Home » Eclipse Projects » scout » Remove unused translations ?
Remove unused translations ? [message #735391] Tue, 11 October 2011 16:48 Go to next message
Jeremie Bresson is currently offline Jeremie BressonFriend
After big modifications in my application, I have a lot of unused translations entries (most of it is garbage).
Is there a possibility to detect (and to remove) all unused Text translations defined in the I18N properties files (Texts_de.properties, Texts.properties, ...) ?
I am looking for some Scout SDK support (maybe in the nls editor ?) or for any other kind of scripts.
Re: Remove unused translations ? [message #735548 is a reply to message #735391] Wed, 12 October 2011 07:20 Go to previous messageGo to next message
Andreas Hoegger is currently offline Andreas HoeggerFriend
Open the NLS Editor execute the 'Show NLS entry usage' context menu on
any entry. In the first column the number of references to a certain
entry is displayed.
Furthermore you are to find the usage in your code with the 'Find
references to 'aKey'' context menu.
/andreas
Re: Remove unused translations ? [message #753440 is a reply to message #735548] Thu, 27 October 2011 09:26 Go to previous messageGo to next message
No Message Body
Re: Remove unused translations ? [message #753441 is a reply to message #753440] Thu, 27 October 2011 09:28 Go to previous message
Thanks for your answer. Do you know if there is a possibility to have some kind of script?
If "entry usage" == 0
then remove the text entry.
This script could use the SDK or not...
Previous Topic:create permission
Next Topic:Javadoc / Eclipse help
Current Time: Sun Feb 25 22:17:20 GMT 2018
Powered by FUDForum. Page generated in 0.01605 seconds
