGZqLMnIYobwMVMTo2JowgwRwAxi aBOVxQzlYyaJ
gCNBUgGWDBWgSHUZ9EdEoUl+lAq8DQPBVJaMSWMAwhbVRMb00smY7TpDMp4s e9vjsrcFS5ye
JgKvJ4CZBwbJz5PFjBdDSEYTZjoCmHlk3HodWcx0IDDT0YSZjgBmHhna1JHF TAcCMx1NmOkK
YOaJoU1dWcx0ITDT1YSZrgBmnhna1JXFTBcCM11NmOkJYKaR7EO0vIyNAuzp FD1msHxm9xb9
PO1xuNhjPxWcUNFjJqEiPBwvSL9iQyp6zCCXjO3QwY7IQ/q8bODqw0ZqDrmf 7ii2Ogz492WD
iz43uGgRoT6Zvqbgop8eXLRYLrQvG1z4FoRkNAUXfipm4non2cy2yuDN+X76 Bd6qMhDsy17g
Pj+5fCt0Tr6mCzxIv8BbdwwEB7JGP0AAkgk0Gf1AADN3DEcxkMVMAIGZgKpu uhgwbdC5PbKX
pTkRQv4ApRHyjzIS8gdMi73+V++l2/BFWF7inRgvHEphXlr5QCmtfAhLKx8i 7mH8TaKnQj3P
YSB1hzGkSg8jznYYjEJLyHYfQ2yPcOXDkWSut4Tylzy73pL2W0x1X/wzrfsj fwE3hC/6R8xz
+ktvKc//Fcl8XE6cR0gI55mlGMGTz6I4VYpLWsh7KQ4DqlKKI0utFEfwVJ4R ZfcFLdR0xcUR
l2DGD9NEMh2L3JDvPIjMN+SYe0MmuiOZb8jxF9+QY/gbcsIe4KgFjxN4RZuw uxsXr5jGqRHE
woR5KS6vtnUwpHbSKeVAvKSHpQm+/jL4agTgszJfBKrrw+T0QQu+UvoiEJjW GCH7i2xg+gIR
mL5oSmbEAsmMGqOCEcsmM2KIZEasKZkRC2DmnCUZWczEfMycCVXXY+XJjCnT jpRs33PxYpa1
6IiBKco8ESMliJ4yTcN4NHc+Zn+/+P31PZgJMU2mmpLBUwEOzpSBvplsmnzG 5+BMrSJJZiZQ
WrlgJKZnsqWVGQXQy5mm0spMoLRyybBy27KY2bYgJKMJM9sCmLlkJKa3ZTGz DYGZbU2Y2U7H
jH2QLBn7BHxs3U66N2LvJiPYPgT3GneQwNswULMji5odLmrsHSHfaEcTanbS UdMYMO7gXdmb
ZteSjv0TJAN607D5FLvsGVv/EvCCXIpddiIi8IX2SOzGnA0doRiJYo9Donir IigB2V66+jVC
Bsj2ZNVvjwKAbE+T+u2lqp8znCRLphGBMwX20y/tBmsRxb5sCLmPAM5pX1MI uZ8eQjZGDIds
XzaE3I8hJKMp7XAggJkRAzMHspg5gMDMgSbMHNB03X5JxkxjDO6QHQgY+nGy C9SYZHTIkhIP
h0wj9HstxSCUeThEqqaOH7KHnkZ/R/wsBm6lT96zwEeeHcagVIWjtAnra2WF I6HsSjPj1NAj
lPIurzio4fUG8KaI6pPfVB0h4kgpIeII9siPrbQJ9vJnTn5z3jHHyL1jpSP3 jn/4yL3jzci9
Io3cO9mM3PuOI/dOBM1SM5r/z2b73Sz0zESJE7PG753AcyW2zBy/twVP0diS Gr93rGUYz1b8
lVuC2YFWU4C9ccRIFTRlA+ImNyBODLYkfHWwanOTigV9C69eJO5rpm2bGsyy cejJqcWO+86C
CQ6XiwvkQz6xH+fMuzn3os5yy6+yH2ee0WChn5/oZYIxAficc3IKGgoRyxIz 7fKKpTLcJBZS
GG4Si2ocqk6sWGGER86sHx3hkTO0ifCKE+GRM7qJ8L5fhEfOYt0RHjk3atwq OQePS8i5keNW
yTl4rEwuZMatJhps8AiPXOgZt0ouKGdTWdQcBc2PVwDOMX+VXMRGqf0l+Exw comMVPtLCi/J
uHhq/9sqZGInKZT9VM/fSq6gJwXXv3K+TTojJSG0/Y9VZM37NgI8pi3G2xxD 85jIHyv9bZrJ
nBTyRzIFl/QH8mmSP3o4KeRPOiclPEUMycSykokhJKOHx0Su0jETMvSJXMli 5goCM1eq07bk
iukYvQ/IRDK25CpWtCuZXFsSu5JFZXtNM74M0zOJ/kqMsStZ9NVuNF0V1wIG 5pqhENeyV8U1
l/KYCESJQwOWzI3IVcFwBK7BTe9NulsSnjGM3Y0kuTrpDzIgWPV+bHLDdGvP gl7PbgUrL7Ee
CY1sIrdWWrkp4251cosE2/l9UhPSgW2U8UXY0y7mkeBrgm2tyzKxl1B0NBHZ jtWVRm5Vzoki
JZ37ZklJJfmNlH42+Y2UNuS3IpVGyhvy23csjZTZK/h63twgN/HKMOdYOUnK RrHdSBk+g18x
ku1GKvBVpYoM2y3RQsMnRSt65oCRKhNFeILDaXPhDeZQ86pRm2VJFT5jXzVy syy5g68i3aHi
qfmdns2y5I5X9/Hn2hfkWSBNkFnMBgRvg5CZzAYE7xfVrOKpeQ19ZYkzKWNW o0IZM6F0WS0t
19/2OFkq3pPvUxJxPqlnZD/fc4zBu+9HS/fn3TSXvlDGc6Yw23Wvsu+U3EuS rcEAWWeqbW2u
hO1FhO68r6N40ek8EF6Ue9a1lIunuqpZ/KT+9bP4SVvd+HdSV5pjfQCdxU8e EGcg9kjgCBC2
nYrfm76dgRed43BuFP8dymfhK1T5B6Uq/wDbX/Fo8SoLqZdpJuE7CpH/qLTx 4pHCCj/mXkNn
b87+mg+UtFZc/NaZKZT9k6VS9k9IZ2Xniaqs7DzFP7uy82xtKjsFquw8o01l 5xtWdp7ZzPdx
b+QNel57/v44Tyro2Sy2ewM+T9kwk+3egM+dN6TY7k9URyrItvRkfG2kZ8EL sam2BS/Ejr90
wQtpwWt7C33pghfSgle7VqxhwQtpW99lwUtSYuYTtbbOoGy2ZSmbba4+EqGV 2klvrIRa206f
UpmQzVlJxpEcR530Bxkko2fwfVJK45NkHhl0bEcWMw4EZhzlNF+HQ/N9S2yI pIFxWlnBvstY
VsDit/lYiN/7QsHnqWDYlBNmHkq4Si5IpZ0+CSBWt2CWuErTSy4ClbPLjN2w 76ylVQcItKwQ
K5xq4yotKxD2+e7mOgvCVPPuYkEAf2STT6bgI4IJgVVqEks0WfltMQMxVVgi oUpVmWrNFFOl
mWL6wzPF3iZTXKRMsbfJFH/HTLFHeY5sngSxZ1aCuAOfMuqYmSDuwGeqOlIJ YqolQdzVlCDu
chhw/fm5e61czP+uWQ0+XXgia8/MBp8ePLm6R4un5j1NDT59Lh0rjyHvm9Xb 04c3P30ze3t8
eJfIR8XTcF9Tb4/PRFELj14w9pve/P1C127jqDkIwlx9u4FZnT4BvDEKzOz0 CeAdpIFVPKUf
aJphOqDCSr/U+abXH+Tv2h+YFbsP4Q3V0MzYfQjvPA0LGLuHmmL3EElqf/Qv VZ9Z+UOzIvoQ
3mBFZkb0EbwTFRUwoo80RfSj/7F3ZUut40D0V+YHqEvYecTse3DYX1wmcSLZ iR3iLA5fP9mA
ANosdwsH52nqThUgt1pS9zmnu/nCt3DSrfz9rDsgQF63WGl+F/6l6hYzze/B R0+9HKb5PUNp
fo/rRW4ce62X5tCpfuqstI97v1gJfh/+beoXM8Hvw8dLgxwm+AM7n9MKBgrt mz2OknqQtn3z
QNy+WU3ZOTDUvjmxFCzDad+cpO30ntgAlkkMtfxOFHymzqlLSNL6TALhMwmo zxyGvdbsSH6z
zNCSKs3Px0rPL588uze+/SZb9mx/U5azfwv/TfGaMxkvjo8MFSo0GpzT85a2 QuPNAvCRoaEK
jTeVCg2eZdJWaLxBVGi8GarqeVPwmVvOW7Sa1mdWxT6j1kb9zZDPrCr4zAXP Mml9ZlXsM+dJ
pgbz0JZR8JkLzltUSuszJQvCMoZ8pqQw8OGA4zOltD5Tghj4UDLkM6VEwTKc G3gtrc+sWRCW
SbBr5Na48cZd7O27ihMw1kiWln6iypI1LoxBw2qzV/vSIYrsZ2lNRA4RK5fW UQtO1mFrx9b5
tWNJ91v5GDnMZPMyYr3eOmq12AZsE7oNW2jzeGSyckTDLxgGOc9k+2vEVlwb qD3oNmB70G1a
grFck8qK1Fc3KSMadxO1x9wmMVm9tplgVq9tWX+7em3LXlav5ah6bYssq9cW sHpti3sHtXpx
1yFu33OmHYO0ebLtYvFk2/A82XYxebJteJ5sJxVPtmlkqveOISHsDl8IO3rv O0NnLpLLIn3d
KZb0dRdevLFbTOnrLrygaDfJ33lfMSR9XeF6URjNn3WnGzm92HOqY8hL/9iv FEv0ugL/ODnF
FL068AGTQ/J37B0zoleyxw9x3DCMus4MPXZir1nXP+9kr1BqV7IH/jiRvUKq XYkFHjARy87d
eSeWGbUrsfhq1+ZoaZOzXpsxWhnCerIvZoJZbJr49GdDgsm+GhKsvX/7JGeT yJgU33SnZ9us
QliSA0lLz1q7kWjNICMH0plRF0SLCiUH3PfcrdXolO+W+CKD87Q0FyPhZWnY mLDHGisyo/Nk
ffl3BQnD5P9NfzalzpP1A1LeWn2voC2joPNcY+skWH7xT/eoH/KpoSkNrXIe j9BO+hHaST+S
8O9eTfNsnSWaCxIhCD/vnuo+ycJLn9vQ/U7JMShZT47lZP1FVHW/24XJ1/9s tfuTqMcTppBj
FaJey0aJ1EYaHlwWbKQ+C01OLEQWmpzYf5qFJidkyULnh4UmJ8mShV48Fpqc WtIL02mPJWBZ
EtjTYgFWp/CA1WkxAaszeMDqLA1gxXyi4QGrM5LLek1W5P4jWz3iZKvnKbXr rB+QKn7Vcw1g
y5zbCpbhZKvnJK1lCIBlzrEn3zDzjLnM+VNMrJLnXsjG3zx7euJ+csG9AHqz 4oP0CcK1jZIg
XGAOWSAXf3vIArlcDlnIU4JwuRyysIgJwiXBlqmSy0LJ1sgVfFB7VUjZGrmC T7Su0sjWmA80
fHpwbeUzPbhWKBTfYBf9sqKwfxlXIyeQGBD6dDXXKRuFsH4gfUh+bYh0LCs0 l1nnpHHHCfQ+
lRVKxY84peKbFvhqiHw1hxzblNN6TTnJXp7NWjGK19xIvab2mrCHu5KbtFT1 jS20jNIcUnJj
iKq+IQqW4fjMTVqfuUkgLGPIZ2y5z0Tsm6b22gY/27b8pnmNOB5spwVpbHFT ilBpn2zb0D7J
m1K8+hzLVNICexVxUwpqKVnGELBXUfCZqs324Bq4B1fkN0074O1T2pumIrxp WIoVxj5VCDbM
eMtnzae/47Q1bieuhDLeoqlpbrlp82eaLJnBW3t1NXVytwJhKnVj2d+NruC1 MHewWpg7bsJL
J7v/4VBfXPhNyYWfNfVKd0S8Jho2rkb/jEcu/2XKevtaaVkuDsZ8h9kKgdz/ 7VYI5H7ZCiFP
GPP9shXCImLM94n8sXSm75QTdZx2h/bdbhbE+aFQjRHIA3idH3koZGME8gBe e0oe0zRGYD7X
8Ijzo5nGCOSRyMI4x5vGcQ6NnfdIVfvYPxaLaHqCJ5qeikk0PcETTU9J/o79 s5n+COSZ60UN
r3uVjUx+FuJwrNSWceL/GWTRnhVEdncc3spNi8W5YpHdrZUpQQa2jCvH4to3 HJHdHYErCXO5
r1R5+rtSIE5ugoU4vVi/iDi9SPGYmam+HMY1JVDc0zUILh5TxykKekHFY6p/ HI+pLvGYPOEx
1SUes4h4TJV7B0GCMLVigTA1eBCmVkwQpgYPwnipQJgXI9mYl88pbqx47EfC 8sJJWLy0pLQn
Ftq52SJIYMvU5fKXts0RBr0QaPFAXSF9qnD2qZ5W/lIXpt2qIbUh+UtdLn9p 33JkFY20KXfD
grAM9kwW0uBmcPMT6FRS3IZsLku9rZllNrhxyfxUui8XhMrAzRRdQhLEphgE c1oLISmntYA5
FiEKjvW+dSr+RSQQSkioJmJA+cXw81MY59yroVQeKPQave2kv7WdlLudp2Hc dcOqV2l71VGq
UVW/MahsR90S0WuX5EsbMb1pNmLybdmatzR1RD6/hepHFqehG+8iXl0+5tAj EsBqxwLuSxc3
o6+Bfs/K0lJqkOBZPCCoFgcddUSa/FFHX+6Keaf2M02ZSizwG7dpG5xQRJqo pd/NP1763VqW
fucJBm4tS78XEQZuCQZ6j66B0a936t7s8GujwK1iaXJCeE1OWExNTgivyQlT aXKaRoq/I0Oa
nIgfFY++pDqJQQGOe1SoWSUkgqcq2oWcVULa8PRZm+TvuLcNzSp55XuR125G w4nmtut2Gl43
w2l/LVbjx1f4J+m1mI0fO/BhUsfO32nvGJpU0kkUTrvb6dL6KLfJcN7jYkk6 Yvg3KS6mpCOG
j5O6Vv7Oezenko6ugqTD5wgXumklHV2xpIMSTTYDmBDvcf2nMqYJVDiinqy9 QFTWZCp7Umjm
6D1V+zStq6Y16GvyVj1+Fef4nEjR/Qy0/MDGY1r6qLR83wZlWvpEoJAYecU7 R6tx4gaGqj76
CvUwPc5dNEgrzhmI62F6VqYDA2yZgULT6R6nHmaQVtA1IACWGRgSdA0UfCbg SN364MK7RGHI
V5MjL0vSdk5LbIDXNDHUOS1RiDMaHA+mFlxFV8J9qr5GyiqP/NDSlruBxSpD m/89UZ02Fb+E
yMKVNc1wZSgW7lVGD6QXdSe5yafv0gNmkHDgdUbbwx9cRWuIsos31GDgDTYY eOO3bva67kRM
ZHv1kem/BwRKZaDUQwy63lAFRauwgqJVW2TnVlTzmmw7K6nXqYfoz6uoMqLV xKRkpoQ6Tq30
x8eplZbj1PIkmSktx6nlVTKT4YpaE19RldFlGDZm/1G9mNb++MXEbBIwcSeF bpWLdnPBXB5r
yZ82WekXNXHrljSmdjrvwZ4TRl1nInEeZ1xeLQOztl4sJn0dnklfLyaTvgHP pG+kYtJLRkYo
bhhi0je4XvRx6mMnHv0P5yP3y3DqN4vFp2/C8+mbxeTTN+H59C0rf6d+y1Cf yi2+UrDjZeuC
wqgSTH+iZ5jw1A+9sb9NPMuJT4/DR/hDtW1lr1D8l2E7tm3xdlx/B5W1d2db yIIxEWp+N0HZ
3+I+LdP5euIuhop/ZIe7dTTeG0XPnYkAbP5PWaBbt8NvFBcfjBPSTFHyjqT5 o5W5+aPs8xKh
LiOLK+5ayBfFpejN0L6idw1d0bsEz/LJb1pe74pe4Z7zqD1edvzltV6zdO+T FaXio5yEU5qm
JBkDnywXykoiaJU7uTDplGfX9m5nMe8Vx9C94hD0DcC+Xo4shA2ge+DAAt2z RREQc6RPAzSy
pHui3f4gcWuX71ifF+tvPN0TCWGTOz/1wcxGBlNLTdyg7TGWmSNLLfVNnAA0 WfbQEoqZadU2
vIf7yHu4b2gP90V7OMnvDpOuF8bTUEZ7+/bF22ebPoIHyNt3AA4G0APCR0Rf eyNj1a7D5jBT
Tgmlk2Pm6zNN/ydaoCCVo4cS0R/z9laRytFDfoJc/dp8jD5naZFDX/BkRfQQ U1ZED03KiugR
pqyIHv1t9p4eLWVFOZIV0aOlrGgBO/HQY0uUGE1kBuN0hGSIhI4LJTCgx+AC A3pcSIEBPYHH
AU7SCAyYDzQ41UhPzAgM6IkA8JvFoxmwbHpaKEUBPYXPd04LqSigp+AcBT2z 8nfMzwzhG2cS
RcEHupHhrJ9BgBtqPBA9l+siZeCm6l8SMMj2DHFAZLDpuQiZei+309+0c3F3 hGFqQFHvHFyY
aTtHL0SjIM+94SDqZBAE0Av0aZCy70tQv+/SAvw+2d/iblUzqs7iErxjdyk6 dpPbsgbFy1zm
jJe5QgaFrwy9eVeiLdxrNmF38Spnu3iNvIvXhnbxGpsQp9fYhHiIQoiXDT2Z ZYn68bSayfpl
seTxGVDySMuJ6En5PhNAJHvUMeSNhWrIG9ucIW+4h3IC6HZh1KP0RtwgOexm 2i4wms/mUzYf
aZUKy2fL+ne99vQaYlCbqCQx4mHNTDnr+MfdCeP6DuZ875ihtr4kczqnsBQG K/lMMKYq0woq
iVf54yReZUni5YnEqyxJvEUk8W75JF4UTq3kjPKfDBHHbbE4vFt4Du+2mBze HTyHd5eKw6sY
AffvDHF4dwk/unNeRi9+Z5jhlN8Xi8K7h6fw7otJ4d3DU3gPVv5O+YMhIOxB BIR96kkPMz3p
D0I66JkxBAmFDno0hG092ko2zWDQR4iKXgCDmpnzQp/kvGw2B32yARw0C4r3 JDqGl59ohf4X
QhAJWb7w2dIEi9S+79nGLpqG7SLMwoi+dRFO7gJ2h3AWsKXbRZiJ4M5GYbdG v0kJYnQtpBEB
1LWlWK0MX7Shh+hSl0B2XqWuAn9g/iNfQNvL0hdbhu3/wicSA+Pn+TfAi7zf O6OQZnoDVFPO
CGD9gCxiUKq2ge0Bziw1nLrJ5aQLlcptVMXqAE6r/OEg1Bu0I/o791FN86hy XuqaQJt2mb0f
GK2RBXuqawqDGYbshv/US3tQPSu1dE6pezzGKARW9/QflnnjBDEeSWsZAmAZ zzZkGQWfWeVc
7vW0PlOH8BkP/XKvywY87LXbo2tkak6Vm74uu+lfLzRv+jr3pnfHaxzdbe8a 2dR2prbekhqC
BGrcbLna1eHa1f60LbLGkIaN8tQZvvy1NaXBAFQ2qIvzSjWEOrzpJoEIuRrJ IraWocQQ2EVs
Q/tAyEJ2mCHweDW10DvMAL+GVB4nMK7c6WtI08YJVAyO1rPd0tCWkcYJtWiD Eyc0bDgYyOf6
1Oxqv/Q6imiQb2O9yr5gFtBodTX9VyjQfBl9QSflqkf7mZ7GgJjxwUA+6o1y BqfSIOWoN9YP
zJ9O38q0XdCWIfLTuckegsdyjX8ZV6NwV2xybtFm2pyiKS7KUfRgQ3lo05Zb Zpt5i9aiLejR
ibSp4DU3CXs1Nxb4ahS8xua8MK20XtMSe01ZyWuahrympeA115zz1EoblbQk qJcSANuysXP0
FvdB24/CcBRsj4W+s1/3U4KpEh6EMrKovY7+lSE3aTkMq2477o0/a04ZOVZ4 vDeW/irxEH+q
BJ8IG3eacUconkVZjjpfRCves6U1hTIieO21IswplDSyf5XbieQzYhl7OL1a opSz6Fk/MB9S
hUoJT4Q9i5625QUtYxWHysFqS1IMpmQDogSjTTBLMNrJ3y7BeLWWJRg5KsF4 tZclGAtYgvHK
R0F6zS4dUyi0m0Wb/ZoUSpvdga8b6NiF1GZ34GtZOkkabTbreYbXZseGqJWY T7t9NsjNcM5j
UqhzHsMzMV2rkOe8C1/N0iX5O+ddKHk7WArV4/rbxx/UA2V69u+DMj2uCwgT HKXPS2T5oifA
C0S/uS9Fs3Y0ya4+9/b3Zi2G5pK8ubPRU8JYVxEbp/dRG6f3E1Bh8oAvqwmJ 1xl/5Vx+M0ep
s4cZa3SLKNl4WzGwMbdiACuEHyTZJzIytoBh8QQFHEpQ+3Mkf7w/R7Lsz5En cChZ9udYRHBo
KH/OnI/1ZCkoHBarTccQHtoYFrNNxxs83PaWqk1HYqSA/81Qm443UW/e0x8h bJYjvyoUdzAD
YtRmpKs2bjPSVfKb+T+fXF5VKBzscxQ9pbSKnpK4cFA720RR9JQUdMYDjl6v lFbRUyIAlikZ
0hmXFHxmwBEkrKX1mTUInymh1yOtcZ8NURirggqtEW04TZIjr/ELk5qjW+4j whzne2j1QOt8
2Nuru71md189X/+58VsJeIXsug0KVKyLwOqxSoyGozg+kxG24cuE141OHNxA BUM2/jgYsrEE
Q/IEhmwswZBFBEM2uXcQcWNn/q525hFm7QRps1iYyCY8JrJZTExkCx4T2UqF iWwYwUS2cppQ
bykkR+uctHE7bXK0LU6O1mzNGBklbdxWSKjXOaWB22kT6m0CYJltdJ3CNveO mjl/pe1VR0/J
e+8urdKRHZmu4NVHz493bMmHvp9ypQ+S1cKw7KqUje7wuzKNLyhpFnyJbshd S+Yxow8LG0p2
3LWx7LhLstkRobPVbmKgioe1YyuyHXsPo1S2bAVty1aybpmF7forssvyqtdU a+vmWNpWBPsa
h3sjno5yCTesehMXV/seon3DS7zC4Xdun63yS9siqgLH+ntmSu5Zf+dHxOGw gWp/L2UzAtYP
zEccjm3eMgy38/eI5BD9IMoUHNDfS5CuJd+yMl5L2LWIvmXzhbTua8+zPOL2 aaQU2viWLLSp
apb5+hb3JL9EtaHOi/wTj6DxXUhfx6Rp3W3GHpj20N/HLPD190EhfX+fe8Sa btjoTRq4AFgb
zrgJpnEPrN+Ju/wD7rk86oUT1CzVyTyQnUzWRQAgBfUPEkT2wz+0/jT74R/a S/YjP+yHf0iW
7MfisR/+Ib9HSOg5Ua/b7nU/taD6tId/VKhZTv4RePWbf1TIWU7+EXhFpn+c ZpYT85kGpz38
YzOznPxjrheNFxo7UR1E+u0fF6o/gH8CTs75J4XsD+CfEHhLJvk776dWzuqG /VMJ3LFXVe25
7p9KU6oLTdTodJHBjjNUsOMMFuw4WzCw4wwV7DgHnXTkn/PHp4SjiHtKEMxd Sk0WyDfX4GN8
k7XaUTz6BAb63Dyx0KqH/XOCanfQQm7/ghv5TVOdH4YPWBKZFIbH643oX2CW bfsX5JfQvQvu
DT97gLS0Ev6ljBn0y5pP0qUt9impOzEeoPQdApoWXocA/xL1jF/CnvErS3i3 Sq9VmO04Qrxy
r1BP/hWB3Y4UwbdqtwYV+xNooYl/DRsDXNuikY7N8ig1jsLabCLKp89WWSyU +ot0jOiX16jX
xDXsNVG2xOYfZbUo9keMCMqo90L5tyKCMp8nS7zqtIztKqp5mpHBjTQysDWZ +RubX1oQ1ppf
ar7CgGSJNIMtxHN9g3qub35Jv8fa1rlIsz/KajN4lW1n6SYm8iqb8OObymh9 1THDVZsufQ7W
elFRcAUN+GfThr23K9xdc2e79uWzY5VZMf6KBf7ZFVg4pkIEWUYjGiuD5z97 RUWVFpzhNXjz
K6h4zC1sLHYrwGNG166edc8Rr+Rb1Cv5FvbI3gkysrLb6f6IsYJzlfrn4BEx 5b1DjaXuYHOs
O4GYd7yATqfX7tJRmGR7je+mflZ6FzxEU9+jwuL3sPfwveD1Pe5EvfaXi4IA pbNBA9P+qDf1
A+xN/cC9qTtT5Roj9LEtpdAH8TF8QL2uH0w2bfAfMZs2+I9/u2mD/7hs2pAn 2eLjsmnDIsoW
nyzhaDMn/siDnXDyGmjrmJ4K1a7Bf4JX3zwVsl2D/wyvCHtO066B+U7D65ie zbSw9J/Fwwwz
nHC3WMpkF16Z7BZTmezCK5NfrPyd8Bc7b0rFF66/feLfXyB8FcD+JcmiWRT9 5qp0/Me17m+W
kQwsAEKJZKgKmgZ06LRx5JwnbmThrvxdRE60igpu1GDBjRp/nEut4ckhaGW2 0EPEOmqoWEcN
Fpr2uBduqxd3T+NonLFg9Uj1Pe5+h0oYlvJ+NxBPmIe6355RbKuOim3V/zi2 VV9iW3nCtupL
bGsRsa2GJQoCstTkNYqFZTXgsaxGMbEsAo9lkVRYVt1IpktI3jJdksgkajPO WUujRmWJaVTW
m0vpU+7uxr2XBhpN7ncQ8xqKGudS2LzGt/gbMLLC8S9tgZ5tfFgJhy+QcOxp awiDBryG0Id1
ikCILrpj7cShCs6gpWCpI6rhAlSxVgAr1goS6S4oKVhypyNqouq4mrZJIKBJ MIGAZvK3gYCW
tQQCcgQEtOwlELCAQECLiNDh2HHDmpMVEmgVq01PCJ/IhsVs0xPCgythqjY9 rBcaHhKILDPy
lkjABHWdj8Aww0mPSKFOegQvzmhbhTzpbXjBUJvk76S3EzMn/ZXrRRNczMkq Z3stFsj/Cv8O
vRYT5O/Ax0YdO3/nvJPP+WIs3PT7TAsGqvsfD27/p0s5xNKqeCVuIbax5h3E 3McjTlf9rgVv
ryMyDDGqVq0Lq1Xr2iYVgohW76LyOl1YCL9nmVGMiTsiZLR4DxWu78HC9T1+ bfXH/YEmEOxb
hgShdUReoI+63X3Y7e5zt7udoVNBHVF/OUClXQaw3OuAz73GFRo2mt60p9PE zEiHapAIMzAp
LZ5Cdot4iSao254YZdsSVLYt+eNs23DJtuWJbRsu2bZFZNuGArbNmYimJq9D FrJtWCyy7Q0e
UHorJtn2Bg9yvqUi2xIj0NyqIbJt1Za1EPycgZO1f8RqsWi3VXjarVRM2q0E T7uVSP7OfMkQ
7bbGbxva60Zh1Ip6WZ72tWKxbmvwD9JaMVm3dfggad3O3zFfzynrtq7Auv0k nKas24aVcpI8
4wfStypeT7Dnnm9w/ef+ndlRYQA3ZEPA3JZm24sNWasO19Zse7HJL5upRm2N htri3hZ6Z2kT
FpLdJLJouPLj29VcdRe+FGjTaDuALdR2AFt/vB3A1rIdQJ5wya1lO4BFxCW3 LazGd9vFylm2
4XOW7WLmLDvwOctOqpxly0g7gB1DrS13BAqTvWrVG10Wo7feGmY46ruizIPJ pDMO/j/Fv8VH
V79s4oU0lEPN/BiB+Y/Mr8rJ/DYtPb2lYDUKeehPxd1/vAA+42oY4q8fq+lx tKgVC06LumLL
tKjTenWt7hcrBGtC0wr3QMdRr1PVGU5wppnQOtzooet2Gl5XYynnmrIbRz65 Qan7AGNFiOI1
B1Ud6oCqQ4M9pEE7T3gGDvYw1YHBHoE1MF861nM7tS+jTP1M0rEnvc47gcV1 gYFHG6QLuMRn
S3OJgmFbs1lFsc6IInCkLbBgvcdKECf3eeBgW7APWjEQ7Nu/MjoJsfFMsI/5 OgT7sK/DAcLk
RLFwXO+zD0xqT4MDTO1pcPC3tafB4VJ7miOMNzhcak8XEOMNDok4YZy0enlP 2HRBoOCwUPLT
4AgcpQyOCik/DY4IvCXTyE+ZbzQ43hscm5GfBsc2EqMTHBdKbBocg4tNg5NC ik2DExvekiR/
J/zEjNg0OLXkLQoyCsuD00Kxt8Ep/Bt0Wkj2NjiDj4vO7Pyd9bN8Kk5ZTM4P bq3C4R1XEmCm
j0Xm/FjNLYd3dCzw1djy1Tjs1QTnJJ0al/UDINQTrBqXydB85UA/mR0F2jO4 kE6ja+jJcoML
rGl0wYWga8ABHRkyRuwXEFwI9BmHyej2CMe4MNIfv8zY8OWHxz4icnmXqFze JSwbc8ln6Xsv
KZp9KPNlj3hNQIIrzG4QwRWo4jy4IsLhFFmY6kd4EvAKloW5tvgyiPb/7F1b e6o6E/4r+w/0
+Xo+XDY9V+iB1p5ueBBR0AgKaNP++g91tdVVAglMstBws9ezL6SQzCTzvjPz TuhEya0QLZ0c
d0zpvxf49N8t7K7fuuW0jKRWJdyKlGLr3yGZGa47Q2SG685d7wzXHakzXBXK cN2jOsO1ghmu
+4zMyZ/43QRSOu/fq8WC38Oz4IaaLLgBz4IbXCz4nSGDGTMkseAPDJHuVGil TE77QS0W/AGe
BX9QkwV/hGfBH43q+fqjnB6m/iNh8HX7O2Qo4fFNpJTHN+HvpKarpMc34eOk J1Q9j38y5Hj8
k8t4u8+K17wIJLR/UquE7Rn+knpWs4TtGT5weibVc/4XVM2k9wtDYreZ3lCa lgErmWZ+yW/9
TckO/UfLXZR9m/yCgJSkwfxtXjklqNJ+UCDJAipBRV+ZV4NhZdJLJdJaIUvu 0yuD1RxTrOaV
8O4TAShOoPYQAu/TW34RSUpf4nxl3gzOlUn5Af/KUFsXwco23qjh0dVXk+NU 1eGrhsNwuqwF
HG9EVJmFBV1r4AjM0FlCaw0s2FoDi+S2vHp+t2D7uyOwrqAltK6gJbXTryW0 06+15p1+dt3p
V6U8qF13+q1iHtR2WS6CsmPd+7ZaPEkbnidpq8mTtOF5kjYXT9KS0hzgVJQn cVh4EgrGtMAR
r8OAeC3K2yAD/G0YGifalOYABN440WFonOhTMO8J+Np0GOxmQnmbU3C76TBI 600odtPhZUo6
pLyoetobC2FKugxW856+Mr0eOPPYZbCaJ0orUh/co7oMVuNQWpEM+LVhOG2e KaeNy8vKutmD
AdjIlq7owQB9l15ITGxnOH2XS8tv4+S6ZSGy3BwBxtTSdyYiy6WGHO78/VDQ XhY7umMivsOC
TTwefYzv18Jd+cPxciQUMtX97xV9JSP3leYx6oJc3AHTIu0JpKM8Fr2tIgSd Rx/7GwZxApNS
dNnYbGY/Y4NKkFk9kaMJ+r31Hk3Q79WjCapEZvXq0QSrSGb18681szW7aQsT WX216nv78PRL
X836XgxPCWKu+t6ejBkFfSypvhdn1PdGYxybQ88vQ1gP1KrqHcBX9Q7UrOod wFf1+qh6fu5L
qur1qVYU+I7pzUFqYS/31UpLBfB3UKBmWiqAj4sCUj0vH0pSoBwaWVIM5h/R 2dKCs0O1GnGH
8FfRSM1G3BF8eDRyq+fuI1LNLHTIUM/rUvJ3IW89b5hZz5uac+Ag5sFyHyHV fuY0zJwdLjKI
qh/mFvQaqJgiW5Sn9TbyC2ZYIrqG8dRJPL+bo4jm97eNgn86QwzuJPHlMMDz c02QIltEDRxm
yQ0UjH3IQUA7BXcoRlnDZqx4KZfRfmVys12Bo1RiofXcMWw9d0zXjnPwPJxZ XF67yZTB3YUX
LxtLVZoaC1WaGq+50tS4VpqqUlJqUitNrWJSakKPTOYnTyc5SUsXWE/UgrYT eGj7ria0fYeH
tu9c0HYspRH9XZLGFMloWYzNse+NxmWGLBC10s8EnmYlaqafP+Cp/w+jem7+ ISn9/JGPt8yW
41oTLyijLfWpVhb6E/4u+lQzC/0JHx9touq5+6akLPRmRpfkcBybwTie/jP8 QVaFXX5TrZT0
Fvy9tKVmSnoLPlbaItVz+e1/2il55o8Hfx7y93sZ+fmY2z+piIbnt5ezUH8+ +a9HUk+dsR/M
l/Uv6j39MSQzNcL2kB3q6a9dnd8yPYG6QOc/TwBOHO4wNIxGlMThDm/j305m 4x9j+8yOpMa/
XYaUakxp0NzlTanuGgArs4skrQyDzcQUm9nltZldCJvZlWQzeww241FsZo/X ZvYg0vB7kmxm
j8FmPEpz5h6vzewRiJWRZDP7DA3G95SV8Qq29KaVS+zTr+dZ7H7nsYmd7ef0 iPr9I1dIf90+
EZnKPEDrnco8MOpUZoVSmQduncpcwVTmQYZqoB0MvoWizIWp0oGPy/TbHarF gB7CM6CHajKg
h/AM6BEXA7pPZNAhR8a/pEPSIq0jqr2xxlhHefWnabiIqf50I6f+1LeMglK1 G0ZuEWipAtAS
keOGUJnRjTWXGTVrmdEqRY5mLTO6ipGjmVkSlByOZfu1TaXSZvgYPG2Gj5VM m+FjF34ludJm
GzIERjGqpsAoRgySf3o6P4iRy8ecpv1gUT9LY9HPwnQhUaAIGiOq/cxE2RjD aHyC/g1ViU9E
dl3gk/XuusAndddFhQJOfFp3XaxgwIlP6V0X47gbCKAq8alSLRj4FJxgw2dK tmDgMwN+JXla
MFIvbPgQ9Kya6gL4nCFFfZNe1oDPOcsa0n7AH4KeyylrwOcMCtg3hLIyhHdl CMTKyClrwBcM
NnNLgS0XvDZzAWEzF5Js5oLBZu4o3nTBazMXEDZzIclmLhlspkGxmUtem7nM tpkrliKhtDcW
szIMNqNRbOaS12YuCcTKuKJJgCtqLHRiYXz8R9KhiL4LTvvEJWIA3xXLguGr DCmUhw/fdsPA
D8aRKCkUfJWjCrqcoGXppWTWRcFP4mZL4muRUw/xtcyph/haZDoSX693OhI3 6nRkldihRp2O
XEV2qEE9g6KfW8q0k4u2BB/UUCslqcGnJDU1U5IafEpS40lJpl7R8HyQLkdc FutUK/LHU4xh
Wn7bnLXClXB2XS3yV4cnf2/UJH9v4MnfG7d6zn4jR38H31KtaPqi5pcYqDlI 0KA3TPw7cfUS
bn+rlB4PvoW/mW6V1OPBd/DR0p1RPbe/cytWnp5GbX0X10wCe/YXS7Fr93ll N2m0NBO7dU/d
YCvsjqffv7TDiIDyW02B/Na9K5LfuieQWrvYoF4xgX8XhEub4LyxCO3iJoEW 2sWGVFLPEErq
GWtO6j3UpF6VSL2HmtRbRVLvIWNUlDlMDmYzCcOd5APK4PwHtUi9R/gw9VFN Uu8RHjo9cpF6
hpSAv1nRPoNmfp8BpuiQ4CZvn0Ezs88AM83pTntjIcUXKbHnr5UxKMUXT4hz ZVJ+UGBliJyV
eWKwmStK+dsTr808ZdvMFROOeBLem/JEPXMeHL89i0q+ilNYwPIzElWK8ky9 Zr7GyOVAZXZk
3DIKviI9Czlbx6WJLYdMdUktIqSj51mk+BB+WW/xIfxSiw9VCd691OJDqwjv XkhOGrdsCvdV
Kakh/AqfeHxVUmoIv8Inw994pIZSr2d4aPcmR2wdv7lSU7hvajE6FjyjY6nJ 6FjwjI5Fquf2
rYoyOi0GdP5MYXRavOi8lY3On5h4i5YkRqfFwOj8xp7zlbF5GR0bQawMEc1b 2EZWO823oXJQ
F3aeEnAaZ8PEC9h0wf6v91xc45bGohKOe8Xm9uI2kkak9IUI4OG2UD2S9prr kbRrPZIqsRdO
rUeyiuyFk1u7NVXAM51RshoQc6Swo1ZBugOPwTtqFqR34HmhDldBeluKGklH UkF6F2W3JAO7
fVetgvQuPAbvqlmQ7sLzQq5RPbd35QyIxS7JJDHn0Gnq+yV83VMrYeHBX0ye mgkLDz5Y6qHq
+XrPqCZz2cuXu0nhgOb8XI9X7qaXKXeTyotxcEfAK9PPl0hK4aPmK9PnlUjq GwAr00eimcu+
m8Vcoj9DxjmIyz4RRVxi6iHwMwt9oaSpyVTTNhRT0oSFkoJ4zUlBXJOCVSIF BzUpuIqk4EA2
KThQixQcwMe5vpqkoA+PvXwuUhBLQQy+JFIwkEsKBmqRggE8KRioSQoO4UnB oVE9tx+61SQK
hgyFPJgCh0e8hTyj7EKevlsKrIHB4ZFBb0AajR3fdm6CNptSxyivgqfXKlgz M6IeFw5x7HE8
BXiz11xUHr6D1esIXXF6HaFQPdqQU7oC2OtCBnpuRKHnQl56Lsym50ZMJFQo XI06oqtRz+f3
za25kGBOlCdH3TOEk2yRm/N954kps31NHrvW2zCEEFoxEkloxcZ6E1qxWxNa FSK0YlITWitI
aI3p0ljzk8dProkSY17xWC0kO4ZHsmM1kewEHslOuJBsjGQg2Unl9BYnGXqL yf5bmBmuvedq
RURi+gfehaYK39c8VfhepwqrFFmROlW4ipEVoYvYB6bn28Hge6RpifCKqJUf JPD5wQ8184Mf
8PnBD6784LuURMGHpPzgZ2Y1ZRjg0p7+qRaQ+oQHUp9qAqlNeCC1aVTP0zcr B6Q2qfY2rf2c
JEfA9/swQ6qtPEjVDwtlwEiDPr5yoaBhoYd9wJDoII0HEQAveVmBAC95+loD vOT7aoBXHYBH
Gtc1wFs9gJdsG/UMcq3opwqseMyX/AmV0F3yudDojjQaKqK75LMN+JXkQHfp FzR0zJe8kxR0
Rxoa1Yqi5L9mPLOCwl6uGUp5OfiwzOSRREkv1xH4SupG9bxcd+V4uU4yGNty 9A1p3CClnPwG
/gK6cZV08hv4oOgWVc/Jbw05Tn7rik/LJH+FKOXtd/AX0Z2hpLffwQdHd6R6 3n6P5Hj7fVYS
NhjH3QDC2+/Vgun38DeSoSZMN+CjJKOCMN0gVezWSk1O/NU3kpYW+W/+Wz7x ktQfLCbJNkmp
dApQ0ir5C1T7mW37ncciWZI8JleyBJFieapH6lEx62daWNT2qFdC3Jg0XoiQ 3NWj0NzV45rn
rh7r3FWVclfNOne1irmrZgbNN0g+zUvOgbK0dlOtqLgJHxU/qRkVP8FHxU9c UfGjlKj4SVLy
6hnJYLye1UpiPcPzNM9qJrFe4LnDF6N63v7iVhMDv5B8DPxIwcCviBMDv2Yp lqRjTw5YBoaB
X6n2oztRlDyLCQK/5oiVtIfdghD4lXpSDObv10hCxNSzfHG1R6k5CsOx2rc+ /vg6sr3o1AmT
w+DLE5hekD4M8c8LPgRhnPuCESq2PG/U7UtuHyf5lrNJYgdLfypmYl8mGZIK BY+FN5dPOSXv
06mWETl+u/B3E/DvzhhqWOS7rawT309ijmUh226b6bvf4ffbgt1v+vhBz5++ hf3X6LHkm1i+
XNs2irleC+XpY+byc4UFlJK3FiaglHyZIU5AKXk6rFm0SOac+jmp97MPaRcR w1WQsgM7CNxj
bP6TogQ5awslZ+01J2ftmpytEjnbrsnZVSRn6dMvp0HclKyZx7GzkdrzeNp0 5qFdYfqmrRZZ
24Ynax01yVoHnqx1uMhaWwp940gia+kjDL+Dg8T7O05oxkEJd++oxdZ24Nna jppsbReere0a
1XP3rqSWg24+UDO9yFyYIl7Y5V21GhBc+HvJVbMBwYWPlTxUPZf3JDUg0CcY Lrn87H9wCX/3
1GpB6MFfTD01WxB68MFSj1TP3/uSWhD6uSOjypRd9NXC7X34uwiridsxfHyE K4jbsSTcPqBH
NJbvB7Fph0EUma1g7Let0CtVajVQC7wP4O+jgZrg3YePkfwKgndfEnj3qVYU 2PY4DKejjcxo
6Nhex7Nnvy/j9YFa+D2Av58CNfF7AB8zDSuI34eS8PuQakVdJ9Zz6u8Yl5dk lkmmFe79dvz/
lfjGEcr4xoXSg8JfOMpqhkyvR8k+2orZzOifFuWe+Qn8C9OKcunT6BYNbGkn /3zn8nNClNXm
g5Ov+qusK/0p1DseJycV0xOoPtOZBsRMj6Auydjv+8nvyhQB03eCPkZNX6hk zX/9iJ7T//Bt
98TCmGUV6FPPLL7nkOznPMzZR4Yn0YeY2aFjxc5XxTTLo+h8mzO1VZ5HufQS 4CH+gC4Yj/P8
9Wx6HxSYtUcaYySqinxs5BRpL106r0xyv2P4SuGx+w9nS6Z+0a/+iN8rOe+P mPD2R0yy+yPY
qrXHoP0R9JVJm6b098q80VbG5V0ZN3Nl2KxzYkhaGQabeSPpK/POazPvCGJl JNnMO4PNWBSb
eee1mXcIm3k3RHcbvWfM2/qp4We5K0ieOLzdzCimznxyzsRX0tgq2DFAqDc1 9joO9vzla2jX
KKHooZ0gcQ0CKaNpABsEPmD7ZT6od38ntLqDv9uEtgzQPo0OEbcNaUNoALeB gG4DfWrMr84d
v6eVEbPRtgxxa/4ptDfmE7Y3hj4FZl4Nf2HFS0eO1ix15GwJtPVNJHLdNw3Q dd90S8MN9kYw
gca+KfSc30IS0E5aFLJlMEQh59+XQyEsuyWsI3oro8BkMr2k8oOIX0ZkCfTc baGeuw3rudsZ
jPds82aBgOd3l47NtFZQjhBBoAdvC/XgHdhIbYfql45v42T9/O5VqVbfDjxl swN7Y++Q3CWY
sfH+kpdrXcTy+VvwHau7/+oM36XaivaFpViO6V1hx/QuyaBlQyeaF8P9xLzW gMmEkQu+h3uw
XrxniOnTPykokbFHL0J28N9yCSV1NLUTeBmFPVgctk+vAXTmn5b8NFo6XU6Y 9seC//R92Mt9
382JnNBHLhUgN3baF3p9H0iVGzgQKjdwsOZyAwe13ECV5AYOa7mBVZQbOGSJ Tcxx5ERm5Fqh
Y/4Q84Xrfw7Vals4hC/BO1KzbeEIviz0iKtt4UBKMeORpLaFDZSHA74KmJ0y BY0banUsbMB3
LGyo2bFgwncsmEb13N2U1LFgksw5pvZ33FDc17VjpfoUtGPwC0k7VrJPQTsG D5I0hCrn6xoy
KikEnUai/irN2k0vWtMQ4SvNSvsBf4IOuVKK1tJI1l8r87uM6T8a8fu/km/D UEK3l/422gln
CV3aD/j36UR0CV0qGTv388ST4lPni55mLKTTTnMK6Yh27YqYDaWdiuQDtdP1 5gO105oPrBAf
qJ3VfOAK8oHaGfUMSt4ijsygY86IQd/CZpQERfZ0+Up0NmtnSpGB2hl8nHuu JBmoncNjr3Me
MjD1uoZHDOdyyEDtgl6NHEXjQQm+X7tQigDULsAJQO1CSQJQuwQnALVLo3ou fimHANQuM+pk
B4NxnPxkknj39I5vL6Gm4q5/pRYfeAV/J12pyQdewcdJ16h6rn/9T/nANDbl 2mVoBWhGTMWk
2jUR1DmoNRC9mLTjhNFjUKCg8pEUfBkjo5NrDN5V9CauPF5riOyg0xqglZua xjNwKr2HrkQj
45u4MkdNE9lUp2muxDJHTSMiaU0drTetqRs1rVkhWlN3a1pzBWlNnXoGJUe9 E5kDK7bdEjjn
Ri2ccwOPc27UxDk38DjnlgvnsARF5T/zVo4+o3ZLl0jD+Lt2uUy+4lapyQra HTwFd6fkZAXt
Dp4WviPV8/R7OZMVtPv8yQpmssuhEw0Dv23Ggfkdb5Rx/3u10pX38NeToWa6 0oAPmQy3eu5v
SEpXPqB895+2KyUrEcVWqTEr2oNa+csH+IvqQc385SN88PRoVM/nH91qFjU/ 5itxpuQR5sWy
TU4lzrQfLO5EWlqFIwEBlt5pUu1nlqRgSeo03bykTkyE1Mc2hRLJT2tOJD/V RHKViOSnmkhe
RSL5ieQIGSZh52wpzO4s6Vs46HxWi1F+hodHz2oyys/wkP2Fi1FuSgk6XyQx yi9ursPbwaDl
JU8wf+STC7v9i1r08is8QnpVk15+hUftr6R6bv+Gqok13wwGrJk+20B7423M fHMBsOabnHkY
aWVSv1ZGo6BwixeFWxAo/E3OPIw0fcBfzbz7tJXhtRkLopnXkmQzFsMMlX1K 0/UWKdZ0ncaW
tKiBz8Vf4scsxEnLECStqrWoQUrLSXDkcvGpzSSN20EFX4U+XKwzQ6ncb+II 7yC3qdt8+z3L
9WFxlCvTdtuixqZoNnW74wD93vBW0WUGK2e1Rap2am1QuV6tTRfdnvxVUuy8 si2tW2yf2xn7
fPzLm1pF/Rpsm9tCt9lB/3IWXJp//IpjWhSJFNuFFgJx8gVbUgx5/jYOr2CL kynYwnqMSxJs
6SCGlaFIpLTA96nDEONtU96mwxvjdbJjPDb15o6kGK/DEON9UKbB7RhwMV4X MTQ8fY0YYLn3
u7lh3i0pNIhN67qiIoouvT56bIXLoxUGbpnmpU1wuX7Nhb3/3X86Hm1L4P3s Cm3uconMriIP
iUwGe8Z6J4M9t04GVygZ7JE6GbyCyeAeyrw1zXmeBn+Yw9ALysiq9tSqQOzB 5zJ6alYg9uHz
a32uCkQPycgK9SUpqPSzw+RptXGc7Jw50yCYsoZlyo6xWhUgGL4CBKtZAYLh K0AGqHpOP6ic
dsqARTvlZNqRECZbHTOxCYMcCRXfPinILvvUPR14vreEcssOgfuEB/0+6CQ0 zaeX+VgEdjE2
EfxiSIXegVDoHaw59A5q6F0l6B3U0HsVofeQ3kX6kfzr2ebECr3paVAmBB+q hbuH8Lh7qCbu
HsHj7hEX7g6khOAjSbh7RMfdOGhZ2GxbsVXCz0O1oHYID7VDNaF2CA+1I1Q9 P48kNVtEbjYk
Nb/AWGFPj9Tqr4jh76FYzf6KGD42ikn1PH0sSb5nbOR4uh/4pj8jVCZl2ijH aun1jOHvo4ma
ej0T+Bhp4lbP3yeS9HreUTa/as6HDZTy9Xe10Po7/I30riZaJ/BREqkgWieS 0DohOb7eDR0r
+ROmM5oKJXxlmwr7/Yda6P0D/mb6UBO9f8BHS58VRO+fFR06/MnQw+JT+l8/ eXtYPrN7WAZM
ncGfknpYNhl6WHxK18imwbkyKT/gX5lNJGllGGymS+nC2uS1mc1sm+ky9T1t SrKZLQabcWn9
NAS672mLoe/pk+LbW7x9T1vZfU9sw3+2JPU9bTH0PX1SLHibVw9hG0GsjCQ9 hG0Gm9mkdP1b
4Ba8nX/SNFoUC97mPWm2M0+axitT5962pJNmBzGsDMWCd3hvpx0DYGV2kGgJ gR1qBH1GHHtW
CbGsIJDEecetaSGgHS8HepnVgDvCBqrtUgPXKLbCuEDD70HRN6H33yVIMXKL vIoYQdJdV2Qh
3C5Z70K4PVQXwlWoEG7PqAvhVrAQbo96BkXJf79H3pSg1/bUSpnvw5PB+2qm zPfhExT7XCnz
XVcGvXZQUUnCAwbBml0KgDngheAH2ZKEO26piBF6ZRgkCXcp4jmHvBD8EEGs jPDBAIfUM+oh
Tq6qK39WT83YtHQoTKjkkHoAeN9vuCDQldYcxdGqcySJ1Txi4O4OKYj6iBdR H2XzvYdMiPpI
OKI+ogY2x7NAg4KrWczzKA9Fp3klk3lu0McS2fN9z5lH/WuldYSEYNcNQyR2 3XDXG7tukBq7
Vgi7mqjGriuIXU0j+7T80VFol8CvploloCZ4UYN+rGQJqH5swK8kVwnohiEB v+rHpJL4NS3w
+RUUb6TjVx1xBsVpP1jciSO3VKgGFRTriGo/yHGtiReExcNiHYkKi/UT6gHS +vPaS6CtyZLU
0U/ARSX0E+NfSgynfdHfFp+ylHOLP+FMOaf9YMHiUy2NaQ+ALf4U5SZWz2ay 3CwWfpojzZoq
6A39QVQXPpmWxfJ9Dyn8PaXQo34mUgJEP1tvCRD9rJYAqRB61M9qCZAVRI/6 OfUM8gMz+B7c
YVqtoExbkX6uVFuRfg6etdPPlWwr0i/AM8n6BU9bUeotDY8fL9yK6fDpF1R7 O03OmXBs80VZ
l+gfRVmXIjl6/XK9OXr9suboqxRlXdUc/SpGWVcGW5QVLdJNkdlyksukRNB1 pRRpr1/Bk/bX
apL21/Ck/TUPaZ96acMHXdekakFXg2pvD47/80fZw65G3vxEvVFsXKbeoG5o 8PWai3x0S2Pi
QjXRcyrTvvfPe+vzWeTzxS3UWqJrSC43SqfBtfzCxZQtnNPgGmfhYtoPFr25 gaqx9RrJ8q5Z
3ILZXUtHolxLp4YLMzyBl/I8TKVmui6nrS3t7/wyOz29KlTXebMvenb2ha00 TBeefblBOSdO
iQG5+k3eAZ/W3fU/pifn1p/+n70raW6U16L/5S1fVerLPCzeImToTAZM4kwb itjY4GBsMziy
f/3DdvK100FCgiu1bLHpql6YgHSvdM65U4K4Lx0qDFxVWTxDq7J4JBc28PNv v16cPYO5YQjy
YoPCiw2MFxusXmyQvVhH4lcmzxRNrBdbbtvNoHkJdGZyQ2cmF3Rmiiliz/s7 P+zPxICXJmNt
Qd4PVu3P1MSvTJ79Na0C+2PFL02Pl/E1ETh+sQTBZqs4Xyrn85aWZ7HmS1nE fKncHee9MnmW
Z5GKCIYRlbFZhRN4fIuL/H/PNcnifsOTLO7rJAuZ5P/7OsliHeX/B3xB0+/j vMKIlcaDWtkV
D/DZFQ9qZle04LMrWkzZFfdCsitaYpq2Nlr4pq1pnNieM3Ht+f8ruPqjUn1a G4/wkahHJfu0
Nh7ho6NPmnyu/iTbQNPGEz5X3QkY+PoT4sXXnzUeYtGzmEYUeX/nB2V/xhR8 PLNGup7Jka6n
v7AyeTb3jL2IsvMk/Ipx0ljdS6W8PZLVveCBwvId0ShyM5T9zfgqzo1tvAhS 0F8oFPQXjIL+
wqqgv5AV9GcqBf2Fu4L+ik9uYJQuX7np5q8euHT5Kkg0f6UQzV8xornDKpo7 ZNH8VRO/Mnkm
52DPmNNw+qmb05udU14xh/si7Ml+OYze9WGHLlHlrehYD2I+6dhvXNOx3zY8 HfutTseWSY9t
1+nY66jHtrFn0DB0bT/MEGT2J2y306ui1LTVyr5uw+sLHTWzrzvwmleHKfv6 TUj2dUfM1LyG
i7WiuYNXCbu4aoVdXPiwi6tm2KULH3bpWvJ5eFe6otYunj1ln3iZUYCAmkL1 CvO/e9x1vh52
139/S7lKhp73lwhiD/EkiJ622QTRs2qCKBFB9LyaIK4hQfQQqV43TXrDL35Y BT76aoXyfXha
46sZyvfhqXafKZTfQyLgY1+6UH4fH8rPHpB9iJZ2u25EDSH7RVnR7xH3qNw7 oTot6rnU3/Ju
/SXA+M5zgFjjfbMHiDWCeoCYTIAxqAeIrSNgDDxSROEbYqwAGAOlhog1BvAq 2UDJIWKNAbxy
O2AZIpZ7R8MDxlATE1EILV4RhVCtmGEIT2SGasYMh/DkeujJ5+FD6To2jbD2 du62/Xn2KjWD
GlViUKSsxhFeJ/l8yetwlCYl5gd8WODzA0aIbX5ANfY45lofPN7w+uBxXR8s E3sc1/XB68ge
I01EPlqkVrZKBM95IjWzVWJ4Hh4zZauMhVQOxoKKhGPC9N0MhNmj34dvaV9P 1AotJvDsJ1Ez
tJjAM/JUk8/XU0uMr6ceL6UoVUsLnsDfQRM1teAJPC6aIPk8/EOTcyDnB0W1 +ghTpfnBWq3+
Qa5WH5WVeIBTED4QaUr9JDsc2TJzkQSZuQh7upzN69PD7CmW++/7031WUUpu 1ypZ9YywG+B8
Zg7/0a+2MaVqdGAjcHVwqjGrg6Qvn2K3KVrsTsa7f3P5b30Ijmiq6vVT7t0Z p16hoVFZ17So
vUirX7KR9KzAHTsjo6TdzrC758fX4RL9BNPrME6cMMn2BTMCfWVbh3pJiX3m 4Q1pnGZv0vmm
ro9zxZjsROgYYTD9wm9+fO5GGTL4F9D9dLEtkgCfjkZEF2uFwRx7uB19rsjN uxt8/6Yck5jM
n/a///x39TYt58nbsJ68jbWFUTSc+B1uG4D4bcC2x3UDEOgG7GB53h+H2qq/ jWaV2rnYHK1/
x+K5+Dse7OIj8j3m/LjB8wAKw8JztPpdjefC71rlFh7D8HfxUfL5JGrXmP/2 894uTfZ3iQ1+
8i7mHOr/D93f2sNPhF10Lly9K4kqCvGPEC7ur2I16mu5hC6zR7NrF2E6+Lf9 Wem92yPtXejl
VfCV3rt9kL0rs6D7FsWC/qGNlF7SfY+4pHlspvySor+1pAcaxZLOz7io67Sr LOcBqQ19PlIq
vZwH3l9bzoIbcmUtqxzVhxrAYq7KXxUv00M6FFP6Oj2ElxMP8XIiNRWvYilH WMdLYyArObLk
spIjj6+VHMGHlY61v2slx9gbr+cm1ifnr2Ijx55cNnKM+NrIiaDs7RPSxpmf WkGVjTuRbONO
OG/clqShli2KUMsME2rZYg21bJFDLXR6+ZaglslbFK1CtzHdaW3WVqG2BrEy gpqo2hQ2s4Np
Jm2z2owNYTO2IJuxKWxmBzMZC2F3r+Tb5MVVfrzNNN+C9VPGOV15PyhU0sRH gvRTLLeijZzq
p7yCQLpW1HDWISmiBOlT17D3+TIXd9kE6fd+5a4TtfKpX/BTPnWNp96vayIL K/QznoUV+tlm
F1boZ3VhhUSFFfpZXVixhoUV+rmGT7XO3iB0AjtOorS9dP+yhE8/V6qyQj8H l/z0cyUrK/QL
8KxW/YKlsiL3kgbPxdQvPCkFgjwo9yeJyEGXSxJxyUiD835QCEppwCcwibi0 8PXME79NRyMu
iwZl5H0u9Ifg+4git724dS7CiR8NwwFlipz+S/v7n/WLlFc6SEO/vXhxMzvl 6L6pYKs645T/
NyHCN735mTddRk6PepuuirbpdscqRzWvLCKeWObJLo+sYVSQaoj0Jir5Fh5x XFu4muiG7no0
pWD09Lel8aO/VzRCdYnsKP0aHyvqflrWLyf5phLctarkR+ktj98yXfNMTNOv PZEqwTXPbs/6
zWZ3e9Zv6m7PMqkEN3W353VUCW4Q/j5N7GA4HNlvkeu826Hbq6AS3CpVk63f gtdk67dK1mTr
t+DJM/odS0127iUNrxLcianJ1u+wVjTwwwzH2xmCtgcO8ueVCqW9/U6p+my9 Aa9kNZSsz9Yb
8OpqA8nn7bqYbC9dx1rR4k6v4OG6Ur06dR3+FjKU7NWpG/DIyPDk83BDzHw/ 3SRhmdjPPmpx
o2e8Z1gpymeqFeUz4e8hU80oXxMeGzUt+fy9+VejfN+K9b6/F9bqrn+K9rd+ 2PkeyPv85u/P
tLBnTuyO/1Dx8x+A3UAnSKgeQAgC0D0AkYERxSPuCRXfEdUDsKsQJ5HfpvqO e+xCzJUbqifg
4XGUHRNtJ6B5ygO+9tLtUT0AbxJx7EZUi/GAXYzP64/mGajoPuWSYJwXWfoR jb/KT9fXW6wp
vS1iSm9uRJIqFsZnZbzilbnWMCuDWFcGQawM95jxo4aPGYeJH6bUfZX0R4tX vPjRw18TSfaS
vUrtaCqE3R65ht2eNjzs9lSH3WQKuz3VYbd1DLs9Yc+gOPvXXvYDKM3Wn9WK tj3Da0rPakbb
nuF1zhemaNujELb+Iija9oK1ol4wfJvnNpV28Re1Qmyv8DLSq5ohtld4afMV yefijqAQm4O1
oq4fxYk9jOwMGCT2So6s/ZV2WcH9HbXibw78vfSmZvztDR4rvXnyuf+bbLPy 9DZJs1koi9cL
lZIp279dpN7kSVZU6k0bnyjkxnH26d8amfaohDGPY/V4m2e7Xr2jicwL71g8 BaqOt9kCVQfV
ApVEApWr1QLVGgpUrlWYWJJB28p5Ja5aONaFx7FdNXFsFx7HdplwbMcSgWO7 gvLIelgrSiq1
K9Z7aiWO9eDVlZ6aiWMevOLnWfI5uCdpewiPoj1EG5OQ4rO2h/DJ7SHaWkl2 CZx24ePbDyyb
ki9A22mbOvnCLxpq1b8rSd99gDbSOWsclcwF6WOvl8iN02DV8cL3w0rF5xHi kjTS58rJ+xvO
yfs1J5eJk7/XnHwdOfm7VXyo2+EwsZ1/p8iUxu3vahHzd3hiHqhJzAN4Yh4w EfO+ENweCCLm
A43W538jIbtdbeSWPlCLtA/gSftATdIewpP20JLP+UNPjPOH5CzRitLcUK0s 0SH8xTRUM0t0
CA+WRpp8Xj4SlCU6wqdapEHijzKPzpy7gqOP1MoVHcNfQmM1c0XH8MBojORz 9EjOGU55ausP
Dd7PnzqjR4zzePJ+sLoTvlVJH4ZeGYroRB9TFBqzRidiDWJluEcnYkLz6jiJ hlPm8ETMLTwR
Y0+B+dD5xdve+eF7XKlElPQCiVb4AosRs8s14/ge2E1LnKjnfguMBFqVcfH6 lE81beLxDIwk
aLMDI6lWB0YkCoykVh0YWcPASMqbQaVqMagJPIOaqMmgJvAMasLEoBJPBIP6 EFRt94Efdzis
Kod+qBXx/IAX8ZCaEU8ELywjTz4fR0hOlWRK0TorwQyymrK2zpqSW2fFVFrA lPs03CnWfh4y
eHXdyZ6SHZAMUsAU8ZICZhqxgBqQAB+W5OgzfKM+N3PHDuQrlhwDPPOE5Vce 8ZERZlybcm1v
eFOu7bopl0wywnbdlGsdZYRtxI9d7KiVbLEDj4l31Ey22IHnabtMyRYzIQ07 dgUlW+zylgp3
1ZIK9+Clwj01pcI9eKlwD8nn6PuCpMJ9i0yJbD+23z79oLy376slGu7DX0YH aoqGB/AA6cCT
z9sPJBUNDylEwxkmgeiQVTQ8JIuGeWIdg3oFvTIU/fZnGDn1kLXf/iGCWBlP zMoc0dgMpiT+
iNVmjiBs5oi70HyEPXMs1+ncu0GXQWQ+4iYyHwurPzcuLC766DHX+vPjDa8/ P67rz2XSR0/q
+vN11EdPiKV4GTB2OxWo1IlaVOoEnkptqUmltuCp1BYTlToWUqWyJaji3MbP chsmdpxkP2lX
cHNbrdpyG17Vs5WsLTdOwZVm49SSzs2NUzG15cYp4tPx0dCUinQaGvjtY2hK RjoNDRwRGWea
fA5+JibSaZxxjnQaZ0pFOo1z+PvnXMlIp3Huwa8kks/RL+QsK89TKH/o2Mf5 sQ/jgrGsPO8H
qztxRKNj4zVVKB3buMDaz31mDe3FxJFLd6EHfQramcGcfrbZ+24xJInbuNQ4 SdzGJWmc+Pcv
WFW7HYOm8atheiXfCj+pfalmgeVOG00uicnGJc/EZOPXZicmG7/qxGSJhHfj V52YvIbCu/EL
8ZTkjCu1GPsVPGO/UpOxX8Ez9msWxp57OcMD+WtBjP3a49ju0bhWi67fwNP1 GzXp+g08Xb9B
8nn5rZjEZOPW4qzL3SoVSDdu4S+hOyUD6cYdPDC68+Rz9DsxgXSjgbWi365d wc0bSgXSjQb8
LdRQM5CuwyMj3ZLPzXVBgXQda0XD0LW7C8nVD3v26uCt0k5vqEXVDfgbyVCT qhvwKMmUkKqb
lpwxN7O4qiYngrOMuZmMVTV5P1jdiYtqER/glWlqFCuTX1VjNBmravJ+wL4y Td5VNUaTXFWD
iUjSxB+bBSU2uWtAFemzxJXYtPhE+iyeJTaGtdklNoZVl9jIFOm7r0ts1jHS d2+RsnJtJ+zY
wzlkyv5OBRZxr5ZCeA+PfR/UVAgf4PnYA5NCaAnJ3HuQs2tBHvD5gZUtTOZe ixUrt8hYuUmV
udfijpVbWPt5irI9hk3fa3GDz494sXhuvYB5ci980PMjV/T8uOHo+bFGzzKh 56caPa8jen7C
nkF+OEoTe+RX6PVlPKmFmp/gUfOzmqj5GR41PzOh5kchqPlZUtT8QoGaHzGo +YUVNb+QUXOL
CjW/cEfNL1j7OcvOj6iKxPxSHiODfd6rhhfQB8PJT1awMHaGj3y1ij6yVbJi 5hW7M368fPnz
dJ4jll2Z3MYSGq8IL+bPX+EUsnCnQwBbJY8ih/Dd/3z/cADq43ClPs6GUx+n pj4yUZ+3mvqs
I/V5I0xGC+009Mepay8ObyeowIHe1OJAb/AcqK0mB2rDc6A2EwdyhHCgtqQc qEPBgV7zR8kb
HVYO1CFzoDxwToUKgUlCB2s/p51OZYbQQbwYgquRGEJ2o7Td0yDgxg1cgsgW u1ECyg08D5wb
uJ5IbuBybR/Q3fD2Ad26fYBM3KBbtw9YR27QxZ5BaRjM393t2Is1c4JFhhFQ HWJPrVqFHjzC
7alZq9CDZ10eU62CK6RWwZO0VsGjqFVwMbUKHmutgkeuVehQxUs8jzdX8LH2 c+eH75VyinyL
V0swH3t8uGHn3Emcb0s99ioAdfOUJOKnoxHRP1pf15C+vIX+XPwcG1lkRf3v P/9ddZlybtjX
sE/fLWQGpOXvk7MRHmHzusxTj98O9D2KHeDAnvpc2dP7hrOn95o9ycSe3mv2 tI7s6R0RuzI5
qziqNFcK1OJKATxXCtTkSgE8VxowcaW+EK40ENSCbeBx7bQ4UKsHWwjfaSRU swdbCN/9JkTy
uflQUA+2oUW800d+GFfw8qFaSRJD+CtopGaSxAgeFo08+bx8JKgB2xhrRTCg fUzKc+iM05yl
/+n1/4Aru3n65dgj6ZcXn3IgjVw5Lshr6AzLzgqIqpZA/tCFdy3w7IHIYs4e IH4zSaJd/eLX
kEoJ3y0pFUdYMDDOSP5n17KVg2KvUgMXm6NUGWs8xeLYEpk8Ens85c8Ybbb8 mWi1/CmR/JlY
tfy5hvJngj2DRtEw+0kytf14VQW1FzdXaVCVqCWRpPASSaqmRJLCSyQpk0QS eyLI00SQRDKx
eA6jmKglkUzgJZIPNSWSD3iJ5MOTz8s/BEkkSOM8jAKp1aUewV9CSM0u9VN4 YDS15HP0qaAu
9dNigadKyGOmVv7CDP4WmqmZvzCDR0bbmnxuvi0of2GbpCfby5m7NkQzrG21 aPoO/G20oyZN
34FHSDsS0vRdSYe/7xYPf88JxC2LO3ZZh7/vEoe/51cc0ATxuAyiyAmd/VwZ zCCKPY1xZXJ+
UGJluPfR2sOeUc0v1LgsY6CJHO95vCLHe0zRS9pY6lbJt9kHj2PbfFr27nPt W7W/4X2r9uu+
VTKFFw/qvlXrGF48sAqPbtv5Omcr8JUDtQIOB/C0+lDNgMMhvNRzyBRw2BfS uOpQUMDhSCMO
uBl27RXIVtrbj9SKOhzBc+ojNaMOx/A6z7Eln7cfC4o6HCOa8CKU15+oFYQ4 gb+ZTtQMQpzA
o6UtTT6v35K04cwWRcOZPUxzyi3WhjNb5IYzuYnt9NIQ8MrYFG079zFqrc3a ttO2AFbG1gSt
DIXNRBibsVltxkYAaq0txmbyOvH8WBk/X8c2TxltJu8Hqyvj07R6zXtjPitD YTN9C7MyiHVl
EMTK8G5sZWqESRlOZ6W5FYXCb2qFUzH8ck1nTc0TNV3avPN4iO2mxrOVkXm2 2a2MzLO6lZFE
Yrt5VrcyWkOx3TzDnkHD0LWHI7di8Y55rhQDN8/BGbh5riQDN8/BGbh5wcLA c69ncAZuXohJ
AzQvPAFj5M0LpXIAzUtwbdi8VDIH0Lz04FcSyeftv8SU6pm/CBGGQbbvfgbv gZq6m7+UiqOb
v+DvpSsl4+jmFTxWuvLk8/krMXF08xprRaEz8XtzRg8B6K+VCqSb1/AX07WS gXTzBh4s3Vjy
ufuNmEC6eYO1ot+uXcHNb9Xi7bfwd9Gtmrz9Fh4f3UnI2+/kjJznxSr+jGjl hE6WEa071ojW
HTGilRtJYoiugEW0GlpBq8OzyF28EW3LQ7NRGNYalysVMRve3xzlaDZQ9VGO P3bYQtBNF01d
5Dh3U+dZFmPqm10WY+p1WYxMkTqjLotZx0idgec689vLtYPsLrOddrUOxqah lppnwKNVU001
z4RnUCaTmqeLyJg1TUFqXhNrRXF2kgQuRMsOs6mWlteE1/Kaamp5FryWZ1ny ObvlyUnyreLG
FDlMbkny7xkbU+T9YHUnGlpJCghM8u+x
Re: [ATL] metamodel element uml::Class not found [message #81314 is a reply to message #81262] Thu, 15 May 2008 12:57 Go to previous messageGo to next message
William Piers is currently offline William PiersFriend
Deepak a écrit :
> Hello,
The problem is that you're trying tu use an UML model as a metamodel. If
you want to use a local file for the UML21 metamodel, you must take the
..ecore one, which is available in org.eclipse.uml.uml2 plugins.
William
> occurs.
> model UML
> model UML
> Cheers,
> Deepak
Re: [ATL] metamodel element uml::Class not found [message #81497 is a reply to message #81314] Fri, 16 May 2008 19:00 Go to previous message
Member
William Piers schrieb:
> Hello,
> Best regards,
> William
Thanks !!! The using of the uml.ecore file fixed my small problem.
Deepak
Previous Topic:[ATL] transformation of UML metamodel specialization
Next Topic:[ATL] How can I set namespace of classes in uml2
Current Time: Sun May 27 12:09:16 GMT 2018
Powered by FUDForum. Page generated in 0.01654 seconds
