Home » Modeling » EMF » Problem while loading entities of different type in a XMLResource
Problem while loading entities of different type in a XMLResource [message #725665] Thu, 15 September 2011 13:47 Go to next message
Thomas Ricatte is currently offline Thomas RicatteFriend
I a really new to EMF and I have to load some data contained in XML files. I was given the corresponding ecore schema in a xml format but I wasn't able to load it directly in a emf project (some prefix were null).
What I have done so far :
- Created a EMF project in eclipse. Creating a ecore schema for each "branch" of the packages (the original schema contained some packages attached to org.apache.xxx. some others to com.xxx. etc)
- Corrected the null prefix
- Created generators for each "branch" with reference to other generators (because of dependencies)
- Generated the code of the generators
- Try to execute the following code :
XMIResource resource = new XMIResourceImpl(
		URI.createURI("file:" + pathOfFile));
		resource.load(null);
		for (EObject eo : resource.getContents()) {
			System.out.println(eo.eClass().getInstanceClassName());
When I try this code with a xml file containing only one kind of entities (without external references of course), all works perfectly and I can load my objects.
When I try this code on a complete xml file (containing different kind of objects with references etc...), I get an org.eclipse.emf.ecore.xmi.IllegalValueException caused by a java.lang.ArrayStoreException when it comes to the first line in the file where the kind of entity changes.
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.apache.uima.tika.impl.AttributeFSImpl@15b1773 (localName: xxx, qualifiedName: xxx, uri: , value: xxx)' is not legal. (file:xxx.xml, -1, -1)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2663)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1149)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHandler.java:1228)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endDocument(AbstractSAXParser.java:737)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:516)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
	at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
	... 20 more
Caused by: java.lang.ArrayStoreException
	at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.java:124)
	at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList.java:448)
	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUnique(NotifyingListImpl.java:393)
	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:377)
	at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1200)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2658)
	... 31 more
Actually, the new entity mentioned at this line is also coming from an other package but I don't know if the error comes from the new kind of entity or of the difference of package. I was unable to test because of the huge number of references between entities (I was only able to find a small group of the same type without references to make the first test). The ArrayStore Excerption make me think that the loader can't store in the same array different kinds of entities but it seems a bit strange to me (I thought it was using arrays of EObject that are quite general to store all the entities loaded from the xml resource).
Do you have any idea to help me at this point ?
Thanks very much in advance.
[Updated on: Thu, 15 September 2011 14:01]
Report message to a moderator
Re: Problem while loading entities of different type in a XMLResource [message #725687 is a reply to message #725665] Thu, 15 September 2011 14:01 Go to previous messageGo to next message
Thomas,
Comments below.
On 15/09/2011 6:47 AM, Thomas Ricatte wrote:
> null).
Normally you load using a resource set. If you use Generate Test Code
in the Generator you'll see an XyzExample.java in the *.tests project
that shows how you should be loading.
> -1, -1)
So it sounds like there is an ID-based reference to some other object in
the file, but that type of object is not allowed by the feature doing
the referencing. It's impossible to say more...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 20 more
> at
> at
> at
> at
> at
> ... 31 more
It sounds like a same document reference.
You've set a breakpoint to determine which particular reference is
causing the problem?
The debugger will need to be consulted. You're going to have to figure
out which reference is causing the problem. It might well be the case
that the serialization is simply invalid and your not doing anything
wrong in the code. So, set an exception breakpoint on
ArrayStoreException; in the breakpoint view's toolbar you'll see a
button for doing that. No doubt an instance of AttributeFS is
involved. From the stack you'll be able to determine which ID value is
being resolved and which feature is being assigned.
Re: Problem while loading entities of different type in a XMLResource [message #725958 is a reply to message #725687] Fri, 16 September 2011 09:29 Go to previous message
Thanks a lot for your answer !
I have tried to put some breakpoints on ArrayStoreException as you proposed and I was able to find the feature assignment that was buggy (it involved a reference to an other object not mentioned in the error trace).
There's indeed something strange in the schema itself if I am not mistaken (the other object was waiting for a certain type of attributes that is incompatible with AttributeFS. However, the data xml files are using AttributeFS as attributes of this object).
I will try to investigate a bit this problem and I will maybe come back to ask other questions if necessary.
Thanks again,
Thomas
Previous Topic:[CDO] export question
Next Topic:(no subject)
Current Time: Tue Apr 24 14:55:04 GMT 2018
Powered by FUDForum. Page generated in 0.01698 seconds
