| Java error "java.lang.NullPointerException" [message #736738] |
Fri, 14 October 2011 05:31  |
samer borgi Messages: 10 Registered: October 2011 |
Junior Member |
I get this java error while running an application that needs internet to set up an account(adoble flash player and java updated):
at com.positscience.bfc.license.BFCLicenseManager.init(SourceFile:58)
at com.positscience.bfcapplication.views.BFCHomeView.cJ(SourceFile:207)
at com.positscience.bfcapplication.views.BFCHomeView.(SourceFile:135)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:170)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:788)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:235)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:69)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:327)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:227)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:299)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:531)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:179)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:268)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:400)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1604)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:649)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:576)
at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:563)
at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:270)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:931)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2497)
at org.eclipse.ui.internal.WorkbenchWindow$23.run(WorkbenchWindow.java:2837)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:2818)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(WorkbenchWindow.java:735)
at org.eclipse.ui.internal.Workbench$20.runWithException(Workbench.java:1023)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3425)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:797)
at org.eclipse.ui.internal.Workbench$25.runWithException(Workbench.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
at com.positscience.bfcapplication.Application.bI(SourceFile:261)
at com.positscience.bfcapplication.Application.start(SourceFile:134)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
so what should I do to fix it,I'm using windows 7 service pack 1,64-bit.
| Re: Java error "java.lang.NullPointerException" [message #738486 is a reply to message #738284] |
Sun, 16 October 2011 05:46   |
Junior Member |
I uninstalled all the previous versions and I have updated my java,I have java 6 update 27 (32-bit version) and java 7 (64-bit version),but still getting the same error message.. I have JRE versions,I don't develop Java applications and applets, so I don't need the JDK
I also found this .log file,it contains more details about the error I think..It is attached to this message
[Updated on: Sun, 16 October 2011 06:29] Report message to a moderator
| Re: Java error "java.lang.NullPointerException" [message #738904 is a reply to message #738758] |
Sun, 16 October 2011 18:46   |
Junior Member |
I attached 2 screenshots about my application.
Before I can begin to use this application,I need to activate the software, and set up
my personal account. To complete this process,I must be connected to the internet,so I can activate my license.
When I click set up account ,I get the blank screen and when I try to close it using the task manager ,it gives the error code "java.lang.NullPointerException"
Thank you
Attachment: 1.jpg
(Size: 52.99KB, Downloaded 65 times)
Attachment: 2.jpg
(Size: 88.41KB, Downloaded 67 times)
[Updated on: Mon, 17 October 2011 09:54] Report message to a moderator
FUDForum. Page generated in 0.05503 seconds
