Home » Eclipse Projects » Remote Application Platform (RAP) » Request Failed: HTTP Status Code: 12002
Request Failed: HTTP Status Code: 12002 [message #719007] Thu, 25 August 2011 19:11 Go to next message
Graham Missing name is currently offline Graham Missing nameFriend
We're running a load balanced RAP 1.3.2 application with jetty. The users are using both IE6SP3 and IE8. We've started experiencing a lot errors of the type "Request Failed. HTTP Status Code: 12002". They seem to be happending when our users access the application through a very large coporate WAN. We have been unable to reproduce the error locally. From what I've read the 12002 is a timeout error. Unfortunately, when this error occurs the users are kicked out of the application and have to log back in and navigate to where they were.
What is the default timeout? I've put some sleep code in the application to try to slow things down but after a 4 minute sleep I still don't see the 12002 error code. Is there a way to catch the error and put a more attractive error message and also not destroy the users session?
Also is there a way to see what request has failed?
Re: Request Failed: HTTP Status Code: 12002 [message #724529 is a reply to message #719007] Mon, 12 September 2011 14:31 Go to previous messageGo to next message
Originally posted by:
Graham,
RAP does not define any timeout. The timeout may be caused by the client
or the sever or anything in between like a proxy or router.
To print a more attractive error message is certainly possible, please
file an enhancement request therefore.
Continuing the broken user session however wouldn't make sense. The
client can't just ignore the missing response as it would bring client
and sever out of sync. Besides, before this message appears, the user
has the opportunity to retry sending the request.
Most browser have built-in tools or plug-ins to track requests that you
can use to analyze the failed request.
HTH
Rüdiger
Rüdiger Herrmann
Twitter: @EclipseRAP
Re: Request Failed: HTTP Status Code: 12002 [message #724602 is a reply to message #724529] Mon, 12 September 2011 16:08 Go to previous message
Cole Markham is currently offline Cole MarkhamFriend
I remember having this discussion a couple of years ago. Since 12002 is a timeout error, it is unknown whether any changes were sent to the server. Thus it is not handled as a "connection error" which prompts the user to retry the request. Instead is just fails and the user gets the error message to restart the system.
I'm afraid your only options are
(1) Track down the source of the timeout. Most likely it is a proxy server that is dropping the connection after a short time.
(2) Live with the timeout and subsequent restart of the app, and program your application to save the user's state so it can be restored quickly. There is a session store within RAP that is persistent across HTTP sessions.
Hope that helps,
Cole
Eclipse User wrote on Mon, 12 September 2011 10:31
Originally posted by: <a href="mailto:"></a>
Graham,
HTH
Rüdiger
Rüdiger Herrmann
Previous Topic:Tree widget support v_scroll and h_scroll??
Next Topic:Re: Dialog with Icon
Current Time: Sun Feb 18 07:50:47 GMT 2018
Powered by FUDForum. Page generated in 0.01937 seconds
