Home » Newcomers » Newcomers » Tomcat failed to start(Tomcat failed to start in my Eclipse )
icon4.gif  Tomcat failed to start [message #725428] Wed, 14 September 2011 18:30 Go to next message
chandrurajendran.1217 is currently offline chandrurajendran.1217Friend
Please help me,
when i changed the versions of tomcat in my eclipse the problem started, it's been already two that the tomcat error ruined my work, i have tried everything but my eclipse says the tomcat failed to start, after many fine tunes now it shows this error msg,
"Server Tomcat v7.0 Server at localhost was unable to start within 45 seconds. If the server requires more time, try increasing the timeout in the server editor."
even after increasing start time the same error returns, my console says,
14 Sep, 2011 11:55:30 PM org.apache.catalina.core.AprLifecycleListener init
INFO: Loaded APR based Apache Tomcat Native library 1.1.22.
INFO: APR capabilities: IPv6 [false], sendfile [true], accept filters [false], random [true].
14 Sep, 2011 11:55:30 PM org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:jsep' did not find a matching property.
14 Sep, 2011 11:55:31 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-apr-8080"]
INFO: Initializing ProtocolHandler ["ajp-apr-8009"]
14 Sep, 2011 11:55:31 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1163 ms
14 Sep, 2011 11:55:31 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
14 Sep, 2011 11:55:31 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.21
14 Sep, 2011 11:55:31 PM org.apache.catalina.startup.Catalina start
SEVERE: Catalina.start:
org.apache.catalina.LifecycleException: Failed to start component [StandardServer[8005]]
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:152)
at org.apache.catalina.startup.Catalina.start(Catalina.java:621)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:322)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:450)
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardService[Catalina]]
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:727)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:148)
... 7 more
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina]]
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:443)
... 9 more
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost]]
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1033)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:291)
... 11 more
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[]]
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:774)
... 14 more
Caused by: java.lang.NoSuchMethodError: javax.servlet.ServletContext.getSessionCookieConfig()Ljavax/servlet/SessionCookieConfig;
at org.apache.catalina.deploy.WebXml.configureContext(WebXml.java:1308)
at org.apache.catalina.startup.ContextConfig.webConfig(ContextConfig.java:1390)
at org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:896)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:322)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5103)
... 17 more
INFO: Server startup in 216 ms
what could be wrong, what i can do start the tomcat, somebody please help me..!!!
Re: Tomcat failed to start [message #725478 is a reply to message #725428] Wed, 14 September 2011 21:32 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 14-Sep-11 12:30, chandrurajendran.1217 wrote:
> Please help me,
> [snip]
> help me..!!!
This is a question for the Eclipse web tools forum. In the meantime, you
should look at http://wiki.eclipse.org/WTP_Tomcat_FAQ
Re: Tomcat failed to start [message #870395 is a reply to message #725478] Mon, 07 May 2012 23:50 Go to previous messageGo to next message
Venkat Star is currently offline Venkat StarFriend
You just have to double click the server in Eclipse, in the servers perspective, when you double click it you will see a window showing server config and a section named Timeouts.
hope it work for you.
Re: Tomcat failed to start [message #1705314 is a reply to message #725428] Thu, 13 August 2015 16:57 Go to previous message
Eclipse Fan is currently offline Eclipse FanFriend
Web.xml is the culprit. After wasting a day for searching the solution, i tried removing the web.xml.
step to try -
1. Remove web.xml (DD) from web-inf
2. Right Click on Deployment Descriptor and click Recreate DD stub
it will create a new web.xml
3. step by step check where the issue is arising. IE add the details in web.xml and keep running the project after each entry.
Hope it helps.
Previous Topic:New Android Project option missing in File -> New...
Next Topic:Eclipse - Resource Hog?
Current Time: Sat Jan 20 11:31:19 GMT 2018
Powered by FUDForum. Page generated in 0.02990 seconds
