Home » Modeling » EMF » Proxy & Lazy Load on Many-To-On Association
Proxy & Lazy Load on Many-To-On Association [message #720216] Tue, 30 August 2011 07:08 Go to next message
Cristian Prevedello is currently offline Cristian PrevedelloFriend
Member
Greetings
i'm having some problems with many-to-one associations and lazy load.
Currently all my entities are marked ad lazy="true". There's no proxy turned on, and so far everything works fine, except for those many-to-one associations who are eagerly loaded.
Until now we were in alpha phase, and were just grounding the application so this issue was not important.
Now we need to start to fine tune the datalayer and loading half database in memory is not an option.
So we turned on
props.setProperty(org.eclipse.emf.teneo.PersistenceOptions.SET_PROXY,"true");
First problem is referenced entity is still eagerly loaded, and i get an exception in the eSet method of my containing entity:
public void eSet(int featureID, Object newValue) {
switch (featureID)
case MyPagePackage.XXXXX:
setMyReferenceProperty((MyClass)newValue);
newvalue is an HibernateProxy and is casted to MyClass throwing an exception.
The faq mentions disabling "resolve proxies" on the model: i did this but still the property is eagerly loaded.
thank you in advance.
best regards.
[Updated on: Tue, 30 August 2011 07:27]
Report message to a moderator
Re: Proxy & Lazy Load on Many-To-On Association [message #720231 is a reply to message #720216] Tue, 30 August 2011 07:47 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Resolve proxies is set on the ereference.
To find out why the proxy get's loaded get the Hibernate source code and put a breakpoint in
AbstractLazyInitializer.initialize. The callstack should show what calls the proxied object. Can you post the callstack
here if you feel it is teneo/emf code?
Not sure why the CCE happens, see this part of the hibernate docs:
http://docs.jboss.org/hibernate/core/3.6/reference/en-US/html_single/#performance-fetching-proxies
especially about the example cat/domesticcat. Could that be the issue here?
gr. Martin
On 08/30/2011 09:08 AM, cristian.prevedello wrote:
> Greetings
> So we turned on
> entity:
> switch (featureID)
> The faq mentions disabling "resolve proxies" on the model, but could not find any othe informations about. This might
> fix the lazy load problem, but what about the hibernateproxy cast problem?
> best regards.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Proxy & Lazy Load on Many-To-On Association [message #720246 is a reply to message #720231] Tue, 30 August 2011 08:10 Go to previous messageGo to next message
Member
Ty Martin, as you wrote i was browsing emf.codegen code looking for reloveproxy stuff and found it. been wandering for a while looking for this option and it was under my eyes.
anyhow this is the stack :
VariabileUtente is the my container class, while ParametroQuestionario is the contained class.
with at com.ViewShape.DAO.ViewShapeDAO.loadVariabileUtenteById(ViewShapeDAO.java:600)
i'm loading an instance of VariabileUtente by Id. In the stack trace there's not sign of LazyLoad initializer
this is mapping extract of VariabileUtente
<class name="com.ViewShape.Model.ViewshapemodelFactory$6" entity-name="VariabileUtente" abstract="false" lazy="true" discriminator-value="VariabileUtente" table="`variabileutente`" proxy="com.ViewShape.Model.Base.VariabileUtente">
<many-to-one name="ParametriQuestionari" entity-name="ParametroQuestionario" lazy="proxy" cascade="all" foreign-key="variabileutente_parametriquestionari" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`parametroquestionario_parametriquestionari_e_id`"/>
</many-to-one>
mapping for ParametroQuestionario
<class name="com.ViewShape.Model.ViewshapemodelFactory$29" entity-name="ParametroQuestionario" abstract="false" lazy="true" discriminator-value="ParametroQuestionario" table="`parametroquestionario`" proxy="com.ViewShape.Model.Base.ParametroQuestionario">
java.lang.ClassCastException: org.hibernate.proxy.HibernateProxy_$$_javassist_0 cannot be cast to com.ViewShape.Model.Base.ParametroQuestionario
at com.ViewShape.Model.Base.VariabileUtente.eSet(VariabileUtente.java:2171)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1081)
at org.eclipse.emf.teneo.hibernate.mapping.property.EReferencePropertyHandler.set(EReferencePropertyHandler.java:190)
at org.hibernate.tuple.entity.AbstractEntityTuplizer.setPropertyValues(AbstractEntityTuplizer.java:583)
at org.hibernate.persister.entity.AbstractEntityPersister.setPropertyValues(AbstractEntityPersister.java:3822)
at org.hibernate.engine.TwoPhaseLoad.initializeEntity(TwoPhaseLoad.java:152)
at org.hibernate.loader.Loader.initializeEntitiesAndCollections(Loader.java:982)
at org.hibernate.loader.Loader.doQuery(Loader.java:857)
at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:274)
at org.hibernate.loader.Loader.loadEntity(Loader.java:2037)
at org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:86)
at org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:76)
at org.hibernate.persister.entity.AbstractEntityPersister.load(AbstractEntityPersister.java:3268)
at org.hibernate.event.def.DefaultLoadEventListener.loadFromDatasource(DefaultLoadEventListener.java:496)
at org.hibernate.event.def.DefaultLoadEventListener.doLoad(DefaultLoadEventListener.java:477)
at org.hibernate.event.def.DefaultLoadEventListener.load(DefaultLoadEventListener.java:227)
at org.hibernate.event.def.DefaultLoadEventListener.proxyOrLoad(DefaultLoadEventListener.java:285)
at org.hibernate.event.def.DefaultLoadEventListener.onLoad(DefaultLoadEventListener.java:152)
at org.hibernate.impl.SessionImpl.fireLoad(SessionImpl.java:1090)
at org.hibernate.impl.SessionImpl.get(SessionImpl.java:1005)
at com.Larix.Utils.DataLayer.DataLayerSessionHibernate.get(DataLayerSessionHibernate.java:87)
at com.ViewShape.ViewShapeModel.tests.ViewShapeModelSearchTests.TestLoadForMultipleJoin(ViewShapeModelSearchTests.java:91)
Re: Proxy &amp;amp; Lazy Load on Many-To-On Association [message #720252 is a reply to message #720246] Tue, 30 August 2011 08:29 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
I can remember having had the same problem and the only solution for us
was to remove the generated proxy="..." in a postprocessing step because
we are loading a pregenerated hbm.xml-File this is not really a problem
to us.
The code looks like this:
> private File generateHbmXML(Properties hibernateProps, File outDir,
> Class<?> dialect, Class<?> idMapper) throws Exception {
> File hbmXML = new File(outDir, dialect.getSimpleName()
> + "-hibernate.hbm.xml");
> ExtensionManager extensionManager = ExtensionManagerFactory
> .getInstance().create();
> extensionManager.registerExtension(IdMapper.class.getName(),
> idMapper.getName());
> extensionManager.registerExtension(SQLNameStrategy.class.getName(),
> BizerbaSQLNameStrategy.class.getName());
> String mapping = HbHelper.INSTANCE.generateMapping(
> new EPackage[] { RetailPackage.eINSTANCE }, hibernateProps,
> extensionManager);
> FileWriter writer = new FileWriter(hbmXML);
> // Last fix up else we get JavaAssist errors
> mapping = mapping.replaceAll("proxy=\"com\\.(\\w+\\.?)*\"", "");
> writer.write(mapping);
> writer.close();
> return hbmXML;
Tom
Am 30.08.11 10:10, schrieb cristian.prevedello:
> with at
> </many-to-one>
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Proxy &amp;amp; Lazy Load on Many-To-On Association [message #720253 is a reply to message #720246] Tue, 30 August 2011 08:31 Go to previous messageGo to next message
Hmm, I mean the stacktrace when you put a breakpoint in the initialize method of the AbstractLazyInitializer, that will
show what code forces the proxy load.
The names of the classes in the mapping seem very strange (with $29 and $6), where is this coming from? It could be related.
gr. Martin
> </many-to-one>
The Netherlands
Re: Proxy &amp;amp; Lazy Load on Many-To-On Association [message #720287 is a reply to message #720253] Tue, 30 August 2011 10:20 Go to previous messageGo to next message
Member
Well AbstractLazyInitializer.initialize is never called...this means the reference is eagerly loaded? It seems it's not a lazy loaded problem then?
about the Factory$ no clue. that's the mapping generated from teneo.
i thought it was proxy stuff. A side one we are not using interfaces for our entities but just plain class (which are not final), so all the proxy stuff should work.
i'm really lost will do some other testing otherwise i'll be forced to rip off from the model some references and will code them by hand.
Re: Proxy &amp;amp;amp; Lazy Load on Many-To-On Association [message #720296 is a reply to message #720287] Tue, 30 August 2011 10:31 Go to previous messageGo to next message
Is it easy for me to reproduce this? If so, then if you can zip something up and email it directly, then I can take a look.
gr. Martin
> code them by hand.
The Netherlands
Re: Proxy &amp;amp;amp; Lazy Load on Many-To-On Association [message #720815 is a reply to message #720296] Wed, 31 August 2011 09:39 Go to previous messageGo to next message
Member
Well before forcing you to dig into the package i tried to solve the problem.
Digging more into the problem i discovered several problems:
First of all all my entities were marked as lazy="false". i guess with all the tests i made i got screwed up the configuration. This caused the eager load of all entities.
To fix this i extracted the mapping, saved to an xml and updated, setting all my entities as as lazy loadable and now lazy loading was working. Tried to turn on proxy configuration option and again lazy loading was working.
At this point things improved a bit. References are not eagerly loaded, but the ESet method on my entites throws an exception. To fix the problem i had to do something like this in eSet, but this causes the reference to be lazy loaded.
case ViewshapemodelPackage.VARIABILE_UTENTE__CONFIGURAZIONE_QUESTIONARIO_STANDARD:
setConfigurazioneQuestionarioStandard((QuestionarioStandard)((HibernateProxy)newValue).getHibernateLazyInitializer().getImplementation());
kinda lost at this point. Hibernate proxy should derive from my base classes, so i should be able be casted to model classes without problem, right?
[Updated on: Wed, 31 August 2011 16:30]
Re: Proxy &amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #721042 is a reply to message #720815] Wed, 31 August 2011 18:30 Go to previous messageGo to next message
Hi Cristian,
I published a new teneo build with a new PersistenceOption: PersistenceOptions.FORCE_LAZY (default is false, you need to
set it to true), the full option name is teneo.mapping.force_lazy. Can you try with setting this option to true?
And set the SET_PROXY option to false. This should force lazy="true" in the mapping without the proxy attribute.
The entity which gets loaded in your stack trace, is that the entity you are requesting in
DataLayerSessionHibernate.get, if so, then this is correct, when you get an instance directly with get it is not lazy
loaded/proxied. The same applies when reading instances with a query. Basically only many-to-one associations are
possibly lazily loaded.
The exception you are getting is not 'normal', my feel is that somehow the mapping does not contain the correct
information. Can you retry with the new option above?
gr. Martin
> First of all all my entities are marked as lazy="false". This cause the eager load of all entities. What can cause the
> lazy="false"?
> To fix this i extracted the mapping, saved to an xml and updated, setting all my entities as as lazy loadable.
> At this point things improved a bit. References not eagerly loaded, but there's something that still try to lazy load
> them. Now AbstractInitilizer is hit. here is the stack:
> Thread [main] (Suspended (breakpoint at line 165 in AbstractLazyInitializer))
> JavassistLazyInitializer(AbstractLazyInitializer).initialize() line: 165
> JavassistLazyInitializer(AbstractLazyInitializer).getImplementation() line: 215
> ViewshapemodelFactory$6(VariabileUtente).eSet(int, Object) line: 2205
> ViewshapemodelFactory$6(BasicEObjectImpl).eSet(EStructuralFeature, Object) line: 1081
> EReferencePropertyHandler.set(Object, Object, SessionFactoryImplementor) line: 190
> EMFTuplizer(AbstractEntityTuplizer).setPropertyValues(Object, Object[]) line: 583
> SingleTableEntityPersister(AbstractEntityPersister).setPropertyValues(Object, Object[], EntityMode) line: 3822
> TwoPhaseLoad.initializeEntity(Object, boolean, SessionImplementor, PreLoadEvent, PostLoadEvent) line: 152
> EntityLoader(Loader).initializeEntitiesAndCollections(List, Object, SessionImplementor, boolean) line: 982
> EntityLoader(Loader).doQuery(SessionImplementor, QueryParameters, boolean) line: 857
> EntityLoader(Loader).doQueryAndInitializeNonLazyCollections(SessionImplementor, QueryParameters, boolean) line: 274
> EntityLoader(Loader).loadEntity(SessionImplementor, Object, Type, Object, String, Serializable, EntityPersister,
> LockOptions) line: 2037
> EntityLoader(AbstractEntityLoader).load(SessionImplementor, Object, Object, Serializable, LockOptions) line: 86
> EntityLoader(AbstractEntityLoader).load(Serializable, Object, SessionImplementor, LockOptions) line: 76
> SingleTableEntityPersister(AbstractEntityPersister).load(Serializable, Object, LockOptions, SessionImplementor) line: 3268
> DefaultLoadEventListener.loadFromDatasource(LoadEvent, EntityPersister, EntityKey, LoadEventListener$LoadType) line: 496
> DefaultLoadEventListener.doLoad(LoadEvent, EntityPersister, EntityKey, LoadEventListener$LoadType) line: 477
> DefaultLoadEventListener.load(LoadEvent, EntityPersister, EntityKey, LoadEventListener$LoadType) line: 227
> DefaultLoadEventListener.proxyOrLoad(LoadEvent, EntityPersister, EntityKey, LoadEventListener$LoadType) line: 285
> DefaultLoadEventListener.onLoad(LoadEvent, LoadEventListener$LoadType) line: 152
> SessionImpl.fireLoad(LoadEvent, LoadEventListener$LoadType) line: 1090
> SessionImpl.get(String, Serializable) line: 1005
> DataLayerSessionHibernate.get(String, Serializable) line: 87
> ViewShapeDAO.loadVariabileUtenteById(long) line: 597
> ViewShapeTestData.SetupTestData() line: 85
> Anyway beside lazyloading problem i've still the issue that lazy load entities are proxy, and eSet throws an exception.
> To fix it i had to do something like this in eSet.
> is this normal?
The Netherlands
Re: Proxy &amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #721103 is a reply to message #721042] Wed, 31 August 2011 21:30 Go to previous messageGo to next message
Am 31.08.11 20:30, schrieb Martin Taal:
> Hi Cristian,
> PersistenceOptions.FORCE_LAZY (default is false, you need to set it to
Martin this is exactly what we are using in our teneo application (but
we did it by postprocessing the hbm.xml)
Tom
Re: Proxy &amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #721107 is a reply to message #721103] Wed, 31 August 2011 21:43 Go to previous messageGo to next message
Yes, your remark triggered me to add this! so let's hope it helps...
gr. Martin
>> Hi Cristian,
> Tom
The Netherlands
Re: Proxy &amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #721208 is a reply to message #721107] Thu, 01 September 2011 07:36 Go to previous messageGo to next message
Member
I downloaded your latest build but the new option is not working as expected.
New code should be this, right?
//-------------- THIS IF IS NEVER TRUE SINCE SetProxy is false
// automatically add the proxy annotation
if (optionSetProxy && hbClass.getHbProxy() == null) {
// in this case use the DynamicEObjectImpl
if (concreteClass == null) {
concreteClass = DynamicEObjectImpl.class;
if (concreteClass != null || getPersistenceOptions().isForceLazy()) {
final Proxy proxy = HbannotationFactory.eINSTANCE.createProxy();
proxy.setLazy(true);
// interface class is set below.
((HbAnnotatedEClass) aClass).setHbProxy(proxy);
log.debug("Set proxy to true (" + proxy.getProxyClass()
+ ") for eclass " + aClass.getModelEClass().getName());
//-------------- THIS IF IS NEVER TRUE SINCE hbClass.getHbProxy() is always null for me.
if (hbClass.getHbProxy() != null && concreteClass != null) {
// todo add check that there is an impl class
aClass.setOnlyMapAsEntity(false);
// set interfacename if not set
if (!getPersistenceOptions().isForceLazy()) {
final Proxy proxy = hbClass.getHbProxy();
final Class<?> interfaceClass = EModelResolver.instance()
.getJavaInterfaceClass(eclass);
if (interfaceClass != null) {
proxy.setProxyClass(interfaceClass.getName());
} else { // set the class itself
proxy.setProxyClass(concreteClass.getName());
Beside this, i already tried to feed teneo a mapping file, where i ripped off proxy attributes and just set lazy="true".
i get the cast exception.
i tried to feed
<class name="com.ViewShape.Model.ViewshapemodelFactory$10" entity-name="QuestionarioStandard" abstract="false" lazy="true" discriminator-value="QuestionarioStandard" table="`questionariostandard`" proxy="com.ViewShape.Model.ViewshapemodelFactory$10">
and
<class name="com.ViewShape.Model.ViewshapemodelFactory$10" entity-name="QuestionarioStandard" abstract="false" lazy="true" discriminator-value="QuestionarioStandard" table="`questionariostandard`" proxy="com.ViewShape.Model.Base.QuestionarioStandard">
and
<class name="com.ViewShape.Model.ViewshapemodelFactory$10" entity-name="QuestionarioStandard" abstract="false" lazy="true" discriminator-value="QuestionarioStandard" table="`questionariostandard`" >
but none works. the eSet method explodes because the cast. now i'm going to hunt down where the proxy is created...
Re: Proxy &amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #721240 is a reply to message #721208] Thu, 01 September 2011 08:57 Go to previous messageGo to next message
Member
Oh well i finally discovered the problem. Javassist does not work when it comes to extend a class. It works well when it creates a proxy throught an interface.
In our model generation, we suppressed the usage of interfaces. In our service layer, we create a lot of new instances of our model classes for exchanging infos with our DTOs.
Default generation behaviour is to generate an interface and a corresponding implementation class ( MyEntity and MyEntityImpl), and we did not want to pollute our service layer, with new MyEntityImpl() statments. So we killed interfaces as a quick fix for that.
Now i have to code on my workunit object methos to allocate entity Implementations returned as interfaces.
Not sure if cglib works better on this side, anyhow from first tests in my testcase everything work as expected, lazy load included. yeppa.
Ty Martin for the help. Own you a bear anyhow Smile
Re: Proxy &amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #721259 is a reply to message #721208] Thu, 01 September 2011 09:02 Go to previous messageGo to next message
I published a new build which hopefully helps with the force lazy thing.
For the CCE, this must be related to the strange classname in the hibernate mapping (the one with the $ in it). The
classname is determined when the mapping is generated.
How do you initialize the datastore?
gr. Martin
> i tried to feed
> and
> and
The Netherlands
Re: Proxy &amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #721260 is a reply to message #721240] Thu, 01 September 2011 09:16 Go to previous messageGo to next message
Okay, good to hear, another project (I am leading to :-), which might be interesting is Texo:
http://wiki.eclipse.org/Texo
It generates simpler code than EMF, while still integrating with EMF for model-features and xml/xmi serialization, the
generated code works out of the box on a standard ORM like hibernate. Texo also makes it easy to generate the orm.xml
directly from ecore.
Texo is currently mostly for the server side of (web-)server/service environments. So not for rcp's.
gr. Martin
> to
> Ty Martin for the help. Own you a bear anyhow :)
The Netherlands
Re: Proxy &amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814255 is a reply to message #721260] Tue, 06 March 2012 08:16 Go to previous messageGo to next message
Member
Greetings Marting, how are you? Hope things are going well on your side.
i'm briging up this old post again because new issues about lazy loading ManyToOne came up.
The datamodel is
Class RisultatiQuestinario 1---1 OutputRisposte
the reference is not bidirectional, that is risultatiquestionario has a link to outputrisposte, but not the reverse. And the reference is set as not optional, and with resolveproxy to false.
the generated mappings are
<class name="com.xxx.Model.impl.RisultatiQuestionarioImpl" entity-name="RisultatiQuestionario" abstract="false" lazy="true" discriminator-value="RisultatiQuestionario" table="`risultatiquestionario`" proxy="com.ViewShape.Model.Base.RisultatiQuestionario">
      <id name="Id" type="long" unsaved-value="0">
         <column not-null="true" unique="false" name="`id`"/>
         <generator class="native"/>
      </id>
      <discriminator type="string">
         <column name="dtype" index="risultatiquestionariodtype" length="255" not-null="true"/>
      </discriminator>
      <version name="e_version" type="int">
         <column not-null="true" unique="false" name="`e_version`"/>
      </version>
      <many-to-one name="Risposte" entity-name="OutputRisposte" lazy="proxy" cascade="all" foreign-key="risultatiquestionario_risposte" insert="true" update="true" not-null="true" unique="true">
         <column not-null="true" unique="false" name="`outputrisposte_risposte_e_id`"/>
      </many-to-one>
   <class name="com.xxx.Model.impl.OutputRisposteImpl" entity-name="OutputRisposte" abstract="false" lazy="true" discriminator-value="OutputRisposte" table="`outputrisposte`" proxy="com.ViewShape.Model.Base.OutputRisposte">
The problem is, whenever i load a RisultatiQuestionario class, OutputRisposte is eagerly loaded.
as suggested from hibernate forum i put a breakpoint into immediateload in session hibernate to see what's firing the load.
Thread [main] (Suspended)
	JavassistLazyInitializer.invoke(Object, Method, Method, Object[]) line: 190
	OutputRisposte_$$_javassist_32.eInverseAdd(InternalEObject, int, Class, NotificationChain) line: not available
	RisultatiQuestionarioImpl.setRisposte(OutputRisposte) line: 491
	RisultatiQuestionarioImpl.eSet(int, Object) line: 1368
	RisultatiQuestionarioImpl(BasicEObjectImpl).eSet(EStructuralFeature, Object) line: 1081
	QueryLoader(Loader).initializeEntitiesAndCollections(List, Object, SessionImplementor, boolean) line: 982
	QueryLoader(Loader).doQuery(SessionImplementor, QueryParameters, boolean) line: 857
	QueryLoader(Loader).doQueryAndInitializeNonLazyCollections(SessionImplementor, QueryParameters, boolean) line: 274
	QueryLoader(Loader).doList(SessionImplementor, QueryParameters) line: 2533
	QueryLoader(Loader).listIgnoreQueryCache(SessionImplementor, QueryParameters) line: 2276
	QueryLoader(Loader).list(SessionImplementor, QueryParameters, Set, Type[]) line: 2271
	QueryLoader.list(SessionImplementor, QueryParameters) line: 452
	QueryTranslatorImpl.list(SessionImplementor, QueryParameters) line: 363
	HQLQueryPlan.performList(QueryParameters, SessionImplementor) line: 196
	SessionImpl.list(String, QueryParameters) line: 1268
	QueryImpl.list() line: 102
	DataLayerSessionHibernate.Query(String, Object...) line: 143
	ViewShapeDAO.Query(String) line: 176
	ViewShapeModelTestsSearch.TestGetListaRisultati() line: 838
	NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
	NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
	DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
	Method.invoke(Object, Object...) line: 597
	FrameworkMethod$1.runReflectiveCall() line: 44
	FrameworkMethod$1(ReflectiveCallable).run() line: 15
	FrameworkMethod.invokeExplosively(Object, Object...) line: 41
	InvokeMethod.evaluate() line: 20
	RunBefores.evaluate() line: 28
	BlockJUnit4ClassRunner.runChild(FrameworkMethod, RunNotifier) line: 76
	BlockJUnit4ClassRunner.runChild(Object, RunNotifier) line: 50
	ParentRunner$3.run() line: 193
	ParentRunner$1.schedule(Runnable) line: 52
	BlockJUnit4ClassRunner(ParentRunner<T>).runChildren(RunNotifier) line: 191
	ParentRunner<T>.access$000(ParentRunner, RunNotifier) line: 42
	ParentRunner$2.evaluate() line: 184
	BlockJUnit4ClassRunner(ParentRunner<T>).run(RunNotifier) line: 236
	JUnit4TestMethodReference(JUnit4TestReference).run(TestExecution) line: 49
	TestExecution.run(ITestReference[]) line: 38
	RemoteTestRunner.runTests(String[], String, TestExecution) line: 467
	RemoteTestRunner.runTests(TestExecution) line: 683
	RemoteTestRunner.run() line: 390
	RemoteTestRunner.main(String[]) line: 197
when calling eInverseAdd method, the proxy is loaded and hits the database.
ty for your help.
Re: Proxy &amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814284 is a reply to message #814255] Tue, 06 March 2012 09:03 Go to previous messageGo to next message
Hmm, I read a bit through the thread, but what are your current problems?
gr. Martin
> The datamodel is
> </id>
> </discriminator>
> </version>
> </many-to-one>
The Netherlands
Re: Proxy &amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814292 is a reply to message #814284] Tue, 06 March 2012 09:22 Go to previous messageGo to next message
Member
maybe i should have opened a new thread, since my current problem is not exatly related to what i described previosuly in the thread.
right now, entities are not lazy loaded but eagerly loaded.
RisulatoQuestionario in the model has a one way 1-1 relation with Outputrisposte
the mapping generated is the one in my previous post. The problem is whenever i load 1 risultatoquestonario, outputrisposte is loaded as well. Debugging throught the code,
i tracked down the moment the outputrisposte is loaded.
When RisultatoQuestionario is materialized, hibernate sets a proxy for outputriposte into RisultatoQuestionario.
In the RisultatoQuestionario setter, an inverseAdd method in proxy for outputrisposte is called, and that triggers the load from the database.
Re: Proxy &amp;amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814420 is a reply to message #814292] Tue, 06 March 2012 12:29 Go to previous messageGo to next message
But the association is not bidirectional is it? Hmm, why the inverseadd?
gr. Martin
> in the thread.
The Netherlands
Re: Proxy &amp;amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814497 is a reply to message #814420] Tue, 06 March 2012 14:16 Go to previous messageGo to next message
Member
this is the generated setter code
public void setRisposte(OutputRisposte newRisposte)
		if (newRisposte != risposte)
			NotificationChain msgs = null;
			if (risposte != null)
				msgs = ((InternalEObject)risposte).eInverseRemove(this, ViewshapemodelPackage.OUTPUT_RISPOSTE__RISULTATO_QUESTIONARIO, OutputRisposte.class, msgs);
			if (newRisposte != null)
				msgs = ((InternalEObject)newRisposte).eInverseAdd(this, ViewshapemodelPackage.OUTPUT_RISPOSTE__RISULTATO_QUESTIONARIO, OutputRisposte.class, msgs);
			msgs = basicSetRisposte(newRisposte, msgs);
			if (msgs != null) msgs.dispatch();
		else if (eNotificationRequired())
			eNotify(new ENotificationImpl(this, Notification.SET, ViewshapemodelPackage.RISULTATI_QUESTIONARIO__RISPOSTE, newRisposte, newRisposte));
anyway you gave an idea, i will try to make the relation bidiretional to see if it works.
Re: Proxy &amp;amp;amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814526 is a reply to message #814497] Tue, 06 March 2012 14:58 Go to previous messageGo to next message
I mean the generated code seems to indicate that it is already bidirectional, which explains the inverseAdd. I mean only
bi-directional associations would have that.
I would say that you should not set it to bi-directional to prevent proxy loading.
gr. Martin
The Netherlands
Re: Proxy &amp;amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814534 is a reply to message #814497] Tue, 06 March 2012 15:09 Go to previous messageGo to next message
Member
hmm, is there some place where i set the type of the relationship?
So far i thought a relationship was unidirectional if i had only one link from an entity (A) to another (B)
if i create another link from B to A and i set it as opposite to first one then the relationship is bidirectional, or am i wrong?
Re: Proxy &amp;amp;amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814583 is a reply to message #814534] Tue, 06 March 2012 16:19 Go to previous messageGo to next message
Yes only if there is an opposite set then it is bidirectional, are you sure that the generated code is not accidentally
based on a version with a bi-directional association?
gr. Martin
> i wrong?
The Netherlands
Re: Proxy &amp;amp;amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #815928 is a reply to message #814583] Thu, 08 March 2012 08:04 Go to previous message
Member
Well, yes the model always had an unidirectional relationship between the two entities. anyway creating the opposite relationship, and setting mappedby on the @OneToOne annotation fixed the problem.
I'll investigate with more detail as soon as i've some spare time, since in my model i've some others one-to-one entities, and from a first sight some entities lazy loading works out of the box.
ty
Previous Topic:org.eclipse.emf.ocl
Next Topic:generate ecore from xsd with multiple epackages in the root?
Current Time: Tue Apr 24 12:51:31 GMT 2018
Powered by FUDForum. Page generated in 0.02659 seconds
