Home » Eclipse Projects » GEF » Using different connections in the same viewer
Using different connections in the same viewer [message #78782] Thu, 08 May 2003 20:31 Go to next message
Stefan Junsved is currently offline Stefan JunsvedFriend
Member
I'd like to use different connections in the same viewer, one with a
PolygonDecoration,
and one with no decoration at all. Now I use the ConnectionCreationToolEntry
class
for both when creating my palette and the result is that all connections are
created with
a PolygonDecoration. I have created two different classes derived from the
AbstractConnectionEditPart but only one is used.
Is it possible to differentiate the connections when I create them in my
Palette? The
factory parameter to the ConnectionCreationToolEntry class is used for the
model, not
the editpart...right??
Re: Using different connections in the same viewer [message #78800 is a reply to message #78782] Thu, 08 May 2003 20:36 Go to previous messageGo to next message
Member
I'm sorry for this question. It's been a long day and I know how to solve
the problem.
/Stefan
"Stefan Junsved" <stefan.junsved@comactivity.net> wrote in message
news:b9eeqm$jbd$1@rogue.oti.com...
> PolygonDecoration,
> class
are
> created with
> Palette? The
> model, not
> Thanks
Re: Using different connections in the same viewer [message #78815 is a reply to message #78800] Thu, 08 May 2003 21:12 Go to previous message
I hope you are using the factory.getObjectType() to distinguish between the
two types of connections.
news:b9ef3u$jhl$1@rogue.oti.com...
> the problem.
> /Stefan
> > Hi,
> > PolygonDecoration,
> > class
> are
> > created with
the
> > Palette? The
the
> > model, not
> > Thanks
Previous Topic:Accesssibility
Next Topic:Editable PropertySheet
Current Time: Wed May 23 17:05:36 GMT 2018
Powered by FUDForum. Page generated in 0.01644 seconds
