Home » Language IDEs » C / C++ IDE (CDT) » C++ Build problem!!!!!!!!!!!!
C++ Build problem!!!!!!!!!!!! [message #721916] Sat, 03 September 2011 15:31 Go to next message
Gabriel Ameen is currently offline Gabriel AmeenFriend
Hi friends,
I facing a problem with Eclipse IDE and MinGW, hope you will help me out. This is how I installed eclipse.
1. I installed JRE.
2. I donwloaded the MinGW automatic installer, installed everything except Fortran compiler, under C:\MinGW
3. Then I added C:\MinGW\bin to my system path variable.
4. Then I downloaded Eclipse IDE for C/C++ Developers (includes Incubating components), extracted it under C:\eclipse
Now when I create a c project, with .c source file, the build is successfuly done, and I can run the executable created. But when I try to do the same thing with a c++ project, I face the following errors.
Description	                        Resource         Path   Location
Symbol 'cout' could not be resolved	First.cpp	/First/src	line 13	Semantic Error
Symbol 'endl' could not be resolved	First.cpp	/First/src	line 13	Semantic Error
Symbol 'std' could not be resolved	First.cpp	/First/src	line 10	Semantic Error
Error launching external scanner info generator (g++ -E -P -v -dD C:/Users/dawood/workspace/.metadata/.plugins/org.eclipse.cdt.make.core/specs.cpp)	First		[Discovery Options] page in project properties	C/C++ Problem
Program 'g++' is not found in $PATH	First		[Discovery Options] page in project properties	C/C++ Problem
I searched for the iostream under C:\MinGW but couldn't find, why is iostream not included with MinGW???
I am running Windows 7 x64 Ultimate SP1, please help me with this! Looking forward to your replies!
Thanks in advance!
Re: C++ Build problem!!!!!!!!!!!! [message #721928 is a reply to message #721916] Sat, 03 September 2011 16:24 Go to previous messageGo to next message
Joost Kraaijeveld is currently offline Joost KraaijeveldFriend
What is the extension of the C++ file?
> Location
> 13 Semantic Error
> 13 Semantic Error
> 10 Semantic Error
What namespace is imported (if any)?
Joost
Re: C++ Build problem!!!!!!!!!!!! [message #721932 is a reply to message #721928] Sat, 03 September 2011 16:58 Go to previous messageGo to next message
It is .cpp
I didn't get this part of your question, I am giving all the code for your information.
#include <iostream>
using namespace std;
int main()
     cout << "Hello, world!\n";
     return 0;
Re: C++ Build problem!!!!!!!!!!!! [message #721942 is a reply to message #721932] Sat, 03 September 2011 17:58 Go to previous messageGo to next message
From your previous mail:
Did you look at this? Is g++ installed and in the path?
Joost
Re: C++ Build problem!!!!!!!!!!!! [message #721944 is a reply to message #721942] Sat, 03 September 2011 18:23 Go to previous messageGo to next message
Joost Kraaijeveld wrote on Sat, 03 September 2011 13:58
Joost
Somehow after reinstalling my problem has been solved, but now another problem rises. printf gives console display, while cout doesn't!
Re: C++ Build problem!!!!!!!!!!!! [message #759157 is a reply to message #721944] Sun, 27 November 2011 03:15 Go to previous message
Marco.Leise is currently offline Marco.LeiseFriend
Write
cout << "Hello, world!" << endl;
endl will flush the buffer.
Previous Topic:[SOLVED] Errors from eclipse cdt core on startup, even after fresh install
Next Topic:How to build a project with "./configure && make"
Current Time: Fri Apr 20 18:52:25 GMT 2018
Powered by FUDForum. Page generated in 0.01941 seconds
