Home » Eclipse Projects » BIRT » How to control table size for PDF Generation?
How to control table size for PDF Generation? [message #730671] Wed, 28 September 2011 20:27 Go to next message
Jean-Baptiste Guillois is currently offline Jean-Baptiste GuilloisFriend
Member
I am using BIRT 3.7.1 and created some reports with large tables. By "large", i mean tables with a big width.
As a result, when i export this report as a PDF, the table does not fit (i have the 2/3 of the table visible and only one page in the PDF file) in the pdf A4 page even when setting the report layout as "AutoLayout".
Where (if any) can i configure the maximum width or "another autolayout" setting?
Even if i tick the "Size to fit" or "Auto" options in the export dialog, no change, the table is still cut.
Actually, i haven't tested it but it might not be specific to the PDF Emmiter....
Thanks a lot for your help,
Jean-Baptiste
Re: How to control table size for PDF Generation? [message #730680 is a reply to message #730671] Wed, 28 September 2011 20:57 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Select the master page and set the page size to one of the specific
formats or use custom and set any size you want.
Jason
On 9/28/2011 4:27 PM, jeanbaptiste.guillois wrote:
> Hello,
> setting?
> Emmiter....
> Jean-Baptiste
Previous Topic:Access to a different column in the onCreate script
Next Topic:Error in cross tab
Current Time: Sun May 20 14:14:05 GMT 2018
Powered by FUDForum. Page generated in 0.01818 seconds
