Home » Eclipse Projects » Virgo » Uses Violation: Conflicting Packages from Kernel and User Region
Uses Violation: Conflicting Packages from Kernel and User Region [message #739252] Mon, 17 October 2011 09:04 Go to next message
Vladimir Stevanovic is currently offline Vladimir StevanovicFriend
I'm trying to start PAR file in Virgo 3.0.1, containing several bundles. After failing to start it, I've used OSGi state explorer to diagnose the problem. I've got a lot of uses violations and among them some very strange:
Uses violation: <Import-Package: org.springframework.remoting.rmi; version="[2.5.0,4.0.0]"> in bundle <org.gs4tr.editor.trasnstudio.par-1-gs4tr-tm-lucene_3.0.30.SNAPSHOT[1318841157640]>
Found conflicts:
package 'org.aopalliance.intercept_1.0.0' in bundle 'com.springsource.org.aopalliance_1.0.0[31]' used by 'org.springframework.remoting.rmi_3.0.5.RELEASE' in bundle 'org.springframework.context_3.0.5.RELEASE[25]'
conflicts with 'org.aopalliance.intercept_1.0.0' in bundle 'com.springsource.org.aopalliance_1.0.0[69]' used by 'org.gs4tr.tm3.commonlayer.lucene_0.0.0' in bundle 'org.gs4tr.editor.trasnstudio.par-1-gs4tr-tm-commonlay
package 'org.springframework.core_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[83]' used by 'org.springframework.remoting.rmi_3.0.5.RELEASE' in bundle 'org.springframework.context_3.0.5.RELEASE[82]'
conflicts with 'org.springframework.core_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[24]' used by 'org.springframework.remoting_3.0.5.RELEASE' in bundle 'org.springframework.context_3.0.5.RELEASE[
So, it points to the springframework bundles from both user and kernel region!!! I thought they were completely isolated. I haven't changed any configuration file in VTS. What could cause this type of error?
Re: Uses Violation: Conflicting Packages from Kernel and User Region [message #739293 is a reply to message #739252] Mon, 17 October 2011 10:03 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn NormingtonFriend
Certain packages are shared from the kernel to the user region in VTS. Take a look at the user region properties file in the config directory which contains the following property:
packageImports =\
org.eclipse.virgo.kernel.artifact.*;version="0",\
org.eclipse.virgo.kernel.core;version="0",\
org.eclipse.virgo.kernel.deployer.core;version="0",\
org.eclipse.virgo.kernel.deployer.core.event;version="0",\
org.eclipse.virgo.kernel.deployer.config;version="0",\
org.eclipse.virgo.kernel.install.*;version="0",\
org.eclipse.virgo.kernel.osgi.*;version="0",\
org.eclipse.virgo.kernel.model;version="0",\
org.eclipse.virgo.kernel.model.management;version="0",\
org.eclipse.virgo.kernel.module;version="0",\
org.eclipse.virgo.kernel.serviceability;version="0",\
org.eclipse.virgo.kernel.serviceability.*;version="0",\
org.eclipse.virgo.kernel.services.work;version="0",\
org.eclipse.virgo.kernel.shell;version="0",\
org.eclipse.virgo.kernel.shell.*;version="0",\
org.eclipse.virgo.kernel.shim.*;version="0",\
org.eclipse.virgo.medic.*;version="0",\
org.eclipse.virgo.repository;version="0",\
org.eclipse.virgo.repository.*;version="0",\
org.eclipse.virgo.util.*;version="0",\
org.apache.commons.logging;version="[1.0.0,2.0.0)",\
org.apache.commons.logging.impl;version="[1.0.0,2.0.0)",\
org.aspectj.*;version="[1.6.5.RELEASE,2.0.0)",\
org.osgi.service.event;version="0",\
org.osgi.service.log;version="0",\
org.eclipse.equinox.region;version="1",\
ch.qos.logback.*;version="[0.9.24,1.0.0)",\
org.slf4j;version="[1.6.1,2)",\
org.slf4j.helpers;version="[1.6.1,2)",\
org.slf4j.spi;version="[1.6.1,2)"
Hope that helps to get you started. See the FAQ for general guidance on debugging uses constraint violations.
Re: Uses Violation: Conflicting Packages from Kernel and User Region [message #739342 is a reply to message #739293] Mon, 17 October 2011 11:19 Go to previous messageGo to next message
I found the uses violations (org.apache.commons.logging).
Re: Uses Violation: Conflicting Packages from Kernel and User Region [message #739343 is a reply to message #739342] Mon, 17 October 2011 11:20 Go to previous message
Great!
Previous Topic:how can I run applet application with virgo
Next Topic:Eclipse Server Runtime Environment for Virgo (Jetty) 3.0.1
Current Time: Tue May 22 06:35:49 GMT 2018
Powered by FUDForum. Page generated in 0.01898 seconds
