Home » Eclipse Projects » WindowBuilder » EMFEditDataBinding(Using Window Builder to bind to an EMF object within an Editing domain)
EMFEditDataBinding [message #730561] Wed, 28 September 2011 15:55 Go to next message
Erik Englund is currently offline Erik EnglundFriend
Member
As far as I can tell the default way that Window Builder binds EMF Objects is by using EMFObservables.
The problem I'm running into are my model objects are stored within a TransactionalEditingDomain and thus you must interact with them through a transaction.
You accomplish this by using the EMFEditObservables.
If I try to manually substitute this in the bindings disappear from the WindowBuilder Binding editor.
How should I accomplish this by using WindowBuilder?
Re: EMFEditDataBinding [message #730727 is a reply to message #730561] Thu, 29 September 2011 02:21 Go to previous message
Eric Clayberg is currently offline Eric ClaybergFriend
You would need to enhance WindowBuilder to support EMFEditObservables in addition to EMFObservables.
Create a Bugzilla request for this feature, and then (ideally) submit a patch to implement it. We would be happy to review any patches and integrate them into the tool.
Previous Topic:Data Binding Question
Next Topic:Design and Test/Preview smaller than when running application
Current Time: Mon Apr 23 13:59:46 GMT 2018
Powered by FUDForum. Page generated in 0.01376 seconds
