Home » Modeling » M2T (model-to-text transformation) » [Acceleo](eIsSet() Function)
[Acceleo] [message #720368] Tue, 30 August 2011 13:18 Go to next message
Frank  is currently offline Frank Friend
Hi !
Acceleo 3.0 & Helios Eclipse.
I want to use function eIsSet(Feature f) in my Acceleo template. Is it possible to get Feature from metamodel without using Wraper java ?
[Updated on: Tue, 30 August 2011 15:13]
Report message to a moderator
Re: [Acceleo] [message #720737 is a reply to message #720368] Wed, 31 August 2011 07:26 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
Hi Frank,
You can use from Acceleo any method that is modelized in the target metamodel. In the current case, you can use the EClass methods :
[self.eIsSet(self.eClass().getEStructuralFeature('<feature name>'))/]
Laurent Goubet
Previous Topic:[Acceleo 3] select() work on Acceleo 2 but not on Acceleo 3
Next Topic:[Acceleo] PDE, Ant build and Acceleo(Compiler)
Current Time: Tue Mar 20 11:56:24 GMT 2018
Powered by FUDForum. Page generated in 0.01619 seconds
