Home » Newcomers » Newcomers » Problems with org.apache.derby.jdbc.EmbeddedDriver(I am having problems with the EmbeddedDriver in Ecliplse)
Problems with org.apache.derby.jdbc.EmbeddedDriver [message #721023] Wed, 31 August 2011 17:54 Go to next message
Bion Hall is currently offline Bion HallFriend
I am trying to use the embeddeddriver for apache.derby. when I exec the code:
String DRIVER = "org.apache.derby.jdbc.EmbeddedDriver";
String URL = "jbdc:derby:C:\\Documents and Settings\\Bion Hall\\MyDB";
String QUERY = "SELECT FULLNAME FROM WEB1.LOGON WHERE USERID = ?";
try{
Class.forName(DRIVER).newInstance();
I get the following errors:
java.lang.ClassNotFoundException: org.apache.derby.jdbc.EmbeddedDriver
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1676)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1521)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
I have changed the CLASSPATH values, I have moved derby.jar to the WEB-INF/LIB folder and everything else I can find on the web. But nothing works. Any help would be greatly appreaciated.
Bion Hall
Re: Problems with org.apache.derby.jdbc.EmbeddedDriver [message #721049 is a reply to message #721023] Wed, 31 August 2011 19:21 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
> code: String DRIVER = "org.apache.derby.jdbc.EmbeddedDriver";
> try{
> I get the following errors: java.lang.ClassNotFoundException:
> at
> at
> Bion Hall
Dropping the JAR into your project is only the first of three steps. You
allude to the second one, that of adding it to the CLASSPATH via the
Build Path dialog. The third step is, I'm guessing this is a Dynamic Web
Project, adding this to the Deployment Assembly (right-click the
project, choose Properties, then Deployment Assembly.
Previous Topic:modify what is listed in package explorer
Next Topic:Can't activate breakpoint in Eclipse under Windows (Video)
Current Time: Fri Apr 20 23:57:03 GMT 2018
Powered by FUDForum. Page generated in 0.02767 seconds
