Home » Archived » Test and Performance Tools Platform (TPTP) » SampleClient TPTPAgent - Invalid Login Credentials
SampleClient TPTPAgent - Invalid Login Credentials [message #77635] Tue, 18 July 2006 14:10 Go to next message
Originally posted by: martin.schuetz.vmasch.at
I'm trying the TPTPAgent-Sample
( http://www.eclipse.org/tptp/platform/documents/newtechAC/jav adoc/TPTPAgent.java)
to connect to AC and to query all available and runnning agents. I'm using
the same data for the ConnectionInfo-object (host "127.0.0.1" and port
"10002") as in the "Profile"-window via Eclipse (where I can see AC with all
available agents).
Executing the sample, I get the following output:
Connecting to AC..
Error occurred while connecting to
127.0.0.1:org.eclipse.tptp.platform.execution.exceptions.Age ntControllerUnavailableException:
Error: Unable to connect to the Agent Controller.Invalid Login Credentials
I set the AC-network access mode to "ALL" and security enabled to "FALSE"
.... I also configured the AC and tried the connect(ConnectionInfo connInfo,
User user)-method, but it doesn't work.
I'm using Eclipse 3.2.0, TPTP 4.2 and the new technology Agent Controller.
Re: SampleClient TPTPAgent - Invalid Login Credentials [message #77667 is a reply to message #77635] Tue, 18 July 2006 15:56 Go to previous messageGo to next message
Thayaparan Shanmugaratnam is currently offline Thayaparan ShanmugaratnamFriend
You may what to try connecting to the Agent Controller using the old API.
You will be able find a sample of how it is used if you extract the class
AutomationUtil and look at method connect().
AutomationUtil is located in:
/test-results/platform/org.eclipse.tptp.ac.testautomation/sr c/org.eclipse.tptp.ac.testautomation.internal.util
I hope this helps.
-Thay
Re: SampleClient TPTPAgent - Invalid Login Credentials [message #77716 is a reply to message #77635] Tue, 18 July 2006 22:05 Go to previous messageGo to next message
Randy D. Smith is currently offline Randy D. SmithFriend
That's documentation for 4.1.0 sample code... how did you get here?
> available agents).
> Connecting to AC..
> Thanks
If you're using that Callisto stuff, you can do as I did
(1) cd
<callisto_install_dir> /eclipse/plugins/org.eclipse.tptp.platform.execution_4.2.0.v 200606140100/src
(2) javac org/eclipse/tptp/platform/execution/samples/TPTPAgent.java -cp
.../tptpcore.jar
(3) java -cp ../tptpcore.jar
oreg/eclipse/tptp/platform/execution/sample/TPTPAgent
I get:
Connecting to AC..
Connected to localhost at port number 10006
Querying Available Agents ...
Available Agents ::org.eclipse.tptp.FileTransferAgent
Available Agents ::org.eclipse.tptp.JavaTimeCollector
Available Agents ::org.eclipse.tptp.legacy.DumpAgent
Available Agents ::org.eclipse.tptp.StressAgent
Available Agents ::org.eclipse.tptp.TimeCollector
Available Agents ::org.eclipse.tptp.legacy.Java
Available Agents ::Profiling
Available Agents ::Agent
Querying Available Agents by type...
Querying Running Agents...
# of Running Agents ::1
Running Agents ::ProcessController
Querying Running Agents by type ...
# of Running Agents ::0
Agent MetaData ::
Agent ID for the agent ac 1
Agent ID for the agent ac true 2
Thay... how do you "query all available and runnning agents" with the
RAC API? I thought that was one of the distinct advantages of the "new
tech AC"!
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: SampleClient TPTPAgent - Invalid Login Credentials [message #77732 is a reply to message #77716] Wed, 19 July 2006 06:47 Go to previous messageGo to next message
I started my challenge via
http://www.eclipse.org/tptp/platform/documents/newtechAC/jav adoc/overview-summary.html
.... and I unfortunately mixed different versions.
Now it works,
Thanks!
"Randy D. Smith" <randy.d.smith@intel.com> schrieb im Newsbeitrag
news:e9jlvg$5g1$1@utils.eclipse.org...
>> using the same data for the ConnectionInfo-object (host "127.0.0.1" and
>> port "10002") as in the "Profile"-window via Eclipse (where I can see AC
>> with all available agents).
>> Connecting to AC..
>> Credentials
>> connInfo, User user)-method, but it doesn't work.
>> Controller.
>> Thanks
> (1) cd
> ../tptpcore.jar
> I get:
> Connecting to AC..
> Agent MetaData ::
> Thay... how do you "query all available and runnning agents" with the RAC
> API? I thought that was one of the distinct advantages of the "new tech
> AC"!
> RDS
Re: SampleClient TPTPAgent - Invalid Login Credentials [message #77856 is a reply to message #77732] Wed, 19 July 2006 16:30 Go to previous message
> Now it works,
> Thanks!
I'm glad it works for you. I don't want to belabor the point, but I do
want to prevent anyone else going down this path... can you tell me more
explicitly how you got to the above so that I can bugzilla the
appropriate links to clean things up? I tried going through the main
Documentation link from TPTP, and then through Platform; then tried
through Platform link from TPTP, and then to Documentation... the
variations I tried didn't take me anywhere I saw any newtechAC references.
If you can recall the path you took, I'll try to get it cleaned up. Thanks.
RDS
Previous Topic:Test guidelines
Next Topic:Coverage RAC: missing feature.properties
Current Time: Wed Feb 21 23:44:20 GMT 2018
Powered by FUDForum. Page generated in 0.01743 seconds
