Home » Eclipse Projects » Web Tools Project (WTP) » Install J2EE & Spring plugins(Installing J2EE and Spring plugins in Helios for Javascript)
Install J2EE & Spring plugins [message #719524] Sat, 27 August 2011 11:51 Go to next message
Vasanthakumar V is currently offline Vasanthakumar V
Dear All,
Not sure if this has already been discussed in this forum. I have been using eclipse "Helios for Javascript", working on js. Now I have to work in J2EE / Spring. Could you please assist in setting up J2EE / Spring in the same IDE I am using (without having to install eclipse "Helios / Indigo for J2EE")??
[Message initially posted as msg_719468 in "Java tooling in Eclipse" Forum by mistake]
Thanks and Best Regards,
Vasanthakumar V
Re: Install J2EE & Spring plugins [message #719952 is a reply to message #719524] Mon, 29 August 2011 10:47 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
It sounds like you'll want to check the Spring documentation; my guess is that it will direct you to which parts of the Java EE tools from Eclipse that it might need as well as how to install it properly.
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Problem with Indigo and Tomcat 7.0 on fedora 15
Next Topic:Adding Taglibraries to a web app
Current Time: Sun May 19 14:51:52 EDT 2013
Powered by FUDForum. Page generated in 0.01635 seconds
