Home » Eclipse Projects » BIRT » Does BIRT have a Mondrian or XMLA data source?
Does BIRT have a Mondrian or XMLA data source? [message #719328] Fri, 26 August 2011 18:08 Go to next message
diddy  is currently offline diddy Friend
I'd like to know if it is possible to connect to Mondrian (OLAP server)? Or is there at least a way to define a XMLA data source?
Thanks in advance,
Diddy
(no subject) [message #719331 is a reply to message #719328] Fri, 26 August 2011 18:11 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
No currently, but you should be able to access it with a scripted
dataset. If you have Java access to the cubes and data you should be
able to call this api from a scripted data source.
Jason
On 8/26/2011 2:08 PM, diddy wrote:
> Thanks in advance,
> Diddy
Re: (no subject) [message #719370 is a reply to message #719331] Fri, 26 August 2011 20:31 Go to previous messageGo to next message
Thanks a lot for your feedback! I hope BIRT will include in future a dedicate connector as well.
Re: (no subject) [message #719390 is a reply to message #719370] Fri, 26 August 2011 21:38 Go to previous messageGo to next message
We have an ODA framework for just this kind of feature. It allows users
to develop a custom GUI and run time data routines that will be called
by BIRT automatically. If you want more info on developing an ODA let
me know.
Jason
Re: (no subject) [message #719876 is a reply to message #719390] Mon, 29 August 2011 09:45 Go to previous messageGo to next message
Hi Jason,
Thanks, can you please point me to some info on how implement this?
Diddy
Re: (no subject) [message #719978 is a reply to message #719876] Mon, 29 August 2011 15:13 Go to previous messageGo to next message
There is a lot of data available in the DevShare on Birt-Exchange.org
for this. Start with these articles:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/445-oda-primer-articles/
Jason
On 8/29/2011 5:45 AM, diddy wrote:
> Hi Jason,
> Best regards,
> Diddy
Re: (no subject) [message #719980 is a reply to message #719876] Mon, 29 August 2011 15:13 Go to previous messageGo to next message
Jason
> Hi Jason,
> Best regards,
> Diddy
Re: (no subject) [message #720081 is a reply to message #719390] Mon, 29 August 2011 20:35 Go to previous message
Thanks a lot Jason! I'll take a look at this.
Previous Topic:stacked bar chart..
Next Topic:IRR function
Current Time: Wed Jun 20 11:54:57 GMT 2018
Powered by FUDForum. Page generated in 0.02133 seconds
