Home » Eclipse Projects » Web Tools Project (WTP) » URIResolverExtension / custom Resolvers(Can't seem to get this to ever work.. comparing to XMLCatalogURIResolverExtension)
URIResolverExtension / custom Resolvers [message #729666] Mon, 26 September 2011 14:08 Go to next message
Roger  is currently offline Roger
So, i'm trying to make my own custom resolver extension class, so I can associate the proper XSD files to XML files based on their location/filename.
Sample code:
@SuppressWarnings("restriction")
public class XSDResolver implements URIResolverExtension {
    private static final Log log = LogFactory.getLog(XSDResolver.class);
	public String resolve(IFile file, String baseLocation, String publicId, String systemId) {
		log.info("File: " + file.getName());
		log.info("Base Location: " + baseLocation);
		log.info("Public ID: " + publicId);
		log.info("System ID: " + systemId);
		XMLCatalogURIResolverExtension e = new XMLCatalogURIResolverExtension();
		String result = e.resolve(file, baseLocation, publicId, systemId);
		log.error("RESULT: " + result);
		if (result != null) {
			return result;
		return null;
	private String getXsdFromFileName(String fileName) {
		log.error("**********************");
		return "file:/home/rstudner/svn/studio-trunk/core/studio/templates/knowledgebase.xsd";
I'd love to know, how to take a given filename, and associate XSD with it.. but so far nothing in these forums/any book/anything on Google is helping me out Smile
Re: URIResolverExtension / custom Resolvers [message #729667 is a reply to message #729666] Mon, 26 September 2011 14:09 Go to previous messageGo to next message
And note.. if I dump this resolver, and put the explicit stuff in my xml doc.. then it uses my XML Catalog entry and works hah
So it makes no sense that if I'm simply returning the value from the XML resolver in my own code, why it then fails to work.
thoughts?
Re: URIResolverExtension / custom Resolvers [message #729682 is a reply to message #729667] Mon, 26 September 2011 14:42 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
The resolvers aid in finding associated resources, they don't define that association themselves. For XML validation, you still have to put a reference to the Schema/DTD within the document's text, or be using the org.eclipse.wst.xml.core.externalSchemaLocations extension point.
Nitin Dahyabhai
Eclipse WTP, IBM
Re: URIResolverExtension / custom Resolvers [message #729982 is a reply to message #729682] Tue, 27 September 2011 08:11 Go to previous messageGo to next message
Do you have any example or know where the "doc" is for:
"or be using the org.eclipse.wst.xml.core.externalSchemaLocations extension point."
Hardest thing about doing RCP stuff i've found so far, is there is almost no documentation of anything Smile
Roger
Re: URIResolverExtension / custom Resolvers [message #731033 is a reply to message #729982] Thu, 29 September 2011 14:31 Go to previous messageGo to next message
Nick Sandonato is currently offline Nick Sandonato
Hi Roger,
The only real doc (we really should have more) that exists for the externalSchemaLocations is within the interface for org.eclipse.wst.xml.core.contentmodel.modelquery.IExternalSchemaLocationProvider. Basically, you'll implement this provider so that it can associate schemas based on the URI that it is passed. These providers are invoked in the absence of a referenced schema within the XML. You can find an example provider in the org.eclipse.wst.xml.core.tests ExternalSchemaTest scenario.
Re: URIResolverExtension / custom Resolvers [message #731076 is a reply to message #729982] Thu, 29 September 2011 17:11 Go to previous message
David Carver is currently offline David Carver
Roger wrote on Tue, 27 September 2011 08:11
Roger
Here is a code example of how we resolve what XML Schema to use for the XSLT Editor. Depending on the version attribute determines what XML Schema is loaded for the editor, and then loaded into the Content Model.
http://dev.eclipse.org/viewcvs/viewvc.cgi/sourceediting/plugins/org.eclipse.wst.xsl.core/src/org/eclipse/wst/xsl/core/resolver/ResolverExtension.java?view=markup&root=WebTools_Project
Hope that helps.
Previous Topic:Import WSDL and XSD files
Next Topic:Cannot open JSP in Web Page Editor
Current Time: Sun May 19 00:37:10 EDT 2013
Powered by FUDForum. Page generated in 0.01726 seconds
