Home » Eclipse Projects » Platform - User Assistance (UA) » Error Message
Error Message [message #721130] Wed, 31 August 2011 23:48 Go to next message
hansho13 is currently offline hansho13Friend
Hey guys.
Whenever I try to run a program in eclipse, it gives me an error message in the console. It looks like this:
Error: Could not find or load main class var
I would really appreciate if someone could help me. Thanks!
Re: Error Message [message #721776 is a reply to message #721130] Fri, 02 September 2011 20:33 Go to previous messageGo to next message
Chris Goldthorpe is currently offline Chris GoldthorpeFriend
Can you give more details about what you are doing? It sounds as though you are able to launch Eclipse but are unable to run a Java program, is that correct?
Re: Error Message [message #721837 is a reply to message #721776] Sat, 03 September 2011 04:36 Go to previous messageGo to next message
yes that's correct
Re: Error Message [message #723176 is a reply to message #721837] Wed, 07 September 2011 22:49 Go to previous messageGo to next message
There is a cheat sheet on how to run a Java program from Eclipse. From the Menu Bar select Help/Cheat Sheets. I the dialog that opens expand the Java Development category, select Create a Hello World Application and follow the steps. If this does not work let me know which step failed.
Re: Error Message [message #731550 is a reply to message #723176] Sat, 01 October 2011 17:34 Go to previous message
Chris Goldthorpe wrote on Wed, 07 September 2011 18:49
Okay it worked! Thanks for your help Smile
Previous Topic:Context sensitive help flashes no topic found, then finds topic
Next Topic:Implementing org.eclipse.ui.cheatsheets.cheatSheetItemExtension
Current Time: Thu Feb 22 17:18:44 GMT 2018
Powered by FUDForum. Page generated in 0.01927 seconds
