Home » Newcomers » Newcomers » Changing the Data Source of a Crosstab(Changing the Data Source of a Crosstab)
Changing the Data Source of a Crosstab [message #721123] Wed, 31 August 2011 23:03 Go to next message
Jeff Rasmussen is currently offline Jeff RasmussenFriend
This is my first post so I'm going to apologize up front if this message does not conform to etiquette guidelines. If it does, perhaps someone can point me to the correct reference materials?
Now that that is out of the way, my issue, which seems to have not been asked this way is as follows:
the BIRT reports we deploy target many different environments each with their own data.
so, to facilitate this, prior to running any report, all data sources in the rptdesign are updated with the current system's connection information (url, user, pass, driverClass). This allows us to connect the report to the same data source as the rest of the application.
to do that we do this:
Iterator<OdaDataSourceHandle> dataSourceIter = designHandle.getDataSources().iterator();
while (dataSourceIter.hasNext()) {
OdaDataSourceHandle dataSourceHandle = dataSourceIter.next();
if (this.usePropertiesDatasource(dataSourceHandle)) {
dataSourceHandle.setPropertyBinding("odaDriverClass", enquote(getOdaDriverClass()));
dataSourceHandle.setPropertyBinding("odaURL", enquote(getOdaURL()));
dataSourceHandle.setPropertyBinding("odaUser", enquote(getOdaUser()));
dataSourceHandle.setPropertyBinding("odaPassword", enquote(getOdaPassword()));
The problem arises when we have a crosstab on the report. With or without the crosstab on the report, the property bindings appear to be reset correctly and the ones applied in the above method are used. However, when a crosstab is on the report, all tables and crosstabs ignore the changed datasource and instead, use the one that's previously included with the rptdesign even though all the properties should have already been updated.
Perhaps we're using the update wrong? This whole process works fine when there's only a table on the report.
Thanks for any and all ideas,
Jeff
Re: Changing the Data Source of a Crosstab [message #721466 is a reply to message #721123] Thu, 01 September 2011 19:18 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
BIRT has its own group in the forums, so you'll probably get more help
there as opposed to this "Newcomers" group.
Eric
> their own data.
> already been updated. Perhaps we're using the update wrong? This whole
> Jeff
Previous Topic:Can't show some of my images on the website
Next Topic:[SOLVED] Error when attempting to upgrade to Indigo on a Mac
Current Time: Wed Apr 25 07:17:21 GMT 2018
Powered by FUDForum. Page generated in 0.02455 seconds
