Home » Eclipse Projects » Eclipse Platform » Mac snow leopard update site issue
Mac snow leopard update site issue [message #734418] Fri, 07 October 2011 17:20 Go to next message
RJ  is currently offline RJ Friend
I am trying not able to update eclipse indigo on Mac osx. I get org.eclipse.equinox.p2.core.ProvisionException and nested org.apache.commons.httpclient.NoHttpResponseException. The laptop has internet connection and what I noticed that problem is only with eclipse trying to connect to internet. I have tried both 32 and 64 bit version of eclipse. Internet is full of provisioning exception dating nearly 2 years back, however clear solution is someone missing my eyes. My laptop has direct connection to internet so reaching download.eclipse.com should not be an issue. Wonder what is wrong?
A quick response will be highly appreciated otherwise i will end up installing windows on mac.
regards,
Rajic
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at download.eclipse.org/mylyn/releases/indigo/compositeContent.xml.
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:189)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile(CompositeMetadataRepositoryFactory.java:73)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:98)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:749)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:117)
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:102)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82)
at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.apache.commons.httpclient.NoHttpResponseException: The server download.eclipse.org failed to respond
at org.apache.commons.httpclient.HttpMethodBase.readStatusLine(HttpMethodBase.java:1976)
at org.apache.commons.httpclient.HttpMethodBase.readResponse(HttpMethodBase.java:1735)
at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1098)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
... 1 more
Re: Mac snow leopard update site issue [message #734522 is a reply to message #734418] Sat, 08 October 2011 06:03 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
Which JRE are you using?
Dani
> regards,
> Rajic
> repository at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 1 more
Re: Mac snow leopard update site issue [message #734674 is a reply to message #734522] Sun, 09 October 2011 07:24 Go to previous messageGo to next message
Started with Default apple 1.6.027 java and jre and now switched to openJDK 7.0 from code.google.com. Am using eclipse version 3.7.1 and build no M20110909-1335. Still the same error. Wondering if I can run updates in verbose mode just to check which java library are getting used during updates.
Re: Mac snow leopard update site issue [message #735509 is a reply to message #734418] Wed, 12 October 2011 03:34 Go to previous message
Deepak Azad is currently offline Deepak AzadFriend
> regards,
> Rajic
> repository at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 1 more
Could it be that you are behind a proxy?
http://stackoverflow.com/questions/1500646/eclipse-3-5-unable-to-install-plugins
In any case, copying this to the p2 forum.
Previous Topic:How to add parameters to CommandContributionItemParameter
Next Topic:How to call a handler from a popup menu or generate an ExecutionEvent?
Current Time: Wed Apr 25 07:14:42 GMT 2018
Powered by FUDForum. Page generated in 0.01915 seconds
