Home » Language IDEs » Java Development Tools (JDT) » Hot Swap does not work :(
Hot Swap does not work :( [message #717438] Sat, 20 August 2011 17:18 Go to next message
alex_prislopeanu is currently offline alex_prislopeanuFriend
Well my problem is simple: hot swap does not work in Eclipse EE...
Tried debugging , running, breakpoints, nothing seems to change the console output ...
my code:
while(x>=0)
{Thread.sleep(1000);
System.out.println("bla bla ");
changing the println line does not change the console output... am I doing something wrong ? config ? Maybe it should not work for stuff like this ?
[Updated on: Sat, 20 August 2011 17:18]
Report message to a moderator
Re: Hot Swap does not work :( [message #717456 is a reply to message #717438] Sat, 20 August 2011 19:31 Go to previous messageGo to next message
any1 ?
Re: Hot Swap does not work :( [message #717464 is a reply to message #717456] Sat, 20 August 2011 20:47 Go to previous messageGo to next message
also debugging doesn't seem to work at all. I hit a break point, change values, but when I step over the new code, the old values are in effect
Re: Hot Swap does not work :( [message #717832 is a reply to message #717464] Mon, 22 August 2011 13:29 Go to previous messageGo to next message
Originally posted by: Rich Kulp
Make sure you have "Incremental Build" turned on. I don't how many times
I got frustrated trying to change code and it wouldn't change and it
turned out because I had turned the build off! :-)
Rich Kulp
Re: Hot Swap does not work :( [message #717843 is a reply to message #717464] Mon, 22 August 2011 13:50 Go to previous message
Originally posted by: Bill T.
You may wish to check developer works, there was a recent article on when hot swap will and will not work. might explain what your seeing
Previous Topic: Developing a content Assist plugin
Next Topic:Eclipse excludes all sources when import maven project
Current Time: Wed May 23 01:46:13 GMT 2018
Powered by FUDForum. Page generated in 0.01628 seconds
