Home » Language IDEs » Java Development Tools (JDT) » Run / Debug error([Fatal Error] AndroidManifest.out.out.out.xml:1:1: Premature end of file.)
Run / Debug error [message #725823] Thu, 15 September 2011 21:28 Go to next message
George O'Gorman is currently offline George O'GormanFriend
My system: Windows XP sp2 32bit.
I have just installed Eclipse Indigo and am trying to debug a program for the first time. I am getting the error [Fatal Error] AndroidManifest.out.out.out.xml:1:1: Premature end of file.
When I hit the debug button there is a dialoge box which says: "JRE Instance Default XSLT processor does not support debugging. Would you like to use the default processor?"
Any help regarding this is greatly appreciated.
Thanx, George.
Re: Run / Debug error [message #726156 is a reply to message #725823] Fri, 16 September 2011 17:02 Go to previous message
David Wegener is currently offline David WegenerFriend
This appears to be an Android related question. You should consult the Android forums provided by Google. Eclipse forums do not provide Android support.
Previous Topic:How to increase priority of template proposals in Eclipse?
Next Topic:Eclipse + Web Service + Event broadcast/consume Tutorial ?
Current Time: Sun Jan 21 16:59:53 GMT 2018
Powered by FUDForum. Page generated in 0.01962 seconds
