Home » Language IDEs » PHP Development Tools (PDT) » Eclipse can't follow updating
Eclipse can't follow updating [message #731231] Fri, 30 September 2011 10:49 Go to next message
forsoap is currently offline forsoapFriend
Hi all,
please help me, I use Eclipse Helios with PDT on Fedora 15, and I can't update the IDE.
Below the error message:
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse Java Development Tools 3.7.1.r371_v20110810-0800-7z8gFcoFMLfTabvKsR5Qm9rBGEBK (org.eclipse.jdt.feature.group 3.7.1.r371_v20110810-0800-7z8gFcoFMLfTabvKsR5Qm9rBGEBK)
Software currently installed: Shared profile 1.0.0.1303939529128 (SharedProfile_PlatformProfile 1.0.0.1303939529128)
Only one of the following can be installed at once:
Welcome Framework 3.4.100.v20110425 (org.eclipse.ui.intro 3.4.100.v20110425)
Welcome Framework 3.4.0.v20100427 (org.eclipse.ui.intro 3.4.0.v20100427)
Cannot satisfy dependency:
From: Shared profile 1.0.0.1303939529128 (SharedProfile_PlatformProfile 1.0.0.1303939529128)
To: org.eclipse.ui.intro [3.4.0.v20100427]
From: Eclipse Java Development Tools 3.7.1.r371_v20110810-0800-7z8gFcoFMLfTabvKsR5Qm9rBGEBK (org.eclipse.jdt.feature.group 3.7.1.r371_v20110810-0800-7z8gFcoFMLfTabvKsR5Qm9rBGEBK)
To: org.eclipse.platform.feature.group 3.7.1
From: Eclipse Platform 3.7.1.r37x_v20110729-9gF7UHOxFtniV7mI3T556iZN9AU8bEZ1lHMcVK (org.eclipse.platform.feature.group 3.7.1.r37x_v20110729-9gF7UHOxFtniV7mI3T556iZN9AU8bEZ1lHMcVK)
To: org.eclipse.ui.intro [3.4.100.v20110425]
Please, any help well come.
Thanks!
Re: Eclipse can't follow updating [message #759929 is a reply to message #731231] Wed, 30 November 2011 15:30 Go to previous messageGo to next message
Martin is currently offline MartinFriend
I have this same issue. Is there a general help topic for resolving this sort of thing? Not seen one yet but still looking.
Re: Eclipse can't follow updating [message #760070 is a reply to message #759929] Thu, 01 December 2011 08:38 Go to previous messageGo to next message
Toshihiro Izumi is currently offline Toshihiro IzumiFriend
It seems that this indicates you installed Fedora Eclipse but not Eclipse.
You can update via Fedora repository but not Eclipse repository.
Fedora Eclipse is being modified from Eclipse. It will disable update via Eclipse repository, or it will damage some functionalities of the feature which comes from outside Fedora repository. Do not mix Fedora Eclipse and Eclipse. You must use Eclipse which is available at http://www.eclipse.org/downloads/
Re: Eclipse can't follow updating [message #760136 is a reply to message #760070] Thu, 01 December 2011 13:08 Go to previous message
Many thanks to Toshihiro Izumi as uninstalling Eclipse and then reinstalling from the download site appears to have fixed everything.
Previous Topic:Zend debugger installation for PDT 2.2 fails
Next Topic:Weird behavior with the editor.
Current Time: Sat Jan 20 11:27:34 GMT 2018
Powered by FUDForum. Page generated in 0.02805 seconds
