Home » Eclipse Projects » P2 » p2 ant mirror task should fails on error
p2 ant mirror task should fails on error [message #728402] Fri, 23 September 2011 08:09
Stephane Bouchet is currently offline Stephane BouchetFriend
i am trying to fails an ant build task using p2.mirror if the content
are not correctly mirrored.
For example, p2.mirror will print error messages if there is a problem
during mirror :
[java] [p2.mirror] Problems resolving provisioning plan.
[java] [p2.mirror] Unable to satisfy dependency from
org.eclipse.ui.views.properties.tabbed.feature.patch.feature.group
1.0.0.201109222154 to org.eclipse.ui.views.properties.tabbed
[3.5.100.I20100509-0800].
org.eclipse.emf.ecore.feature.patch.feature.group 1.0.0.201109222154 to
org.eclipse.emf.ecore [2.6.1.v20100914-1218].
org.eclipse.gmf.runtime.diagram.ui.providers.feature.patch.feature.group
1.0.0.201109222154 to org.eclipse.gmf.runtime.diagram.ui.providers
[1.4.0.v20100430-1518].
The result is that the mirror will not contains any plugin.
i would like to fail the build is such an error happens. i could not
find any attribute or useful information . could it be possible to
achieve this ?
St├ęphane Bouchet, OBEO
Previous Topic:Use a version in installui in a headless installation
Next Topic:No application id has been found
Current Time: Mon May 28 03:34:06 GMT 2018
Powered by FUDForum. Page generated in 0.01293 seconds
