| Re: UTF-8 - without BOM [message #725249 is a reply to message #724353] |
Wed, 14 September 2011 07:03   |
Originally posted by: Thomas Mooshammer
afaik eclipse does not add BOM.
just set the project's text-file encoding to utf-8.
(Menu: Project->Properties->Resource:Text File Encoding)
Am 12.09.2011 09:09, schrieb fred133084:
> hello, my text file encoding project must be in UTF-8 without BOM.
> how do ?
> nb : no, i really not use UTF-8, because the opensource project is in
> utf-8 without bom, and use utf-8 with bom cause a lot of bugs. So,
> actually, we use notepad ++ yeapppyyyy :(
> please help !
| Re: UTF-8 - without BOM [message #725818 is a reply to message #725423] |
Thu, 15 September 2011 17:06  |
you can verify inside eclipse by right-clicking the file in an explorer
view and choosing properties.
if the file has a BOM (either because it existed before or another
editor inserted it), there is a third line inside the text-file-encoding
box saying "Byte Order Mark is UTF-8 BOM".
eclipse preserves existing byte order mark but does not create it for
new files.
i'm using eclipse indigo and pdt on windows xp, both text and php files
created inside eclipse open with Encoding "UTF-8 without BOM" in notepad ++
Am 14.09.2011 20:26, schrieb fred133084:
> thanks...
> but i don't understand ... when i create a file and open it in notepad++
> the encoding file is utf-8 with BOM :(
> i use PDT ?! may be ?
FUDForum. Page generated in 0.01824 seconds
