[CDO] Possible bug with InnoDB? [message #725670] |
Thu, 15 September 2011 14:00 |
erpalma2003 Messages: 12 Registered: July 2011 |
Junior Member |
Using MySQL 5.1.56 + InnoDB + CDO 4.0 (DBStore) I'm getting this when trying to tweak "innodb_log_file_size" from 5MB to >5MB:
[INFO] CDO server starting
[ERROR] Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
at org.eclipse.net4j.spi.db.DBAdapter.validateTable(DBAdapter.java:439)
at org.eclipse.net4j.spi.db.DBAdapter.createTable(DBAdapter.java:146)
at org.eclipse.net4j.spi.db.DBAdapter.createTables(DBAdapter.java:111)
at org.eclipse.net4j.spi.db.DBSchema.create(DBSchema.java:118)
at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DBStore.java:521)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:72)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:99)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:89)
at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1543)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:201)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:110)
at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:61)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
at java.lang.Thread.run(Thread.java:679)
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown table engine 'InnoDB'
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
at com.mysql.jdbc.Util.getInstance(Util.java:381)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1051)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3563)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3495)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1959)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2113)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2687)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2616)
at com.mysql.jdbc.StatementImpl.executeQuery(StatementImpl.java:1453)
at org.eclipse.net4j.spi.db.DBAdapter.validateTable(DBAdapter.java:428)
... 18 more
[Updated on: Fri, 16 September 2011 09:53] Report message to a moderator
(no subject) [message #725742 is a reply to message #725670] |
Thu, 15 September 2011 16:11 |
I'm not sure if Stefan finds this post because it's not prefixed with [CDO], so I've cc'ed him.
Cheers
/Eike
http://www.esc-net.de
Am 15.09.2011 16:00, schrieb erpalma2003:
> Using MySQL + InnoDB + DBStore I'm getting this when trying to tweak "innodb_log_file_size" from 5MB to >5MB:
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> ... 18 more
Cheers
/Eike
(no subject) [message #726023 is a reply to message #725670] |
Fri, 16 September 2011 12:25 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
I'm a bit puzzled, how the configuration option you gave would affect
CDO, because CDO has no direct reference to the MySQL store type. The
store type is configured as default in your mysql configuration.
What I can tell is that the stack trace you posted is the result of an
error when executing CREATE TABLE. This statement would use the default
table storage engine, which is likely configured to InnoDB.
My first guess would be the following: have a look in your mysql log
file. Maybe you modified something that results in the InnoDB storage
engine not being started at all (which would explain why it is not found
at runtime).
Also, please try to execute a CREATE TABLE statement manually using your
configuration and see if this fails, too.
Stefan
Am 15.09.11 16:00, schrieb erpalma2003:
> cdo_lobs
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
Re: (no subject) [message #733646 is a reply to message #726023] |
Wed, 05 October 2011 09:46 |
I get the same error. My DataSource is correctly configured (I tried to create some tables and drop them: everything is working fine).
I create the DBStore in this way:
private IStore createStore() {
final MysqlDataSource dataSource = new MysqlDataSource();
dataSource.setUser("root");
dataSource.setPassword("root");
dataSource.setServerName("127.0.0.1");
dataSource.setPort(3306);
dataSource.setDatabaseName("cdoexperiments");
DBAdapter dbAdapter = new DBAdapter("mysql",null) {
public String[] getReservedWords() {
return null;
public Driver getJDBCDriver() {
try {
return new com.mysql.jdbc.Driver();
} catch (SQLException e) {
throw new RuntimeException(e);
public DataSource createJDBCDataSource() {
return dataSource;
DBStore store = new DBStore();
store.setDBAdapter(dbAdapter);
store.setMappingStrategy(new HorizontalMappingStrategy());
store.setDataSource(dataSource);
return store;
Then when I launch the server I get the same error as reported by erpalma2003
website: http://www.federico-tomassetti.it
FUDForum. Page generated in 0.03686 seconds
