Home » Language IDEs » C / C++ IDE (CDT) » Help! Adding menu items to CDT Source Editor context menu
Help! Adding menu items to CDT Source Editor context menu [message #78001] Thu, 07 August 2003 21:04 Go to next message
Mike Boyersmith is currently offline Mike BoyersmithFriend
Member
I ran into a weird issue where I was able to add menu items to the CDT
editor (or so I thought this is what it was). using the constant
<viewerContribution id="com.xxx..CDTPopupActions"
targetID="#CEditorContext">
where targetID #CEditorContext
BUT... recently the editor window seems to have changed (it now has a ruler
at the top, and the code is color highlighted) and now my pop up menu items
no longer appear... sigh... so I assume that the editor my menu was popping
up in before must have NOT been the CDT editor, though I had CDT installed.
ugggg.
Is #CEditorContext the correct define for right click context menu items, on
a source editor window such as test.cpp?
I have looked everywhere, trying to find where to get a list of
fragment.xml defines for adding menu items to various UI elements of CDT but
can't find any information anywhere.
any help is appreciated greatly
Thanks in Advance
Re: Help! Adding menu items to CDT Source Editor context menu [message #78017 is a reply to message #78001] Thu, 07 August 2003 21:52 Go to previous messageGo to next message
Member
So further investigation it seems to be using the LPEX editor settings from
the preferences.
I still can't seem to find any information on 'Legal' constants to be used
with fragments for viewerContribution menu items (right click context menu
items).
sigh... any help is appreciated.
"Mike" <mboyersmith@rational.com> wrote in message
news:bgueo9$off$1@eclipse.org...
ruler
items
popping
installed.
> ugggg.
on
but
> Thanks in Advance
Re: Help! Adding menu items to CDT Source Editor context menu [message #78033 is a reply to message #78017] Thu, 07 August 2003 22:13 Go to previous messageGo to next message
Member
Ok, heres the deal.
So I found under eclipse menu:
Window-> preferences->Workbench->File Associations
that the editor I was use to seeing for C and CPP files had been replaced
by LPEX entries. After I removed the LPEX entries and got back to the
Default C/CPP editor my menus started showing again.
So...... what is LPEX? wheres it coming from? and how do I get my menus to
show not only on the default C/CPP editor but also on these other C/CPP
editor windows?
Thanks for the assistance here.
news:bguhjp$r3h$1@eclipse.org...
from
> the preferences.
> items).
> ruler
> items
> popping
> installed.
> > ugggg.
items,
> on
> but
> > Thanks in Advance
Re: Help! Adding menu items to CDT Source Editor context menu [message #78062 is a reply to message #78033] Fri, 08 August 2003 02:33 Go to previous message
kessel haus is currently offline kessel hausFriend
Mike wrote:
> Ok, heres the deal.
> editor windows?
LPEX has been the editor component used by IBM before QNX Team took over
the CDT project ownership. LPEX AFAIK is being abandoned for a long time
now, but as I saw in CVS its still under org.eclipse.cdt.old.
> from
>>the preferences.
>>items).
>>ruler
>>items
>>popping
>>installed.
>>>ugggg.
> items,
>>on
>>but
>>>Thanks in Advance
Previous Topic:JAR creation failure
Next Topic:How can I suppress java warnings in eclipse?
Current Time: Wed May 23 07:27:29 GMT 2018
Powered by FUDForum. Page generated in 0.02055 seconds
