Home » Language IDEs » C / C++ IDE (CDT) » Somethings not working right
Somethings not working right [message #733572] Wed, 05 October 2011 05:09 Go to next message
Steven  is currently offline Steven Friend
Hi every time I try to start a new project in eclipse, when i get it all set up it returns 4 warnings and an error.
They read: Description Resource Path Location Type
1. Program "make" is not found in PATH New C++ C/C++ Problem
2. Error launching external scanner info generator (g++ -E -P -v -dD /Users/Steven/Documents/workspace/.metadata/.plugins/org.eclipse.cdt.make.core/specs.cpp) New C++ [Discovery Options] page in project properties C/C++ Problem
3. Error launching external scanner info generator (gcc -E -P -v -dD /Users/Steven/Documents/workspace/.metadata/.plugins/org.eclipse.cdt.make.core/specs.c) New C++ [Discovery Options] page in project properties C/C++ Problem
4. Program 'g++' is not found in $PATH New C++ [Discovery Options] page in project properties C/C++ Problem
5. Program 'gcc' is not found in $PATH New C++ [Discovery Options] page in project properties C/C++ Problem
What is wrong? I tried deleting eclipse entirely and reinstalling it and it did not fix the issue. Is it something I did or is the program missing something? Also when I try to tell it to run the new project just to see what happens it says Launch Failed. Binary not found. Any clues would be greatly appreciated. I'm really lost as to whats going on and I'm trying to do some practice programming before my exam tomorrow but I can't with the program itself not working properly.
Re: Somethings not working right [message #733589 is a reply to message #733572] Wed, 05 October 2011 06:57 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
You have to install a toolchain (compiler, linker, debugger etc.)!
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse.cdt.doc.user/reference/cdt_u_prop_build_settings_steps.htm
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Somethings not working right [message #734941 is a reply to message #733589] Mon, 10 October 2011 13:35 Go to previous messageGo to next message
Okay where can I get it?
Re: Somethings not working right [message #735167 is a reply to message #734941] Tue, 11 October 2011 06:54 Go to previous messageGo to next message
Here is the correct link
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse.cdt.doc.user/concepts/cdt_c_before_you_begin.htm
Before you ask
- search this forum
- google
Re: Somethings not working right [message #750518 is a reply to message #735167] Tue, 25 October 2011 20:37 Go to previous message
Hi thanks for the help my teacher ended up helping me. it turned out that i needed another part of xtools
Previous Topic:CDT and embedded device development
Next Topic:Makefile colours
Current Time: Sun Feb 18 09:24:56 GMT 2018
Powered by FUDForum. Page generated in 0.01914 seconds
