Home » Modeling » EMF » Package with uri 'null' not found
Package with uri 'null' not found [message #718183] Tue, 23 August 2011 14:04 Go to next message
Dirk Hoffmann is currently offline Dirk HoffmannFriend
I'm using EMF standalone (actually inside an Eclipse based product but
the EMF jars are in a separate plug-in so the do not interfere with the
EMF version that comes with the Product).
I get the "Package with uri 'null' not found" error when trying to load
a file this way:
* @param inputStream XML comes in as an {@link InputStream}
* @return EMF resource containing the model data
* @throws IOException
private Resource load(InputStream inputStream) throws IOException {
ResourceSet rs = new ResourceSetImpl();
rs.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xml",
new GenLegacyRenderingResourceFactoryImpl());
GenLegacyRenderingPackage.eINSTANCE.eClass();
Map options = new Properties();
// Just a dummy url to specify the type of the document
URI uri = URI.createURI("http://www.tesis.de/legacy/rendering.xml");
Resource resource = rs.createResource(uri);
resource.load(inputStream, options);
return resource;
Any idea what is wrong with this approach?
Thanks and Regards,
Dirk
Re: Package with uri 'null' not found [message #718195 is a reply to message #718183] Tue, 23 August 2011 14:53 Go to previous messageGo to next message
Dirk,
Does the generated XyzExample work properly?
On 23/08/2011 7:04 AM, Dirk Hoffmann wrote:
> the EMF version that comes with the Product).
> load a file this way:
> URI uri =
> return resource;
> Thanks and Regards,
> Dirk
Re: Package with uri 'null' not found [message #718198 is a reply to message #718195] Tue, 23 August 2011 15:15 Go to previous messageGo to next message
It produces:
Enter a list of file paths or URIs that have content like this:
<?xml version="1.0" encoding="ASCII"?>
<legacyrendering:LegacyRendering
xmlns:legacyrendering="http://legacyrendering/1.0"/>
but the files I want to load start like this:
<T4XObject type="4974656d">
<ERPObject status="4f4b" message="">
So there is no namespace declaration and of course no namespace prefix
and the root element is T4XObject which according to the meta model is
an element of LegacyRendering.
When I pass in the name of such a file I get
Problem loading
file:/D:/S/L/T4S_apps/trunk/plugins/de.tesis.plmware.t4x.app.tests/example1.xml
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
'null' not found.
(file:/D:/S/L/T4S_apps/trunk/plugins/de.tesis.plmware.t4x.app.tests/example1.xml,
2, 28)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
de.tesis.plmware.t4x.app.legacyrendering.tests.GenLegacyRenderingExample.main(GenLegacyRenderingExample.java:89)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
with uri 'null' not found.
2, 28)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1307)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1468)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1019)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:533)
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(XMLDTDValidator.java:798)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:878)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDispatcher.scanRootElementHook(XMLDocumentScannerImpl.java:1157)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFragmentScannerImpl.java:1794)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:368)
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:834)
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:148)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:180)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
... 2 more
Am 23.08.2011 16:53, schrieb Ed Merks:
> Dirk,
>> return resource;
>> Thanks and Regards,
>> Dirk
Re: Package with uri 'null' not found [message #718207 is a reply to message #718198] Tue, 23 August 2011 15:24 Go to previous messageGo to next message
Dirk,
Comments below.
On 23/08/2011 8:15 AM, Dirk Hoffmann wrote:
> It produces:
Given it produces what you show above, why are you expecting it to be
able to load this form of XML?
> Problem loading
> 'null' not found.
> 2, 28)
> at
> at
> at
> at
> 2, 28)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 2 more
>> Dirk,
>>> Hi,
>>> return resource;
>>> Thanks and Regards,
>>> Dirk
Re: Package with uri 'null' not found [message #718414 is a reply to message #718207] Wed, 24 August 2011 08:59 Go to previous message
Hi Ed,
thanks for your hints. Got it going. See below.
Am 23.08.2011 17:24, schrieb Ed Merks:
> Dirk,
> Comments below.
>> It produces:
>> <?xml version="1.0" encoding="UTF-8"?>
The point is that there was first the XML and I created the meta model
from what I saw inside the XML files. I only had a rough idea of how EMF
deserializes XML into a model. I haven't tried out the generated example
before you asked me to do so.
Anyway its working now. I overrode some methods of the generated
resource implementation and the SAXXMLHandler.
>> Problem loading
>> 'null' not found.
>> 2, 28)
>> at
>> at
>> at
>> at
>> 2, 28)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 2 more
>>> Dirk,
>>>> Hi,
>>>> return resource;
>>>> Thanks and Regards,
>>>> Dirk
Previous Topic:Should not be able to save when editor has errors
Next Topic:[CDO] No type mapping factory found
Current Time: Thu Apr 19 12:18:51 GMT 2018
Powered by FUDForum. Page generated in 0.01989 seconds
