Home » Eclipse Projects » BIRT » Get Dataset value to fill Y-serie
Get Dataset value to fill Y-serie [message #726073] Fri, 16 September 2011 14:00 Go to next message
Missing name Missing name is currently offline Missing name Missing nameFriend
Member
I try to fill Y-series of a Gantt chart using datasource and dataset placed in a report design programmatically.
I created a report design programmatically, placing datasource and dataset extracted from an xml file.
EngineConfig reportConfig = new EngineConfig( );
DesignConfig designConfig = new DesignConfig( );
IDesignEngineFactory iDesignEngineFactory = (IDesignEngineFactory) Platform.createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY);
IDesignEngine designEngine = iDesignEngineFactory.createDesignEngine(designConfig);
SessionHandle session = designEngine.newSessionHandle(ULocale.FRENCH);
ReportDesignHandle designHandle = session.createDesign();
ElementFactory elementFactory = designHandle.getElementFactory();
DesignElementHandle elementHandle = elementFactory.newSimpleMasterPage("Page Master");
try {
  designHandle.getMasterPages().add(elementHandle);
} catch (ContentException e) {
  e.printStackTrace();
} catch (NameException e) {
DesignElementHandle datasource=designHandle.getDataSources().get(0);
OdaDataSourceHandle dataSourceHandle = elementFactory.newOdaDataSource("DataSource", "org.eclipse.birt.report.data.oda.xml");
try {
  dataSourceHandle.setProperty("FILELIST", "myxml.xml");
  dataSourceHandle.setProperty("SCHEMAFILELIST","myxsd.xsd");
  dataSourceHandle.setProperty("ENCODINGLIST","UTF-8");
} catch (SemanticException e1) {
  e1.printStackTrace();
try {
  designHandle.getDataSources( ).add(dataSourceHandle);
OdaDataSetHandle datasetHandle = elementFactory.newOdaDataSet( "DataSet","org.eclipse.birt.report.data.oda.xml.dataSet" );
try {
  datasetHandle.setDataSource( "DataSource" );
} catch (SemanticException e) {
try {
  datasetHandle.setQueryText("table0#-TNAME-#table0#:#[/Reservation]#:#{startDate;DATE;/@startDate},{endDate;DATE;/@endDate},{name;STRING;/owns/@name},{firstname;STRING;/owns/@firstname}#:#");
try {
  designHandle.getDataSets().add(datasetHandle );
Then, I have a chart created programmatically.
I would like to get dataset data to add them in the chart series as dataset.
// Y-Series
GanttSeries yserie = (GanttSeries) GanttSeriesImpl.create();
yserie.setDataSet(????);
SeriesDefinition sdY = SeriesDefinitionImpl.create();
sdY.getSeriesPalette( ).shift(0);
yAxisPrimary.getSeriesDefinitions( ).add(sdY);
sdY.getSeries().add(yserie);
I would like to fill a GanttSerie like this but using data placed in the xml file:
GanttDataSet phase1 = GanttDataSetImpl.create( new GanttEntry[]{
  new GanttEntry( new CDateTime( 2009, 1, 1), new CDateTime( 2009, 1,15),"Name" )
How can I retrieve data ? do you know a tutorial that explains this ?
Thanks in advance,
Val
[Updated on: Fri, 16 September 2011 14:02]
Report message to a moderator
Re: Get Dataset value to fill Y-serie [message #726139 is a reply to message #726073] Fri, 16 September 2011 16:23 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Here is a simple example that builds a report containing a dataset and a
chart. Note that you have to create binding columns on the chart report
item.
import java.io.IOException;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LegendItemType;
import org.eclipse.birt.chart.model.attribute.Palette;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionImpl;
import org.eclipse.birt.chart.model.attribute.impl.PaletteImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.BaseSampleData;
import org.eclipse.birt.chart.model.data.DataFactory;
import org.eclipse.birt.chart.model.data.OrthogonalSampleData;
import org.eclipse.birt.chart.model.data.SampleData;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.impl.QueryImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.DataSetHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.ExtendedItemHandle;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.SimpleMasterPageHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.activity.SemanticException;
import org.eclipse.birt.report.model.api.command.ContentException;
import org.eclipse.birt.report.model.api.command.NameException;
import
org.eclipse.birt.report.model.api.elements.structures.PropertyBinding;
import com.ibm.icu.util.ULocale;
public class SimpleChart
private ReportDesignHandle reportDesignHandle = null;
private ElementFactory elementFactory = null;
private OdaDataSourceHandle odaDataSourceHandle = null;
private String dataSourceName = "datasource";
private String dataSetName = "maindataset";
private SessionHandle sessionHandle =null;
org.eclipse.birt.report.model.api.elements.structures.ComputedColumn
cs1, cs2 = null;
public static void main(String args[])
try {
new SimpleChart().createReport();
} catch (Exception e) {
public void createReport() throws SemanticException, IOException
System.out.println("Start");
init();
createMasterPages();
buildDataSource();
buildDataSet();
createBody();
reportDesignHandle.saveAs("output/desample/simplechart.rptdesign");
reportDesignHandle.close( );
Platform.shutdown();
System.out.println("Finished");
private void init(){
DesignConfig config = new DesignConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_6_1/birt-runtime-2_6_1/ReportEngine");
IDesignEngine engine = null;
try {
Platform.startup(config);
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
..createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY);
engine = factory.createDesignEngine(config);
} catch (Exception ex) {
ex.printStackTrace();
// we need a handle of session of design engine
sessionHandle = engine.newSessionHandle(ULocale.ENGLISH);
reportDesignHandle = sessionHandle.createDesign();
elementFactory = reportDesignHandle.getElementFactory();
private void createMasterPages() throws ContentException, NameException
SimpleMasterPageHandle simpleMasterPage =
elementFactory.newSimpleMasterPage("Master Page");
reportDesignHandle.getMasterPages().add(simpleMasterPage);
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = elementFactory.newOdaDataSource(
"Data Source", "org.eclipse.birt.report.data.oda.jdbc" );
dsHandle.setProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver" );
dsHandle.setProperty( "odaURL", "jdbc:classicmodels:sampledb" );
dsHandle.setProperty( "odaUser", "ClassicModels" );
dsHandle.setProperty( "odaPassword", "" );
PropertyBinding pb = new PropertyBinding();
reportDesignHandle.getDataSources( ).add( dsHandle );
void buildDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle = elementFactory.newOdaDataSet( dataSetName,
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select PRODUCTCODE, QUANTITYORDERED from orderdetails
where ordernumber = 10104";
dsHandle.setQueryText( qry );
reportDesignHandle.getDataSets( ).add( dsHandle );
PropertyHandle handle = dsHandle.getPropertyHandle(
DataSetHandle.RESULT_SET_PROP );
private void createBody() throws SemanticException
ExtendedItemHandle extendedItemHandle =
elementFactory.newExtendedItem("Simple Chart", "Chart");
extendedItemHandle.setWidth("700px");
extendedItemHandle.setHeight("500px");
extendedItemHandle.setProperty(ExtendedItemHandle.DATA_SET_PROP,
dataSetName);
extendedItemHandle.setProperty("outputFormat","PNG");
Chart c = createChart();
extendedItemHandle.getReportItem().setProperty(
"chart.instance", c );
reportDesignHandle.getBody().add(extendedItemHandle);
//PropertyHandle computedSet = extendedItemHandle.getColumnBindings( );
//computedSet.clearValue();
cs1 = StructureFactory.createComputedColumn( );
cs1.setName( "PRODUCTCODE" );
cs1.setExpression( "dataSetRow[\"PRODUCTCODE\"]");
cs1.setDataType( "string" );
cs1.setAggregateOn(null);
cs2 = StructureFactory.createComputedColumn( );
cs2.setName( "QUANTITYORDERED" );
cs2.setExpression( "dataSetRow[\"QUANTITYORDERED\"]");
cs2.setDataType( "integer" );
extendedItemHandle.addColumnBinding(cs1, true);
extendedItemHandle.addColumnBinding(cs2, true);
private Chart createChart() {
ChartWithAxes cwaLine = ChartWithAxesImpl.create();
cwaLine.setType( "Line Chart" ); //$NON-NLS-1$
cwaLine.setSubType( "Overlay" ); //$NON-NLS-1$
cwaLine.getBlock().getBounds().setWidth(600);
cwaLine.getBlock().getBounds().setHeight(400);
// Plot
cwaLine.getBlock().setBackground( ColorDefinitionImpl.WHITE() );
Plot p = cwaLine.getPlot();
p.getClientArea().setBackground( ColorDefinitionImpl.create(
255, 255,
225 ) );
// Title
cwaLine.getTitle().getLabel().getCaption().setValue("Overlay
test Line Chart" );
cwaLine.getTitle().setVisible(true);
// Legend
cwaLine.getLegend().setVisible( true );
Legend lg = cwaLine.getLegend();
lg.setItemType(LegendItemType.CATEGORIES_LITERAL);
// X-Axis
Axis xAxisPrimary = cwaLine.getPrimaryBaseAxes()[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
xAxisPrimary.getMajorGrid().setTickStyle(
TickStyle.BELOW_LITERAL );
xAxisPrimary.getOrigin().setType( IntersectionType.MIN_LITERAL );
// Y-Axis
Axis yAxisPrimary = cwaLine.getPrimaryOrthogonalAxis(
xAxisPrimary );
yAxisPrimary.setType(AxisType.LINEAR_LITERAL);
yAxisPrimary.getMajorGrid().setTickStyle(
TickStyle.RIGHT_LITERAL );
yAxisPrimary.getLabel().getCaption().setValue("TEST");
yAxisPrimary.getLabel().setVisible(true);
SampleData sd = DataFactory.eINSTANCE.createSampleData( );
BaseSampleData sdBase = DataFactory.eINSTANCE.createBaseSampleData( );
sdBase.setDataSetRepresentation( "Category-A, Category-B" );//$NON-NLS-1$
sd.getBaseSampleData( ).add( sdBase );
OrthogonalSampleData sdOrthogonal =
DataFactory.eINSTANCE.createOrthogonalSampleData( );
sdOrthogonal.setDataSetRepresentation( "4,12" );//$NON-NLS-1$
sdOrthogonal.setSeriesDefinitionIndex( 0 );
sd.getOrthogonalSampleData( ).add( sdOrthogonal );
cwaLine.setSampleData( sd );
// X-Series
Series seCategory = SeriesImpl.create( );
// seCategory.setDataSet( categoryValues );
// Set category expression.
seCategory.getDataDefinition( )
.add( QueryImpl.create( "row[\"PRODUCTCODE\"]" ) );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
Palette palx = PaletteImpl.create(10, false);
//sdY.getSeriesPalette( ).shift(1);
sdX.setSeriesPalette(palx);
//sdX.getSeriesPalette( ).shift( 1 );
//sdX.setSorting(SortOption.ASCENDING_LITERAL);
// Set default grouping.
//SeriesGrouping grouping = sdX.getGrouping( );
//grouping.getAggregateExpression();
//grouping.setEnabled( false );
//grouping.setGroupType( DataType.TEXT_LITERAL );
//grouping.setGroupingUnit( GroupingUnitType.STRING_PREFIX_LITERAL );
//grouping.setGroupingInterval( 1 );
//grouping.setAggregateExpression( "Sum" ); // Set Count aggregation.
//$NON-NLS-1$
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
// Y-Series
LineSeries bs1 = (LineSeries) LineSeriesImpl.create( );
bs1.getDataDefinition( ).add( QueryImpl.create(
"row[\"QUANTITYORDERED\"]" ) );
bs1.getLabel( ).setVisible( true );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
//Palette pal = PaletteImpl.create(10, false);
//sdY.setSeriesPalette(pal);
sdY.getGrouping().setEnabled(false);
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeries( ).add( bs1 );
return cwaLine;
Jason
On 9/16/2011 10:00 AM, val.dupin wrote:
> Hello,
> try {
> try {
> try {
> try {
> try {
> try {
> dataset.
> // Y-Series
> I would like to fill a GanttSerie like this:
> 1,15),"Name" )
> How can I retrieve data ? do you know a tutorial that explain this ?
> Thanks in advance,
> Val
Re: Get Dataset value to fill Y-serie [message #727167 is a reply to message #726139] Tue, 20 September 2011 14:49 Go to previous messageGo to next message
Member
Hi Jason,
Thanks a lot. When I try to run my RCP application, I have a problem with the line:
ExtendedItemHandle extendedItemHandle = elementFactory.newExtendedItem("Simple Chart", "Chart");
extendedItemHandle is null.
What is "Chart" ? the class javadoc doesn't help me to understand what is expected !
Is there a plugin to add to my project ?
My report is create dynamically and hasn't element.
Val
Re: Get Dataset value to fill Y-serie [message #727192 is a reply to message #727167] Tue, 20 September 2011 15:05 Go to previous messageGo to next message
Did you add the chart plugins to your project? The "Chart" is the
extension point that implements the chart report item eg
org.eclipse.birt.chart.reportitem_version. You will also need the other
chart plugins.
Jason
On 9/20/2011 10:49 AM, val.dupin wrote:
> Hi Jason,
> with the line:
> is expected !
> Val
Re: Get Dataset value to fill Y-serie [message #728053 is a reply to message #727192] Thu, 22 September 2011 13:10 Go to previous messageGo to next message
Member
Thanks Jason it's OK, extendedItemHandle is filled !
But, I have another question:
How can I fill a GanttSerie with extracted data (and date) ?
As you advise, I create ComputedColumn for each field I would use to create Gantt series:
ExtendedItemHandle extendedItemHandle =elementFactory_.newExtendedItem("Gantt Chart", "Chart");
extendedItemHandle.setProperty(ExtendedItemHandle.DATA_SET_PROP, m_datasetName);
extendedItemHandle.setProperty("outputFormat", "SVG");
ComputedColumn cs1 = StructureFactory.createComputedColumn();
cs1.setName("name");
cs1.setExpression("dataSetRow[\"name\"]");
cs1.setDataType("string");
ComputedColumn cs2 = StructureFactory.createComputedColumn();
cs2.setName("firstname");
cs2.setExpression("dataSetRow[\"firstname\"]");
cs2.setDataType("string");
ComputedColumn cs3 = StructureFactory.createComputedColumn();
cs3.setName("startDate");
cs3.setExpression("dataSetRow[\"startDate\"]");
cs3.setDataType("date-time");
ComputedColumn cs4 = StructureFactory.createComputedColumn();
cs4.setName("endDate");
cs4.setExpression("dataSetRow[\"endDate\"]");
cs4.setDataType("date-time");
extendedItemHandle.addColumnBinding(cs3, true);
extendedItemHandle.addColumnBinding(cs4, true);
Then I define a GanttSeries, and I try to fill it with extracted data from "row", like this:
// Y-Series
GanttSeries taskPhase1 = (GanttSeries) GanttSeriesImpl.create();
taskPhase1.getDataDefinition().add(QueryImpl.create("row[\"startDate\"]"));
taskPhase1.getDataDefinition().add(QueryImpl.create("row[\"endDate\"]"));
taskPhase1.getDataDefinition().add(QueryImpl.create("row[\"name\"]"));
sdY.getSeries().add(taskPhase1);
My chart is displayed but there is no horizontal bar inside.
I would like to know details about how to fill a GanttSerie with row data and how to convert query to CDateTime.
Could you explain me ?
Thanks in advance.
Val
[Updated on: Thu, 22 September 2011 13:11]
Re: Get Dataset value to fill Y-serie [message #728204 is a reply to message #728053] Thu, 22 September 2011 17:51 Go to previous message
Take a look at this example:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1420-java-example-of-createing-a-report-with-a-gantt-chart/
Jason
On 9/22/2011 9:10 AM, val.dupin wrote:
> Thanks Jason it's OK, extendedItemHandle is fill !
> How can I fill a GanttSerie with extracted date ?
> m_datasetName);
> // Y-Series
> Thanks in advance.
> Val
Previous Topic:How to get input from user?
Next Topic:Default Workspace Directory
Current Time: Sat Apr 21 00:24:44 GMT 2018
Powered by FUDForum. Page generated in 0.02460 seconds
