Home » Language IDEs » PHP Development Tools (PDT) » org.eclipse.php.ui.PHPCompletionProposalComputer crash
org.eclipse.php.ui.PHPCompletionProposalComputer crash [message #78615] Tue, 19 August 2008 23:39 Go to next message
Originally posted by: awjrichards.gmail.com
--------------020206050905070006030101
I have 64-bit Eclipse PDT working with Ganymede under 64-bit Ubuntu
8.04. Whenever I try to create a PHP variable (typing '$'), Eclipse
freezes for a while - maybe 20 - 60 seconds. Occasionally, it will
display the following error:
"The 'org.eclipse.php.ui.PHPCompletionProposalCOmputer' proposal
computer from the 'org.eclipse.php.ui' plug-in did not complete
normally. The extension took too long to return from the
'computeCompletionProposals()' operation."
I have attached a screenshot. I've tried disabling all of the options
under the PHP->Editor->Code Assist pane in my preferences, which seems
to prevent any freezing, although performance is choppy - meaning
Eclipse will periodically hang for a second or two while I'm typing (I
can't detect any kind of pattern to it) or moving the cursor around.
I dunno if it'll make any difference, but I'm starting Eclipse with this
command: /usr/bin/eclipse64 -vmargs -Xmx512M.
Anybody have any ideas how to get around this? I'm also attaching my
error log.
Thanks so much!
Arthur Richards
name="eclipse_error_log.log"
Content-Disposition: inline;
filename="eclipse_error_log.log"
!SESSION 2008-08-19 09:41:41.113 -----------------------------------------------
eclipse.buildId=I20080617-2000
java.version=1.6.0_06
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
This is a continuation of log file /home/arthur/Dev/.metadata/.bak_0.log
Created Time: 2008-08-19 09:59:43.047
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 09:59:43.047
!MESSAGE Unexpected runtime error while computing a text hover
!STACK 0
at org.eclipse.ui.texteditor.ChainedPreferenceStore.getVisibleS tore(ChainedPreferenceStore.java:529)
at org.eclipse.ui.texteditor.ChainedPreferenceStore.getBoolean( ChainedPreferenceStore.java:171)
at org.eclipse.dltk.internal.ui.text.hover.AbstractAnnotationHo ver.isActive(AbstractAnnotationHover.java:135)
at org.eclipse.dltk.internal.ui.text.hover.AbstractAnnotationHo ver.getHoverInfo(AbstractAnnotationHover.java:95)
at org.eclipse.php.internal.ui.editor.hover.BestMatchHover.getH overInfo(Unknown Source)
at org.eclipse.php.internal.ui.editor.hover.PHPTextHoverProxy.g etHoverInfo(Unknown Source)
at org.eclipse.jface.text.TextViewerHoverManager$4.run(TextView erHoverManager.java:168)
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:02:55.471
!STACK 0
!ENTRY org.eclipse.search 4 0 2008-08-19 10:04:00.190
!MESSAGE Problems encountered during text search.
!SUBENTRY 1 org.eclipse.search 4 4 2008-08-19 10:04:00.190
!MESSAGE File 'berewarding/berewarding/log/frontend_dev.log' has been skipped, problem while reading: ('Resource is out of sync with the file system: '/berewarding/berewarding/log/frontend_dev.log'.').
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource is out of sync with the file system: '/berewarding/berewarding/log/frontend_dev.log'.
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:619)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:298)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:287)
at org.eclipse.search.internal.core.text.FileCharSequenceProvid er$FileCharSequence.getInputStream(FileCharSequenceProvider. java:282)
at org.eclipse.search.internal.core.text.FileCharSequenceProvid er$FileCharSequence.initializeReader(FileCharSequenceProvide r.java:276)
at org.eclipse.search.internal.core.text.FileCharSequenceProvid er$FileCharSequence.reset(FileCharSequenceProvider.java:268)
at org.eclipse.search.internal.core.text.FileCharSequenceProvid er.newCharSequence(FileCharSequenceProvider.java:40)
at org.eclipse.search.internal.core.text.TextSearchVisitor.proc essFile(TextSearchVisitor.java:255)
at org.eclipse.search.internal.core.text.TextSearchVisitor.proc essFiles(TextSearchVisitor.java:190)
at org.eclipse.search.internal.core.text.TextSearchVisitor.sear ch(TextSearchVisitor.java:171)
at org.eclipse.search.internal.core.text.TextSearchVisitor.sear ch(TextSearchVisitor.java:183)
at org.eclipse.search.core.text.TextSearchEngine$1.search(TextS earchEngine.java:54)
at org.eclipse.search.internal.ui.text.FileSearchQuery.run(File SearchQuery.java:184)
at org.eclipse.search2.internal.ui.InternalSearchUI$InternalSea rchJob.run(InternalSearchUI.java:94)
!SUBENTRY 2 org.eclipse.core.resources 4 274 2008-08-19 10:04:00.190
!MESSAGE Resource is out of sync with the file system: '/berewarding/berewarding/log/frontend_dev.log'.
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:04:25.115
!STACK 0
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:04:36.090
!STACK 0
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:04:46.097
!STACK 0
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:06:17.167
!STACK 0
!ENTRY org.eclipse.jface 2 0 2008-08-19 10:38:50.387
!MESSAGE Ignored reentrant call while viewer is busy. This is only logged once per viewer instance, but similar calls will still be ignored.
!STACK 0
java.lang.RuntimeException
at org.eclipse.jface.viewers.ColumnViewer.checkBusy(ColumnViewe r.java:763)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer. java:541)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider$4.run(ScriptExplorerContentProvider.java:1078)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.runUpdates(ScriptExplorerContentProvider.java:180)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.executeRunnables(ScriptExplorerContentProvider.java :141)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.elementChanged(ScriptExplorerContentProvider.java:1 30)
at org.eclipse.dltk.internal.core.DeltaProcessor$3.run(DeltaPro cessor.java:1660)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.dltk.internal.core.DeltaProcessor.notifyListener s(DeltaProcessor.java:1646)
at org.eclipse.dltk.internal.core.DeltaProcessor.firePostChange Delta(DeltaProcessor.java:1490)
at org.eclipse.dltk.internal.core.DeltaProcessor.fire(DeltaProc essor.java:1464)
at org.eclipse.dltk.internal.core.ModelOperation.run(ModelOpera tion.java:751)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.dltk.core.DLTKCore.run(DLTKCore.java:1336)
at org.eclipse.dltk.core.DLTKCore.setBuildpathContainer(DLTKCor e.java:1977)
at org.eclipse.php.internal.core.language.LanguageModelInitiali zer.initialize(Unknown Source)
at org.eclipse.dltk.internal.core.ModelManager.initializeContai ner(ModelManager.java:1684)
at org.eclipse.dltk.internal.core.ModelManager$8.run(ModelManag er.java:1629)
at org.eclipse.dltk.internal.core.ModelManager.initializeAllCon tainers(ModelManager.java:1638)
at org.eclipse.dltk.internal.core.ModelManager.getBuildpathCont ainer(ModelManager.java:1508)
at org.eclipse.dltk.core.DLTKCore.getBuildpathContainer(DLTKCor e.java:1674)
at org.eclipse.dltk.internal.ui.scriptview.BuildPathContainer.<init >(BuildPathContainer.java:91)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.getProjectFragments(ScriptExplorerContentProvider.j ava:369)
at org.eclipse.dltk.internal.ui.StandardModelElementContentProv ider.getChildren(StandardModelElementContentProvider.java:16 3)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.getChildren(ScriptExplorerContentProvider.java:307)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1352)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeView er.java:385)
at org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChil dren(AbstractTreeViewer.java:636)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(AbstractTreeViewer.java:602)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:799)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:634)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:1442)
at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeVi ewer.java:927)
at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:1453)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:126)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1182)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1167)
at org.eclipse.swt.widgets.Tree.gtk_test_expand_row(Tree.java:2 026)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1572)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4105 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:57 83)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1177)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1541)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3031)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:41:10.475
!STACK 0
!ENTRY org.eclipse.equinox.p2.director 2 0 2008-08-19 11:25:52.622
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:25:52.622
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.ui 1.0.305.v200802142230 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.common.ui 1.0.1.v20070912 to requiredCapability: osgi.bundle/org.eclipse.emf/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.common.ui 1.0.1.v20070912 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.common 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.edit.ui/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.common 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.ui.ide/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.ui/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.core.runtime/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.search/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.jface.text/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.ui.workbench.texteditor/[3.2.0,3.4.0 ).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.106.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.106.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.106.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.106.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200806252211 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200806252211 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200806252211 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200806252211 to requiredCapability: osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200803071930 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200803071930 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200803071930 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200803071930 to requiredCapability: osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.core 1.1.203.v200802140626 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.modulecore 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.modulecore 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.modulecore 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.core 1.1.101.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.core.runtime/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.core 1.1.101.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.core 1.1.101.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.core.expressions/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.emf 1.1.104.v200709131115 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:25:52.623
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.facesconfig 1.0.1.v20070912 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.facesconfig 1.0.1.v20070912 to requiredCapability: osgi.bundle/org.eclipse.emf.edit.ui/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.core 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.core 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.common.frameworks 1.1.102.v200709122200 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.common.frameworks 1.1.102.v200709122200 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.emfworkbench.integration 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.emfworkbench.integration 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jem 2.0.100.v200709051030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.3.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.frameworks 1.1.103.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.common.annotations.controller 1.1.2.v200708301745 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.web 1.1.103.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.environment 1.0.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200803242054 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200803242054 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200803242054 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200806261300 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200806261300 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200806261300 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.2.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.2.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.2.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.common.annotations.core 1.1.2.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.jca 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.jca 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env 1.0.205.v200710161954 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env 1.0.205.v200710161954 to requiredCapability: osgi.bundle/org.eclipse.ant.core/[3.1.100,3.2.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env.ui 1.0.203.v200709052219 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws 1.0.204.v200711140435 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws 1.0.204.v200711140435 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws 1.0.204.v200711140435 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws 1.0.204.v200711140435 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsdl 1.1.101.v200801152132 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsdl 1.1.101.v200801152132 to requiredCapability: osgi.bundle/org.eclipse.xsd/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws.ui 1.0.203.v200708222126 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws.ui 1.0.203.v200708222126 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsi 1.0.105.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.xsd.core 1.1.202.v200710011705 to requiredCapability: osgi.bundle/org.eclipse.xsd/[2.2.0,2.4.0).
!SESSION 2008-08-19 11:26:53.344 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 1 2008-08-19 11:27:06.680
!MESSAGE NLS unused message: EditVariableEntryDialog_filename_empty in: org.eclipse.dltk.internal.ui.wizards.NewWizardMessages
!ENTRY org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.483
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.483
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0)..
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.484
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.485
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.489
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.490
!SESSION 2008-08-19 11:30:53.672 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 1 2008-08-19 11:31:06.102
!SESSION 2008-08-19 11:46:28.136 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2008-08-19 11:46:45.068
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.osgi 2 1 2008-08-19 11:46:53.835
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 12:07:03.351
!STACK 0
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 12:07:04.734
!STACK 0
!SESSION 2008-08-19 13:33:05.208 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2008-08-19 13:33:08.431
!ENTRY org.eclipse.osgi 2 1 2008-08-19 13:33:15.768
!ENTRY org.eclipse.dltk.ui 2 0 2008-08-19 13:36:27.114
!MESSAGE The 'org.eclipse.php.ui.PHPCompletionProposalComputer' proposal computer from the 'org.eclipse.php.ui' plug-in did not complete normally. The extension took too long to return from the 'computeCompletionProposals()' operation.
!ENTRY org.eclipse.ui.workbench 2 0 2008-08-19 13:36:27.573
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-08-19 13:36:27.573
!MESSAGE Conflict for 'org.eclipse.ui.navigate.forwardHistory':
HandlerActivation(commandId=org.eclipse.ui.navigate.forwardH istory,
handler=ActionHandler(org.eclipse.ui.internal.NavigationHistoryAction@38a09316),
expression=ActiveShellExpression(Shell {PHP - rncwc/metrics.php - Eclipse SDK}),sourcePriority=17408)
handler=ActionHandler(org.eclipse.ui.internal.dialogs.Prefer encePageHistory$2@3618a665),
expression=ActiveShellExpression(Shell {Preferences}),sourcePriority=17408)
!MESSAGE Conflict for 'org.eclipse.ui.navigate.backwardHistory':
HandlerActivation(commandId=org.eclipse.ui.navigate.backward History,
handler=ActionHandler(org.eclipse.ui.internal.dialogs.Prefer encePageHistory$1@c544ca2),
handler=ActionHandler(org.eclipse.ui.internal.NavigationHistoryAction@72732600),
!ENTRY org.eclipse.ui 4 0 2008-08-19 13:38:49.278
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.OutOfMemoryError: GC overhead limit exceeded)
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:136)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
at java.lan
Eclipse 3.4/PDT 2.0 Linux - No syntax checking; no code assist [message #78650 is a reply to message #78615] Wed, 20 August 2008 01:35 Go to previous messageGo to next message
Ed Wright is currently offline Ed WrightFriend
Running PDT 2.0.0v20080722 on Eclipse 3.4.0v20080617 on Debian Etch system.
Syntax checking and code assist are not working. I'm wondering if these
are issues with the current version, or if I have a configuration
problem somewhere. If the latter, any advice on getting it straightened
out would be much appreciated.
On a separate note (related or not I don't know) I get the below error
spewed as many as 30-40 times/second at occasional intervals.
Ed
(Note: "eQstuff" is an existing project)
!ENTRY org.eclipse.php.core 4 4 2008-08-19 18:10:43.428
!MESSAGE eQstuff does not exist
!STACK 1
org.eclipse.dltk.core.ModelException: eQstuff does not exist
org.eclipse.dltk.internal.core.ModelOperation.runOperation(M odelOperation.java:768)
org.eclipse.dltk.internal.core.SourceType.newSupertypeHierar chy(SourceType.java:360)
org.eclipse.dltk.internal.core.SourceType.newSupertypeHierar chy(SourceType.java:333)
org.eclipse.php.internal.core.ast.nodes.TypeBinding.getInter faces(Unknown
Source)
org.eclipse.php.internal.core.ast.nodes.Bindings.findOverrid denMethod(Unknown
Source)
org.eclipse.php.internal.ui.editor.OverrideIndicatorManager$ 1.visit(Unknown
Source)
org.eclipse.php.internal.core.ast.nodes.MethodDeclaration.ac cept0(Unknown
Source)
org.eclipse.php.internal.core.ast.nodes.ASTNode.accept(Unkno wn Source)
org.eclipse.php.internal.core.ast.nodes.Block.childrenAccept (Unknown Source)
org.eclipse.php.internal.core.ast.nodes.Block.accept0(Unknow n Source)
org.eclipse.php.internal.core.ast.nodes.ClassDeclaration.chi ldrenAccept(Unknown
Source)
org.eclipse.php.internal.core.ast.nodes.ClassDeclaration.acc ept0(Unknown
Source)
org.eclipse.php.internal.core.ast.nodes.Program.childrenAcce pt(Unknown
Source)
org.eclipse.php.internal.core.ast.nodes.Program.accept0(Unkn own Source)
org.eclipse.php.internal.ui.editor.OverrideIndicatorManager. updateAnnotations(Unknown
Source)
org.eclipse.php.internal.ui.editor.OverrideIndicatorManager. reconciled(Unknown
Source)
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.recon ciled(Unknown
Source)
org.eclipse.php.internal.ui.editor.validation.PhpReconciling Strategy.validate(Unknown
Source)
org.eclipse.wst.sse.ui.internal.reconcile.validator.Reconcil eStepForValidator.validate(ReconcileStepForValidator.java:34 0)
org.eclipse.wst.sse.ui.internal.reconcile.validator.Reconcil eStepForValidator.reconcileModel(ReconcileStepForValidator.j ava:247)
org.eclipse.jface.text.reconciler.AbstractReconcileStep.reco ncile(AbstractReconcileStep.java:96)
org.eclipse.wst.sse.ui.internal.reconcile.validator.Validato rStrategy.reconcile(ValidatorStrategy.java:229)
org.eclipse.wst.sse.ui.internal.reconcile.DocumentRegionProc essor.process(DocumentRegionProcessor.java:175)
org.eclipse.wst.sse.ui.internal.reconcile.StructuredRegionPr ocessor.process(StructuredRegionProcessor.java:252)
org.eclipse.wst.sse.ui.internal.reconcile.DirtyRegionProcess or.run(DirtyRegionProcessor.java:638)
!SUBENTRY 1 org.eclipse.dltk.core 4 969 2008-08-19 18:10:43.429
Re: Eclipse 3.4/PDT 2.0 Linux - No syntax checking; no code assist [message #78668 is a reply to message #78650] Wed, 20 August 2008 02:17 Go to previous messageGo to next message
Oh, damn....
Please forgive the "thread hijacking"..... it was unintended.
Ed
Re: Eclipse 3.4/PDT 2.0 Linux - No syntax checking; no code assist [message #78712 is a reply to message #78668] Wed, 20 August 2008 13:38 Go to previous messageGo to next message
David Muir is currently offline David MuirFriend
Member
Use one of the latest nightlies instead.
Re: Eclipse 3.4/PDT 2.0 Linux - No syntax checking; no code assist [message #78852 is a reply to message #78712] Thu, 21 August 2008 03:21 Go to previous messageGo to next message
David,
Thanks for the reply.
Have you had experience that syntax checking does not work with
I20080722 but does work with the nightlies? I'm a little leery of
possibly introducing stability or other problems with nightly builds as
I need to get work done and don't have a lot of time to mess with the
platform.
Ed
Re: Eclipse 3.4/PDT 2.0 Linux - No syntax checking; no code assist [message #78878 is a reply to message #78852] Thu, 21 August 2008 11:25 Go to previous messageGo to next message
Member
> platform.
> Ed
I've found the nightlies to be significantly better. I20080722 has some
big bugs, and they should have released new integration builds after
fixing the issues with code completion, and the $ freese issue (which
isn't completely fixed yet, but vastly improved).
Re: Eclipse 3.4/PDT 2.0 Linux - No syntax checking; no code assist [message #78911 is a reply to message #78878] Fri, 22 August 2008 02:48 Go to previous messageGo to next message
Hmmm.... ok.... soon's I get a little time I'll give a nightly a try.
Ed
Re: org.eclipse.php.ui.PHPCompletionProposalComputer crash [message #92432 is a reply to message #78615] Fri, 30 January 2009 12:11 Go to previous message
Phil is currently offline PhilFriend
We're getting this error on various machines now and it's making Eclipse
unusable. Eclipse will freeze as you're typing, and stay locked for around
30-60 seconds, haven't measured it exactly.
Error message:
"The 'org.eclipse.php.ui.PHPCompletionProposalComputer' proposal computer
Extension took too long to return from the 'computeCompletionProposals()'
operation."
So far I've seen it on Eclipse 3.4 + PDT 2.0 under XP 32-bit, and Eclipse
3.4 + PDT 2.0 under Ubuntu 64-bit.
The XP install was from the PDT all-in-one. The only other plugins active
are Subclipse and YamlEditor.
Previous Topic:New face to Eclipse PDT Web Site
Next Topic:Hanging on exit, not saving workspace
Current Time: Sun Feb 25 16:12:29 GMT 2018
Powered by FUDForum. Page generated in 0.02622 seconds
