Home » Eclipse Projects » Rich Client Platform (RCP) » How to use SpellingService
How to use SpellingService [message #723144] Wed, 07 September 2011 19:56 Go to next message
Dennis Melzer is currently offline Dennis MelzerFriend
how can i use the ui.texteditor SpellingService in a SourceViewer? If i write a wrong word nothing is underlined. What's missing?
My try:
SourceViewer viewer =new SourceViewer(currentVersionTextsComposite,null,SWT.BORDER | SWT.WRAP | SWT.MULTI | SWT.V_SCROLL  );
            IPreferenceStore iPreferenceStore = new PreferenceStore();
            iPreferenceStore.setValue(SpellingService.PREFERENCE_SPELLING_ENABLED, true);
            TextSourceViewerConfiguration configuration = new TextSourceViewerConfiguration(iPreferenceStore);
            viewer.configure(configuration);
Re: How to use SpellingService [message #723847 is a reply to message #723144] Fri, 09 September 2011 16:36 Go to previous messageGo to next message
So my new version: It will show a popup but the wrong word isn't underlined? What do i have to do?
 final SourceViewer sourceViewer = new SourceViewer(parent, null, null,
                true, SWT.MULTI | SWT.V_SCROLL | SWT.WRAP);
        // grab the text widget from the source viewer
        StyledText fTextField = sourceViewer.getTextWidget();
        // this is where the magic happens for spellchecking
        // see TextSourceViewerConfiguration#getReconciler
        Document document = new Document("dfg");
        SourceViewerConfiguration config = new TextSourceViewerConfiguration(
                EditorsUI.getPreferenceStore());
        sourceViewer.configure(config);
        sourceViewer.setDocument(document, new AnnotationModel());
Re: How to use SpellingService [message #724793 is a reply to message #723847] Tue, 13 September 2011 07:33 Go to previous messageGo to next message
Nobody any idea?
Re: How to use SpellingService [message #724954 is a reply to message #723847] Tue, 13 September 2011 15:13 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
If you don't have JDT installed then you won't have a spelling engine.
Maybe that's your problem? See https://bugs.eclipse.org/185695.
Dani
Re: How to use SpellingService [message #726146 is a reply to message #724954] Fri, 16 September 2011 16:40 Go to previous messageGo to next message
no i have jdt installed
here my new version with underlined words =), but now i miss the quick assistant =(. and how can i choose a dictanory?
		private void createSourceViewer(Composite parent) {
			final IAnnotationAccess access = new DefaultMarkerAnnotationAccess();
					null, true, SWT.MULTI | SWT.V_SCROLL | SWT.WRAP);
			SourceViewerDecorationSupport decorationSupport = new SourceViewerDecorationSupport(
					sourceViewer, null, access, EditorsPlugin.getDefault()
							.getSharedTextColors());
			configureSourceViewerDecorationSupport(decorationSupport);
			if (sourceViewer instanceof ISourceViewerExtension3)
				((IAnnotationAccessExtension2) access)
						.setQuickAssistAssistant(((ISourceViewerExtension3) sourceViewer)
								.getQuickAssistAssistant());
			GridDataFactory.fillDefaults().grab(true, true)
					.applyTo(sourceViewer.getTextWidget());
		private void configureSourceViewerDecorationSupport(
				SourceViewerDecorationSupport support) {
			for(Object o :new MarkerAnnotationPreferences()
			.getAnnotationPreferences())
				support.setAnnotationPreference((AnnotationPreference)o);
			support.setCursorLinePainterPreferenceKeys(
					AbstractDecoratedTextEditorPreferenceConstants.EDITOR_CURRENT_LINE,
					AbstractDecoratedTextEditorPreferenceConstants.EDITOR_CURRENT_LINE_COLOR);
			support.install(EditorsUI.getPreferenceStore());
Re: How to use SpellingService [message #727886 is a reply to message #726146] Thu, 22 September 2011 06:45 Go to previous messageGo to next message
Take a look at TextSourceViewerConfiguration.
Dani
> null,
Re: How to use SpellingService [message #728378 is a reply to message #727886] Fri, 23 September 2011 07:02 Go to previous messageGo to next message
ok which line,section or methode =).
i set the textviewerconfiguration in my sourceviewer
			((IAnnotationAccessExtension2)access).setQuickAssistAssistant(((ISourceViewerExtension3)sourceViewer).getQuickAssistAssistant());
the QuickAssistAssistant is the SpellingCorrectionProcessor
[Updated on: Fri, 23 September 2011 07:33]
Report message to a moderator
Re: How to use SpellingService [message #730871 is a reply to message #728378] Thu, 29 September 2011 12:27 Go to previous messageGo to next message
*push* Razz
Has anybody an information for me ?
Re: How to use SpellingService [message #732281 is a reply to message #730871] Tue, 04 October 2011 12:13 Go to previous message
The SpellingEngine works fine, but the quick assistant not.
Do i need the extension point quickDiffReferenceProvider from ui.workbench.texteditor?
Previous Topic:eclipse.ini for Windows built on Linux is unix format
Next Topic:RetargetAction behavior with command/handler/menu extension points
Current Time: Sun Apr 22 05:19:34 GMT 2018
Powered by FUDForum. Page generated in 0.02663 seconds
