Home » Language IDEs » ServerTools (WTP) » After upgrade of JBossWS, runs clean standalone, not as "Server" in Eclipse (JBoss 5.1 configuration won't run in Eclipse after JBossWS upgrade)
After upgrade of JBossWS, runs clean standalone, not as "Server" in Eclipse [message #734051] Thu, 06 October 2011 14:11 Go to next message
Steve Cohen is currently offline Steve CohenFriend
Member
I downloaded and installed JBoss 5.1GA, also the JBoss plugins for Eclipse on my PC (Windows XP). These allowed me the option of creating a JBoss 5.1 Server in Eclipse pointed at the local installation. Everything worked either standalone or in Eclipse (but obviously not simultaneously).
Then I upgraded the jboss web service support to 3.4.0, the highest that JBoss says is supported. This put some new libraries in the installation.
Now I find that the JBoss installation starts and stops clean when run standalone(no apps are deployed and no errors) but the Eclipse "Server" config that runs the same server will not start without errors (which, however, are not fatal). Can someone explain what's going on here and how to fix it?
[Updated on: Thu, 06 October 2011 14:16]
Report message to a moderator
Re: After upgrade of JBossWS, runs clean standalone, not as "Server" in Eclipse [message #735220 is a reply to message #734051] Tue, 11 October 2011 09:30 Go to previous message
Wolfgang Knauf is currently offline Wolfgang KnaufFriend
Member
Am 06.10.2011 16:11, schrieb Steve Cohen:
> Now I find that the JBoss installation starts and stops clean (no apps
I am not sure about it, but there is an Eclipse bugreport about endorsed
dirs not being added to the server configuration:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=250643
In this bugreport, you will find a link to a modified JBoss server
plugin, which works around this issue. You might give it a try.
Or you could even use the "JBoss Tools" plugins: http://www.jboss.org/tools
Here you should find all server plugins.
Best regards
Wolfgang
Previous Topic:Re: How make correct configuration for JavaScript work
Next Topic:Eclipse Indigo and JAX-WS Support - why only Axis2/CXF??
Current Time: Wed Apr 25 08:58:24 GMT 2018
Powered by FUDForum. Page generated in 0.01868 seconds
